Cross-platform file transfer solution?
I have used “Sendanywhere” for few years now- it transfers files for me across systems ( android, Debian-based distros, Windows, iPad ). Now that I am trying to use arch based distros, the application crashes often and is unusable.
λ sendanywhere
10:06:32.445 › App starting...
(node:69360) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Pleaseuse the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
(electron8:69360): Gtk-WARNING **: 10:06:32.460: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is not avalid color name
(electron8:69360): Gtk-WARNING **: 10:06:32.460: Theme parsing error: gtk-dark.css:5825:14: not a number
(electron8:69360): Gtk-WARNING **: 10:06:32.460: Theme parsing error: gtk-dark.css:5826:13: not a number
(electron8:69360): Gtk-WARNING **: 10:06:32.460: Theme parsing error: gtk-dark.css:5827:11: Expected a length
10:06:32.492 › [event] app.ready.
(electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It willchange to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
10:06:32.508 › [event] app.browser-window-created.
10:06:32.540 › [event] app.browser-window-created.
10:06:32.559 › IP 112.196.132.43
10:06:32.560 › os ver 5.16.12-zen1-1-zen (x64)
10:06:32.561 › paprika setup..
10:06:32.564 › deviceId 7697454384562
10:06:32.628 › db initialized..
10:06:32.630 › handler initialized
10:06:32.631 › push initialized..
10:06:32.632 › policy initialized..
10:06:32.653 › [event] HandlerManager.onCreateWindow
10:06:32.864 › [event] mainWindow.webContents.dom-ready
[69360:0307/100633.391210:FATAL:gpu_data_manager_impl_private.cc(1034)] The display compositor is frequently crashing. Goodbye.
Failed to get crash dump id.
Report Id:
10:06:33.959 › P PAPRIKA_STATE_PREPARING PAPRIKA_DETAILED_STATE_PREPARING_UPDATED_AUTH_TOKEN 0
Report Id:
fish: Job 1, 'sendanywhere' terminated by signal SIGILL (Illegal instruction)
  1. I am a noob, and don’t know what this means or how can I rectify this on my own. Please suggest a way out, if any.
  2. If not, can you suggest a reliable file transfer alternative ( not browser based please ). I have heard Feem is good ( but it crashes without notice as well ), but would be happier if there are any other options.
It’s apparently a different problem than you thought - not with the App, but with your Desktop Environment.
This needs to be addressed - the App is probably fine …
Someone else may know what to do - I don’t - and will not be here for some time anyway.
All the best!
Oh… I have used KDE on Manjaro as well as Garuda with the same result. If someone confirms, could probably change the DE :crossed_fingers:
I do not think has something to do with the DE.
Use --no-sandbox when you start the app …
I usually just use kdeconnect for some quick small file transferring(also I use syncthing, samba, ftp, scp), right click file, send → device, done
It is a good option actually. But iPad does not have KDEconnect…So, forced to look for alternatives
There seems to some beta version of kdeconnect for iphone and ipad from my search,
dont know much about it
OMG! I absolutely didn’t know this. And now, I can confirm that this works for the moment (it is still under development). Thank you so much :slight_smile:
