Create /boot/efi and mantain old /root
I have encountered an issue with the operating systems on my computer. I am not an expert in partitions or mount points, but here is what happened:
About six months ago, I reinstalled Manjaro (switching from KDE to GNOME) and performed a clean installation. During the setup process, I created a 512MB partition at /boot/efi , marked it as the boot partition.
Last week, I decided to install Windows 11 on another partition. However, during the installation, it indicated that there was a partition configuration issue that prevented the installation. To proceed, I had to delete the partition where Manjaro’s /boot/efi was located.
As expected, after this, I was no longer able to boot into Manjaro. I attempted to boot using a Live USB and performed a chroot to reinstall GRUB, but it could not find /boot/efi .
I created a new 512MB partition with FAT32, but I am unsure how to reinstall the firmware and make the system boot from Manjaro’s /root partition without reformatting.
The Calamares installer allows me to create /boot/efi , but it requires me to delete the current contents of the partition where I have Manjaro fully configured to my liking.
Is there any solution to restore the bootloader and make the system boot from Manjaro without losing my current configuration?
Take a look at this wiki article:
You don’t need calamares. Gparted from the live usb is enough. If the newly created esp is not recognized as such, it might be because wrong partition type or flags. It is not exactly a windows fat partition. It has to have 2 flags: esp and boot. And then has to be mounted. (Maybe a reboot inbetween). And then you chroot and reinstall grub there as per guide.
Thanks, is the first thing I tried yesterday. But some errors appear.
I follow the guide again without errors, it’s like I recover old grub configuration, but Manjaro doesn’t boot… :upside_down_face:
I had a grub theme and possibly the configuration file points to other file than default one, but I don’t know how to solve it.
I tried to follow the guide again and when I pacman -Syu grub error installing grub encountered
Well, if there is no efi partition mounted to /boot/efi in the chroot, it won’t write the efi file to the partition, but to the root partition. Therefore, your UEFI doesn’t find the EFI file on an EFI partition. Logical, right?
You might need to use a different approach to chroot into your system - to reinstall Grub and all that.
The automatic procedure (manjaro-chroot -a) probably isn’t working because you deleted the original EFI partition - which gets mounted under /boot/efi.
You created a new one - it has got a new UUID - it doesn’t match what is in /etc/fstab anymore.
To chroot using manjaro-chroot:
mount /dev/sdaX /mnt → (mount the / partition)
mount /dev/sdaY /mnt/boot/efi → (mount the EFI partition to its proper place)
manjaro-chroot /mnt /bin/bash → (under /mnt is now your assembled / file system - chroot into it)
correct /etc/fstab
lsblk -f is one tool that tells you the UUID’s
Thanks!
Yes, I’m doing the chroot maual like as you say.
What I have to do when I indentify the boot efi partition UUID?
cat /etc/fstab → look at the UUID of the partition that is mounted to /boot/efi
lsblk -f → look at the UUID of the new partition that is now supposed to be your /boot/efi location
compare the two - if different → edit /etc/fstab
nano /etc/fstab
and put in the new UUID instead of the one that is there …
We (or I) could be more specific would we know some more detail about your system and disk layout.
inxi -zv8
would reveal some important bits …
and, of course
lsblk -f
inxi -zv8
  Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_GNOME_2420 quiet
    systemd.show_status=1 splash driver=nonfree nouveau.modeset=0
    i915.modeset=1 radeon.modeset=1
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
    base: Arch Linux
  Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
    UEFI: American Megatrends v: 2803 date: 04/27/2022
  Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
    status: discharging
  System RAM: total: 32 GiB available: 31.25 GiB used: 4.13 GiB (13.2%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3733 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Patriot
    part-no: 3733 C17 Series serial: <filter>
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    part-no: 3733 C17 Series serial: N/A
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 1740 min/max: 550/4663 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1740 2: 1740 3: 1740
    4: 1740 5: 1740 6: 1740 7: 1740 8: 1740 9: 1740 10: 1740 11: 1740 12: 1740
    13: 1740 14: 1740 15: 1740 16: 1740 bogomips: 108837
    xsaves xtopology
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ZOTAC driver: nvidia
    v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
    (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.0
    chip-ID: 10de:2484 class-ID: 0300
  Device-2: ARC Camera driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10.3:6 chip-ID: 05a3:9331
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: X: loaded: N/A failed: nvidia gpu: nvidia
    note: X driver n/a, try sudo/root display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4640x1920 s-size: <missing: xdpyinfo>
  Monitor-1: DP-2 pos: primary,right res: 1200x1920 hz: 60 dpi: 94
    size: 324x518mm (12.76x20.39") diag: 611mm (24.05") modes: N/A
  Monitor-2: DP-4 pos: left res: 3440x1440 hz: 60 dpi: 110
    size: 797x334mm (31.38x13.15") diag: 864mm (34.02") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
    memory: 7.81 GiB
  Device-1: NVIDIA GA104 High Definition Audio vendor: ZOTAC
    bus-ID: 0a:00.1 chip-ID: 10de:228b class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: ARC Camera driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
  API: ALSA v: k6.12.1-4-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 5.24 TiB used: 0 KiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
    model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 620311WD temp: 25.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: KIOXIA model: EXCERIA G2 SSD
    lanes: 4 tech: SSD serial: <filter> fw-rev: ECFA17.1 temp: 26.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3500G
    tech: SSD serial: <filter> fw-rev: 70RL scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 vendor: OCZ model: VERTEX4 size: 238.47 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 1.5 scheme: MBR
  ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DL003-9VT166
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CC32 scheme: MBR
  ID-6: /dev/sdd maj-min: 8:48 vendor: Kingston model: DataTraveler 3.0
    size: 7.22 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: PMAP scheme: MBR
  Message: No partition data found.
