Creative Sound Blaster X4 - No 5.1 Surround Sound
Hello, i tested today my new USB DAC, Creative Sound Blaster X4…
Headphones and Front Speakers working flawless (switching between HP and Speakers are easy possible with a hardware button) with Analog Stereo Duplex (for pavucontrol in KDE). This was also required for my other Creative Sound Blaster AE-5.
It was possible to gain full 5.1 Surround Sound in Alsamixer on my SB AE-5 (in my other PC) but that isn’t the case for the SB X4.
While Alsamixer showes this options, it was no effect on the other 5.1 channels… only Front Left & Right is working.
$ inxi -zv8
  Kernel: 7.2.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.2-x86_64
    root=UUID=7d0165de-089c-45ee-adb3-9a8ca8d12132 rw amd_pstate=passive
    amdgpu.ppfeaturemask=0xffffffff sysrq_always_enabled=1
    resume=UUID=342d34b4-152b-4a04-9479-c0b3cbc6c96f udev.log_priority=3
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
  Type: Desktop Mobo: Gigabyte model: X870E AORUS ELITE WIFI7 v: x.x
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: FA7 date: 12/12/2025
  System RAM: total: 32 GiB available: 30.95 GiB used: 3.53 GiB (11.4%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
    part-no: UD5-6000 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
    level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
    model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 5233 min/max: 603/5272 boost: enabled scaling:
    driver: amd-pstate governor: performance cores: 1: 5233 2: 5233 3: 5233
    4: 5233 5: 5233 6: 5233 7: 5233 8: 5233 9: 5233 10: 5233 11: 5233 12: 5233
    13: 5233 14: 5233 15: 5233 16: 5233 bogomips: 150108
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
    ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
    perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
    stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
    umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: vmscape mitigation: IBPB on VMEXIT
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: Tul / PowerColor driver: amdgpu v: kernel
    arch: RDNA-4 code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie:
    gen: 5 speed: 32 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,
    DP-2, DP-3, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: HannSpree/HannStar HS233 serial: <filter>
    built: 2010 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
    chroma: red: x: 0.647 y: 0.333 green: x: 0.302 y: 0.600 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 510x287mm (20.08x11.3")
    diag: 585mm (23") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
    720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 9070 (radeonsi gfx1201 ACO DRM
    3.64 7.2.3-2-MANJARO) device-ID: 1002:7550 memory: 15.62 GiB unified: no
    display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 (RADV GFX1201) driver: mesa radv v: 26.2.2-arch1.1
    device-ID: 1002:7550 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Gigabyte
    bus-ID: 1d:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-3: Creative Sound Blaster X4
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2 chip-ID: 041e:3278
    class-ID: 0102 serial: <filter>
  API: ALSA v: k7.2.3-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8922AE 802.11be PCIe Wireless Network Adapter
    driver: rtw89_8922ae v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: e000 bus-ID: 0f:00.0 chip-ID: 10ec:8922 class-ID: 0280
  IF: wlp15s0 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 10:00.0
  IF: enp16s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:2 chip-ID: 0bda:8922
  Local Storage: total: 3.18 TiB used: 502.02 GiB (15.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRDY2000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK51.2 temp: 47.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 960 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B7QCXE7 temp: 22.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD
    serial: <filter> scheme: GPT
  ID-1: / raw-size: 390.62 GiB size: 383.43 GiB (98.16%)
    used: 14.06 GiB (3.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: root
    uuid: 7d0165de-089c-45ee-adb3-9a8ca8d12132
    used: 328 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: efi
    uuid: 3BE0-5B02
  ID-3: /home raw-size: 503.28 GiB size: 494.31 GiB (98.22%)
    used: 14.19 GiB (2.9%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: home
    uuid: 938cd14e-1366-4038-9b43-1348b0e4aae4
  ID-4: /media/nvme-games raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 473.77 GiB (25.9%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: nvme-games uuid: ef738838-b40e-4cbe-a55d-a3f8bcfdb11a
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
    priority: -1 dev: /dev/sda2 maj-min: 8:2 label: swap
    uuid: 342d34b4-152b-4a04-9479-c0b3cbc6c96f
  ID-1: /dev/nvme1n1p1 maj-min: 259:3 size: 100 MiB fs: vfat label: N/A
