Hello, I just finally got GPU pass-through to be available with “lspci -nnk correctly” but now I’m trying to follow many guides like this, and they want me to pass "something to nvram in the qemu conf file but I have nothing like that, since I can’t seem to post images, let me show you the cd output
[jamesbuild1 ~]# cd /usr/share/ovmf/x64
[jamesbuild1 x64]# ls
OVMF_CODE.fd OVMF_CODE.secboot.fd OVMF.fd OVMF_VARS.fd
So I don’t have anything like what they want me to put in their example
nvram = ["/usr/share/ovmf/ovmf_code_x64.bin:/usr/share/ovmf/ovmf_vars_x64.bin"]
So I’ve put in this thinking that’d get the job done
It might be correct, but when I click begin installation on virt manager having been able to follow the rest of that guide above, I get this
Unable to complete install: ‘internal error: qemu unexpectedly closed the monitor’
File “/usr/share/virt-manager/virtManager/asyncjob.py”, line 65, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File “/usr/share/virt-manager/virtManager/createvm.py”, line 2001, in _do_async_install
installer.start_install(guest, meter=meter)
File “/usr/share/virt-manager/virtinst/install/installer.py”, line 691, in start_install
domain = self._create_guest(
File “/usr/share/virt-manager/virtinst/install/installer.py”, line 639, in _create_guest
domain = self.conn.createXML(install_xml or final_xml, 0)
File “/usr/lib/python3.8/site-packages/libvirt.py”, line 4035, in createXML
if ret is None:raise libvirtError(‘virDomainCreateXML() failed’, conn=self)
libvirt.libvirtError: internal error: qemu unexpectedly closed the monitor
One solution I found online for others was to set myself as a user in the conf file which I tried and that didn’t fix it, what gives!