  ID-1: /dev/nvme0n1p1 maj-min: 259:4 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:5 size: 100 MiB fs: vfat label: N/A
    uuid: ECCC-7828
  ID-3: /dev/nvme0n1p3 maj-min: 259:6 size: 1.43 TiB fs: ntfs label: N/A
    uuid: 9428DBD628DBB588
  ID-4: /dev/nvme0n1p4 maj-min: 259:7 size: 758 MiB fs: ntfs label: N/A
    uuid: DA342A0D3429ECE7
  ID-5: /dev/nvme0n1p5 maj-min: 259:8 size: 397.67 GiB fs: btrfs label: N/A
    uuid: efcf7327-b70a-4194-8cd4-6d749e10920e
  ID-6: /dev/nvme0n1p6 maj-min: 259:9 size: 512 MiB fs: vfat label: N/A
    uuid: 24EB-20C0
  ID-7: /dev/nvme1n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
  ID-8: /dev/nvme1n1p2 maj-min: 259:2 size: 931.5 GiB fs: ntfs
    label: NVMe 1TB uuid: 3E0E309D0E304FDF
  ID-9: /dev/sda1 maj-min: 8:1 size: 465.76 GiB fs: ntfs label: SDD 500GB
    uuid: 5CD028FCD028DDD0
  ID-10: /dev/sdb1 maj-min: 8:17 size: 238.47 GiB fs: ntfs label: SSD 240GB
    uuid: 3816F45B16F41C16
  ID-11: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: ntfs label: Arxius 2TB
    uuid: 60A6CCB155D250D7
  ID-12: /dev/sdd1 maj-min: 8:49 size: 3.54 GiB fs: iso9660
  ID-13: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 2AB1-D802
  Device-1: 1-6:2 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
    serial: <filter>
  Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-7.2:5 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Hub-3: 1-10:4 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 0424:2514 class-ID: 0900
  Device-1: 1-10.3:6 info: ARC Camera type: video,audio
    chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Device-1: 2-3:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 Kyson
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 504mA
    chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: ROCCAT Kave Headset type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 1e7d:38a4 class-ID: 0301
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 33 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Packages: pm: pacman pkgs: 1211 libs: 316 tools: gnome-software,pamac
    pm: flatpak pkgs: 0
    1: http://manjaro.mirror.ac.za/stable/$repo/$arch
    2: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    3: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    4: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    5: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    6: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    7: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    8: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    9: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    10: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    11: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    12: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    13: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    14: http://manjaro.grena.ge/stable/$repo/$arch
    15: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    16: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    17: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    18: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    19: https://linorg.usp.br/manjaro/stable/$repo/$arch
    20: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    21: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    22: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    23: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    24: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    25: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    26: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    27: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    28: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    30: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    32: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    33: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    34: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    35: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    36: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    37: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    38: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    39: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    40: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    41: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    42: https://mirror.23m.com/manjaro/stable/$repo/$arch
    43: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    44: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    45: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    46: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    47: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    48: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    49: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    50: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    51: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    52: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    53: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    54: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    55: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    56: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    57: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    58: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    59: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    60: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    62: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    63: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    64: https://mirrors2.manjaro.org/stable/$repo/$arch
    65: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    66: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    67: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    68: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    69: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    70: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    71: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    72: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    73: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    74: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    75: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    76: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    77: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    78: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    79: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    80: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    81: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    82: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    83: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    84: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    85: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    86: https://mirror.init7.net/manjaro/stable/$repo/$arch