    uuid: 9095-62C6
  ID-2: /dev/nvme1n1p2 maj-min: 259:4 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:5 size: 396.75 GiB fs: ntfs label: N/A
    uuid: 388AB2318AB1EB8E
  ID-4: /dev/nvme1n1p4 maj-min: 259:6 size: 546 MiB fs: ntfs label: N/A
    uuid: 800CA58D0CA57EB2
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:8922 class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-5:2 info: Creative Sound Blaster X4
    type: HID,abstract (modem),CDC-data,audio
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
    chip-ID: 041e:3278 class-ID: 0102 serial: <filter>
  Device-2: 3-7:3 info: Integrated Express GIGABYTE Device type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5711 class-ID: 0300
  Device-3: 3-9:4 info: CHERRY G83 (RS 6000) Keyboard type: keyboard
    chip-ID: 046a:0011 class-ID: 0301
  Device-4: 3-10:5 info: A4Tech XL-730K / XL-747H XL-750BK XL-755BK Mice
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 09da:9090 class-ID: 0301
  Hub-4: 4-0:1 info: super-speed hub ports: 6 rev: 3.1
  Device-1: 4-1:2 info: Samsung PSSD T7 type: mass storage driver: uas
    interfaces: 1 rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 power: 896mA chip-ID: 04e8:4001 class-ID: 0806
    serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-10: 10-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-11: 11-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  System Temperatures: cpu: 43.6 C mobo: 48.0 C gpu: amdgpu temp: 24.0 C
    mem: 24.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 725
  Packages: pm: pacman pkgs: 1373 libs: 377 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    2: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    3: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 340
  1: cpu: 1.4% command: firefox pid: 15434 mem: 837.8 MiB (2.6%)
  2: cpu: 1.1% command: firefox pid: 15661 mem: 461.1 MiB (1.4%)
  3: cpu: 0.6% command: Linux started-by: dolphin pid: 16520
    mem: 146.1 MiB (0.4%)
  4: cpu: 0.5% command: kate pid: 16542 mem: 120.5 MiB (0.3%)
  5: cpu: 0.4% command: firefox pid: 15885 mem: 345.5 MiB (1.0%)
  Memory top: 5 of 340
  1: mem: 837.8 MiB (2.6%) command: firefox pid: 15434 cpu: 1.4%
  2: mem: 492.5 MiB (1.5%) command: plasmashell pid: 1040 cpu: 0.2%
  3: mem: 461.1 MiB (1.4%) command: firefox pid: 15661 cpu: 1.1%
  4: mem: 410.0 MiB (1.2%) command: systemsettings pid: 14577 cpu: 0.1%
  5: mem: 346.9 MiB (1.0%) command: firefox pid: 15670 cpu: 0.3%
  Processes: 340 Power: uptime: 6h 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.31 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: gcc: 16.2.1 Shell: Bash v: 5.3.15 running-in: konsole
    inxi: 3.3.41
$ pactl list cards
Card #43
        Driver: alsa
        Owner Module: n/a
        Properties:
                device.enum.api = "udev"
                device.api = "alsa"
                media.class = "Audio/Device"
                api.alsa.path = "hw:0"
                api.alsa.card = "0"
                api.alsa.card.name = "HDA ATI HDMI"
                api.alsa.card.longname = "HDA ATI HDMI at 0xf6ca0000 irq 152"
                device.plugged.usec = "14004552"
                device.bus_path = "pci-0000:03:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card0"
                device.bus = "pci"
                device.subsystem = "sound"
                device.vendor.id = "0x1002"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
                device.product.id = "0xab40"
                device.product.name = "Navi 48 HDMI/DP Audio Controller"
                device.name = "alsa_card.pci-0000_03_00.1"
                device.description = "Navi 48 HDMI/DP Audio Controller"
                device.nick = "HDA ATI HDMI"
                device.icon_name = "audio-card-analog-pci"
                api.alsa.use-acp = "true"
                api.acp.auto-port = "false"
                api.dbus.ReserveDevice1.Priority = "-20"
                api.alsa.split-enable = "true"
                spa.object.id = "2"
                factory.id = "15"
                client.id = "42"
                object.id = "43"
                object.serial = "43"
                object.path = "alsa:acp:HDMI"
                alsa.card = "0"
                alsa.card_name = "HDA ATI HDMI"
                alsa.long_card_name = "HDA ATI HDMI at 0xf6ca0000 irq 152"
                alsa.mixer_name = "ATI R6xx HDMI"
                alsa.components = "HDA:1002aa01,00aa0100,00100a00"
                alsa.id = "HDMI"
                device.string = "0"
        Profiles:
                off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
                output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
                output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
                output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
                output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: yes)
