I’m trying to shrink a dynamically-allocated Manjaro guest on a Windows 10 host in VirtualBox, and—after cleaning up unneeded files with the suggestions here—I’m stuck on the step of zero-filling the freed space. I think I should use zerofree to accomplish this, since I’ve made the maximum size of the VM bigger than physical drive on which it resides. Maybe that will be a problem anyway, I don’t know, but the zerofree page gives me to understand that it would potentially be a problem with alternative commands I’ve seen, like
dd if=/dev/zero of=zero.tmp bs=10M; rm -f zero.tmp
or
cat /dev/zero > zero.fill; sync; sleep 1; sync; rm -f zero.fill
Maybe not. Noob here.
After installing zerofree (pamac install zerofree
), I’ve been trying to imitate this way of doing it on Ubuntu, but this zeroing doesn’t seem to work the same way in Manjaro. I first tried enabling the boot recovery mode by commenting out GRUB_DISABLE_RECOVERY=true
in /etc/default/grub
, followed by sudo update-grub
. That worked, and pressing esc
while booting showed that option in the GRUB menu. lsblk -f
showed the disk at dev/sda1
of type ext4
mounted at the root. However, it is mounted read/write, so I get this output:
$ zerofree -v /dev/sda1
zerofree: filesystem /dev/sda1 is mounted rw
Uncommenting GRUB_ROOT_FS_RO=true
in etc/default/grub
did not change this.
I then bashed my head against mount
and chroot
a while, thinking the answer must be in there somewhere. I have not found it.
I also tried booting with a live iso in the VM’s “optical drive” and got variations on the same theme.
$ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squash 4.0 0 100% /run/miso/sfs/livefs
loop1 squash 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squash 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squash 4.0 0 100% /run/miso/sfs/rootfs
sda
└─sda1 ext4 1.0 462d6402-fb0a-4103-813c-82532e2008dc 455G 4%
sr0 iso966 Joliet MANJARO_XFCE_2132 2022-07-04-07-09-08-00 0 100% /run/miso/bootmnt
$ manjaro-chroot -a
$ exit
$ mkdir /chroot
$ mount -r /dev/sda1 /chroot
bash: zerofree: command not found
$ chroot /chroot zerofree -v /chroot
zerofree: failed to determine filesystem mount state /chroot
$ chroot /chroot zerofree -v /dev/sda1
zerofree: failed to determine filesystem mount state /dev/sda1
And that’s where I’m at. Is there a way to do the chroot
and point zerofree
at the right mount
or remount
or bind
or one of those other words? Maybe mount /usr/bin/zerofree
in one place and run it on the rest of the drive in another? Is there a better way to accomplish the zeroing?
Just to complete the tale, I hope to go on to finish the process like given here. Yep, perhaps the moral of the story is that a 512 GB vmdk in VirtualBox is not the right call.
