× var-lib-snapd-snap-core-11993.mount - Mount unit for core, revision 11993
Loaded: loaded (/etc/systemd/system/var-lib-snapd-snap-core-11993.mount; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Mon 2021-11-22 14:34:51 +06; 16s ago
Where: /var/lib/snapd/snap/core/11993
What: /var/lib/snapd/snaps/core_11993.snap
CPU: 3ms
Nov 22 14:34:51 msbis-pc systemd[1]: Mounting Mount unit for core, revision 11993...
Nov 22 14:34:51 msbis-pc mount[3132]: mount: /var/lib/snapd/snap/core/11993: mount failed: Operation not permitted.
Nov 22 14:34:51 msbis-pc systemd[1]: var-lib-snapd-snap-core-11993.mount: Mount process exited, code=exited, status=1/FAILURE
Nov 22 14:34:51 msbis-pc systemd[1]: var-lib-snapd-snap-core-11993.mount: Failed with result 'exit-code'.
Nov 22 14:34:51 msbis-pc systemd[1]: Failed to mount Mount unit for core, revision 11993.
systemctl start var-lib-snapd-snap-core-11993.mount
Job failed. See "journalctl -xe" for details.
journalctl -xe
░ An n/a= process belonging to unit var-lib-snapd-snap-core-11993.mount has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Nov 22 15:01:05 msbis-pc systemd[1]: var-lib-snapd-snap-core-11993.mount: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ Defined-By: systemd
░░ The unit var-lib-snapd-snap-core-11993.mount has entered the 'failed' state with result 'exit-code'.
Nov 22 15:01:05 msbis-pc systemd[1]: Failed to mount Mount unit for core, revision 11993.
░░ Subject: A start job for unit var-lib-snapd-snap-core-11993.mount has failed
░░ A start job for unit var-lib-snapd-snap-core-11993.mount has finished with a failure.
░░ The job identifier is 2484 and the job result is failed.
Nov 22 15:01:05 msbis-pc polkitd[506]: Unr
@megavolt, that’s exactly what I’ve been thinking as well.
@MSbis, how did you install the snap? Can you try removing it and reinstalling? (I don’t know if this will affect any data iit uses, so perhaps make a backup first, if there is anything.)
@Mirdarthos snap was preinstalled in manjaro. I have used snap for couple of times. The error was showing after I make a usb Readonly to Write & read. I don’t know what is the connection.
I might be completely wrong, but after quickly reading through this page it would seem that perhaps it is a permission, or even a space issue where the snaps are supposed to be mounted.
This leads me to ask if you’ve made any permission changes lately?