                output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
                output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
                output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
                pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
        Active Profile: off
        Ports:
                hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "Legacy 1"
                                card.profile.port = "0"
                        Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
                hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "Legacy 2"
                                card.profile.port = "1"
                        Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
                hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "Legacy 3"
                                card.profile.port = "2"
                        Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
                hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "Legacy 4"
                                card.profile.port = "3"
                                device.product.name = "HS233"
                                iec958.codecs.detected = "[\"PCM\"]"
                                audio.channels.detected = "2"
                                audio.position.detected = "[FL,FR]"
                        Part of profile(s): output:hdmi-stereo-extra3
Card #44
        Driver: alsa
        Owner Module: n/a
        Properties:
                device.api = "alsa"
                api.alsa.path = "hw:2"
                api.alsa.card = "2"
                api.alsa.card.name = "Sound Blaster X4"
                api.alsa.card.longname = "Creative Technology Ltd Sound Blaster X4 at usb-0000:15:00.0-5, full speed"
                device.plugged.usec = "14716236"
                device.bus_path = "pci-0000:15:00.0-usb-0:5:1.3"
                sysfs.path = "/devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:0c.0/0000:15:00.0/usb3/3-5/3-5:1.3/sound/card2"
                device.bus-id = "usb-Creative_Technology_Ltd_Sound_Blaster_X4_95DBF3489C1B23DF-03"
                device.bus = "usb"
                device.vendor.id = "0x041e"
                device.vendor.name = "Creative Technology, Ltd"
                device.product.id = "0x3278"
                device.product.name = "Sound Blaster X4"
                device.serial = "Creative_Technology_Ltd_Sound_Blaster_X4_95DBF3489C1B23DF"
                device.name = "alsa_card.usb-Creative_Technology_Ltd_Sound_Blaster_X4_95DBF3489C1B23DF-03"
                device.description = "Sound Blaster X4"
                device.nick = "Sound Blaster X4"
                device.icon_name = "audio-card-analog-usb"
                api.dbus.ReserveDevice1 = "Audio2"
                spa.object.id = "6"
                factory.id = "15"
                client.id = "42"
                object.id = "44"
                object.serial = "44"
                object.path = "alsa:acp:X4"
                alsa.card = "2"
                alsa.card_name = "Sound Blaster X4"
                alsa.long_card_name = "Creative Technology Ltd Sound Blaster X4 at usb-0000:15:00.0-5, full speed"
                alsa.driver_name = "snd_usb_audio"
                alsa.mixer_name = "USB Mixer"
                alsa.components = "USB041e:3278"
                alsa.id = "X4"
                device.string = "2"
        Profiles:
                output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
                output:analog-stereo+input:iec958-stereo: Analog Stereo Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 6555, available: yes)
                output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
                output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
                output:iec958-stereo+input:iec958-stereo: Digital Stereo Duplex (IEC958) (sinks: 1, sources: 1, priority: 5555, available: yes)
                output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
                output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
                output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
                output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
                output:analog-surround-21+input:iec958-stereo: Analog Surround 2.1 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 1355, available: yes)
                output:analog-surround-41+input:iec958-stereo: Analog Surround 4.1 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 1355, available: yes)
                output:analog-surround-51+input:iec958-stereo: Analog Surround 5.1 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 1355, available: yes)
                output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
                output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
                output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
                output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
                output:analog-surround-50+input:iec958-stereo: Analog Surround 5.0 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 1255, available: yes)
                output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
                output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: yes)
                output:iec958-ac3-surround-51+input:iec958-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 355, available: yes)
                output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
                input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
                input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 55, available: yes)
                pro-audio: Pro Audio (sinks: 3, sources: 1, priority: 1, available: yes)
        Active Profile: output:analog-stereo+input:analog-stereo
        Ports:
                analog-input: Analog Input (type: Analog, priority: 10000, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "analog"
                        Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
                iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "spdif"
                        Part of profile(s): input:iec958-stereo, output:analog-stereo+input:iec958-stereo, output:analog-surround-21+input:iec958-stereo, output:analog-surround-41+input:iec958-stereo, output:analog-surround-50+input:iec958-stereo, output:analog-surround-51+input:iec958-stereo, output:iec958-stereo+input:iec958-stereo, output:iec958-ac3-surround-51+input:iec958-stereo
                analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "speaker"
                        Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-stereo+input:iec958-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-21+input:iec958-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-41+input:iec958-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-50+input:iec958-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo, output:analog-surround-51+input:iec958-stereo
                iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "spdif"
                        Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-stereo+input:iec958-stereo
Card #45
        Driver: alsa
        Owner Module: n/a
        Properties:
                device.api = "alsa"
                api.alsa.path = "hw:1"
                api.alsa.card = "1"
                api.alsa.card.name = "HD-Audio Generic"
                api.alsa.card.longname = "HD-Audio Generic at 0xf6900000 irq 153"
                device.plugged.usec = "14029284"
                device.bus_path = "pci-0000:1d:00.6"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:1d:00.6/sound/card1"
                device.bus = "pci"
                device.vendor.id = "0x1022"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
                device.product.id = "0x15e3"
                device.product.name = "Ryzen HD Audio Controller"
                device.name = "alsa_card.pci-0000_1d_00.6"
                device.description = "Ryzen HD Audio Controller"
                device.nick = "HD-Audio Generic"
                api.dbus.ReserveDevice1 = "Audio1"
                spa.object.id = "4"
                factory.id = "15"
                client.id = "42"
                object.id = "45"
                object.serial = "45"
                object.path = "alsa:acp:Generic"
                alsa.card = "1"
                alsa.card_name = "HD-Audio Generic"
                alsa.long_card_name = "HD-Audio Generic at 0xf6900000 irq 153"
                alsa.mixer_name = "Realtek ALC1220"
                alsa.components = "HDA:10ec1220,1458a0c3,00100101"
                alsa.id = "Generic"
                device.string = "1"
        Profiles:
                output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
                output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: no)
                output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: no)
                input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
                pro-audio: Pro Audio (sinks: 2, sources: 1, priority: 1, available: yes)
        Active Profile: off
        Ports:
                analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
                        Properties:
                                port.type = "mic"
                        Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
                analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, not available)
                        Properties:
                                port.type = "mic"
                analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 3, not available)
                        Properties:
                                port.type = "line"
                analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 4, not available)
                        Properties:
                                port.type = "headphones"
                        Properties:
                                port.type = "spdif"
                                card.profile.port = "4"
$ amixer --card='X4'
Simple mixer control 'Speaker',0
  Capabilities: pvolume pswitch pswitch-joined
  Playback channels: Front Left - Front Right - Rear Left - Rear Right - Front Center - Woofer
  Limits: Playback 0 - 51
  Mono:
  Front Left: Playback 42 [82%] [-14.13dB] [on]
  Front Right: Playback 42 [82%] [-14.13dB] [on]
  Rear Left: Playback 42 [82%] [-14.13dB] [on]
  Rear Right: Playback 42 [82%] [-14.13dB] [on]
  Front Center: Playback 42 [82%] [-14.13dB] [on]
  Woofer: Playback 42 [82%] [-14.13dB] [on]
Simple mixer control 'PCM Capture Source',0
  Capabilities: enum
  Items: 'Microphone' 'What U Hear' 'Aux In' 'SPDIF In'
  Item0: 'Microphone'
Simple mixer control 'Microphone',0
  Capabilities: pvolume cvolume pswitch pswitch-joined cswitch cswitch-joined
  Limits: Playback 0 - 105 Capture 0 - 105
  Front Left: Playback 0 [0%] [-96.00dB] [off] Capture 0 [0%] [-96.00dB] [off]
  Front Right: Playback 0 [0%] [-96.00dB] [off] Capture 0 [0%] [-96.00dB] [off]
Simple mixer control 'Aux In',0
Simple mixer control 'Auto Gain Control',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [off]
Simple mixer control 'SPDIF In',0
  Limits: Playback 0 - 321 Capture 0 - 321
  Front Left: Playback 0 [0%] [-80.05dB] [off] Capture 0 [0%] [-80.05dB] [off]
  Front Right: Playback 0 [0%] [-80.05dB] [off] Capture 0 [0%] [-80.05dB] [off]
Simple mixer control 'SPDIF-Out',0
  Mono:
Simple mixer control 'What U Hear',0
  Capabilities: cvolume cswitch cswitch-joined
  Limits: Capture 0 - 321
  Front Left: Capture 0 [0%] [-80.05dB] [off]
  Front Right: Capture 0 [0%] [-80.05dB] [off]
I also not touched this guide yet, which @nikgnomic gave me (im not sure how to implement that stuff into my system):
I’m still pretty clueless how to deal with that sound features around Linux.
I really could need help here.
Screenshot of GUI controls and pactl data shows device is using Profile Analog Stereo Duplex output:analog-stereo+input:analog-stereo
Card #44
        Profiles:
For 5.1 playback, change the Profile to one that has Analog Surround 5.1 output:
pactl set-card-profile alsa_card.usb-Creative_Technology_Ltd_Sound_Blaster_X4_95DBF3489C1B23DF-03 output:analog-surround-51+input:analog-stereo
If it would be this easy, i wouldn’t even had open this topic.
The profile has to be Analog Stereo Duplex, its exactly the same as with my creative SB AE-5.
:backhand_index_pointing_down:
The sound will get heavily acoustic noise when i choose another of this 5.1 or 5.1+input analog stereo Profiles in Pavucontrol in KDE. :frowning:
And even then, all other channels going full muted only front left has sound and has only acoustic noise.
Do you still think the guide which you gave me, would do the trick?
EDIT1:
@nikgnomic
Uff the USB DAC Break my entire PC now… i swapped on the hardware (button) back from speakers to Headphones the LED’s on the DAC blinked all RED and now Pavucontrol shows errors, the shutdown shows errors… i had manually remove the USB, because the system refused to reboot.
Even after a restart my Creative Soundblaster showing connection and disconnection message after i plug in the usb connector again… Hardware is no longer recognise from Manjaro after another reboot. OMG!!!
I think i just break my entire installation now. Luckily i created a Timeshift snapshot, i guess i probably send the hardware back… it looks broken now.
Edit2: Okay i booted into Live Boot, I tried again the USB Creative SB X4 DAC and there it also showed connect & instant disconnect info at the bottom right in KDE at the desktop.
Probably my install is still fine.
But this Creative Device somehow can be easily destroyed in Linux!
Time to return that soundcard :frowning:
I can’t believe that expensive hardware can so easily get defect… that DAC was really expensive.
I find that rather unlikely, but I guess anything is possible, given enough entropy. :thinking:
In the meantime, I’ll unlist this Topic pending your findings on a replacement DAC. :wink:
Everything is possible, it just could be bad quality also… but after just 5-8hours usage.
I own Creative Soundcards since 90th… SB32, Audigy1, Audigy2, X-fi and AE-5.
I never saw something like that.
Sometimes hardware can be defective without being immediately apparent; I’ve unfortunately had too much experience of this. :hammer: :wastebasket:
In any case, let’s see if a replacement module fixes things. :+1: :wink:
TBH, since @nikgnomic not even pointed at the guide (which he gave me few weeks ago) anymore, im not sure if its even possible to get clean 5.1 working sound with that Creative DAC. Specially since the Guide had a strange focus on Voice Chat/Streaming, instead focusing the surround sound.
I probably should go another route now…
I also don’t get it why you censorship this Topic now, why not let other linux user’s knowing which problems they might facing. I don’t descripted the error’s in details not just for fun… people who already have that Creative USB DAC should probably evade this COMBINATION of settings which lead to the breaking device.
If you agree or not, shouldn’t lead to censorship… let everyone made his own judgement.
Maybe my conclusion is wrong, but you can’t proof it. Of course im not 100% sure either,
im not here to fool anyone. (This is a greyzone, are there forum rules against greyzones now?)
Btw. i saw Creative SB AE-5 Topic’s which was unsolved in our forum, leading to expectations that this soundcard not working with 5.1 sound under Linux… Why aren’t this Topic’s unlisted/censored? (i know they are fake, because it is running for me)
My Creative SB AE-5 soundcard is still working under linux for 5 years today and running in 5.1 Mode daily (but with hickups, that required a new coldboot “sometimes” because of flawed initialisation from the hardware, which lead sometimes to 4.0 sound instead 5.1sound). The Key point was always to let the soundcard run in Analog Stereo Duplex in pavucontrol and let Alsamixer do the rest for clean 5.1 sound, problem SOLVED.
My personal guess was, that it is the same with this USB Soundcard..? And my personal guess that this AE-5 Soundcard was instantly muted (for a good reason) when i and the other manjaro or ex-manjaro forum members choosed another pavu soundprofile, that this soundcard was protected from the reversed engineered creative driver’s related with a Device MUTE/No Sound in the past. While the SB X4 has this distortions sounds there was AE-5 muted for protection i assume.
My guess is, that this newer DAC is hardware failing now, because of this missing driver protection (the combination) + pavu 5.1 (or 5.1 + analog input) + switching hardware sound button (from Line Out to Headphones) on the device, while playing this distorted sound = death.
I don’t mind to be proofed wrong btw. everyone who still has warranty and owning this device, is welcomed to test the device and tell another story.
inxi data shows audio device is using 4 drivers
snd-usb-audio is the standard USB audio driver
hid-generic and usbhid are standard Human Interface Device drivers (for the volume control and buttons). These drivers are also used by 3 other USB devices on this system
It might help if the USB audio device is plugged in to a different USB hub that is not shared
with other HID devices, I would avoid using any of the HID controls until a lot more is known about how they work under the hood on Linux.
The unusual driver (that I have never seen before on an audio device) is cdc_acm
USB communications device class - Wikipedia
The Abstract Control Model (ACM) protocol defined in the CDC specification can be used to implement a general-purpose serial UART. For example, an adapter cable which is USB on one end and RS-232 on the other
CDC-ACM is commonly implemented in software on microcontrollers such as the ESP32 to provide a serial console for configuring and debugging embedded systems
I would remove this driver (modprobe -r cdc_acm) that might be causing problems for other drivers
As far as I can tell, the guide is intended to provide independent audio channels for speakers (game) and headset/headphones (chat) available as PipeWire card profiles, based on old Archwiki information: Wireplumber - Configuration - Simultaneous output to multiple sinks on the same sound card
But this guide is only for audio and doesn’t mention any problems related to the buttons
The only way I can find to contact the author for more information about this device is via email address posted on Github page - phasecorex@gmail.com
Thanks for you feedback, i also plugged later the Creative USB DAC on front USB Port from my Case (instead the backslot IO), but that didn’t changed anything.
I returned that Creative SB X4 USB DAC to amazon, is it still important to remove that drivers?
But i guess i better execute your command anyways, thanks for that info.
I just bought a Internal PCI-E Creative SoundBlaster AE-7, i hope that device is working better. I creating another help topic, when i run into troubles with that card.
If you want to remove unneeded drivers, then probably yes (although I can’t imagine them taking up much storage space).
Since this is the case and there is no actual Solution, and the fact you stated you’d start a new Topic (which is indeed appropriate), I’ll now close this Topic, as a general part of Forum housekeeping. :wink:
No
AE-7 should be similar to your previous AE-5 cards since they use the same audio codec
LKML: Connor McAdams: [PATCH 00/20] ALSA: hda/ca0132 - Add AE-7support/Control cleanup