    87: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    88: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    89: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    90: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    91: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    92: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    93: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    94: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    95: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    96: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    97: https://manjaro.kurdy.org/stable/$repo/$arch
    98: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    99: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    100: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    101: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    102: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    103: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    104: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    105: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
    106: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    107: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    108: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    109: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    110: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    111: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    112: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    113: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    114: https://manjaro.ynh.ovh/stable/$repo/$arch
    115: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    116: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    117: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    118: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    119: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    120: https://repos.silknet.com/manjaro/stable/$repo/$arch
    121: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    122: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    123: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    124: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    125: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    126: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    127: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    128: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    129: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    130: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    131: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    132: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 350
  1: cpu: 100% command: ps pid: 21703 mem: 3.68 MiB (0.0%)
  2: cpu: 9.5% command: firefox pid: 20995 mem: 581.3 MiB (1.8%)
  3: cpu: 3.2% command: gnome-shell pid: 20309 mem: 454.4 MiB (1.4%)
  4: cpu: 2.6% command: firefox pid: 21276 mem: 235.1 MiB (0.7%)
  5: cpu: 2.0% command: zsh pid: 21592 mem: 7.84 MiB (0.0%)
  Memory top: 5 of 350
  1: mem: 581.3 MiB (1.8%) command: firefox pid: 20995 cpu: 9.5%
  2: mem: 454.4 MiB (1.4%) command: gnome-shell pid: 20309 cpu: 3.2%
  3: mem: 235.1 MiB (0.7%) command: firefox pid: 21276 cpu: 2.6%
  4: mem: 210.6 MiB (0.6%) command: firefox pid: 21311 cpu: 0.8%
  5: mem: 141.7 MiB (0.4%) command: firefox pid: 21141 cpu: 0.3%
  Processes: 350 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.47 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.36
The main disk is nvme0n1
NAME       FSTYPE   FSVER  LABEL              UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0      squashfs 4.0        0   100% /run/miso/sfs/livefs
loop1      squashfs 4.0        0   100% /run/miso/sfs/mhwdfs
loop2      squashfs 4.0        0   100% /run/miso/sfs/desktopfs
loop3      squashfs 4.0        0   100% /run/miso/sfs/rootfs
sda
└─sda1     ntfs            SDD 500GB          5CD028FCD028DDD0
sdb
└─sdb1     ntfs            SSD 240GB          3816F45B16F41C16
sdc
└─sdc1     ntfs            Arxius 2TB         60A6CCB155D250D7
sdd        iso9660  Joliet MANJARO_GNOME_2420 2024-12-08-02-37-49-00                     0   100% /run/miso/bootmnt
├─sdd1     iso9660  Joliet MANJARO_GNOME_2420 2024-12-08-02-37-49-00
└─sdd2     vfat     FAT12  MISO_EFI           2AB1-D802
nvme1n1
├─nvme1n1p1
└─nvme1n1p2
           ntfs            NVMe 1TB           3E0E309D0E304FDF
nvme0n1
├─nvme0n1p1
├─nvme0n1p2
│          vfat     FAT32                     ECCC-7828
├─nvme0n1p3
│          ntfs                               9428DBD628DBB588
├─nvme0n1p4
│          ntfs                               DA342A0D3429ECE7
├─nvme0n1p5
│          btrfs                              efcf7327-b70a-4194-8cd4-6d749e10920e
└─nvme0n1p6
           vfat     FAT32                     24EB-20C0
What I do
[manjaro-gnome manjaro]# mount /dev/nvme0n1p5 /mnt
[manjaro-gnome manjaro]# mount -o subvol=@ /dev/nvme0n1p5 /mnt
[manjaro-gnome manjaro]# mount /dev/nvme0n1p6 /mnt/boot/efi
[manjaro-gnome manjaro]# manjaro-chroot /mnt /bin/bash
Edited fstab with new partition UUID
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=24EB-20C0                            /boot/efi      vfat    umask=0077 0 2
UUID=efcf7327-b70a-4194-8cd4-6d749e10920e /              btrfs   subvol=/@,defaults,discard=async,ssd 0 0
UUID=efcf7327-b70a-4194-8cd4-6d749e10920e /home          btrfs   subvol=/@home,defaults,discard=async,ssd 0 0
UUID=efcf7327-b70a-4194-8cd4-6d749e10920e /var/cache     btrfs   subvol=/@cache,defaults,discard=async,ssd 0 0
UUID=efcf7327-b70a-4194-8cd4-6d749e10920e /var/log       btrfs   subvol=/@log,defaults,discard=async,ssd 0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
Output when I try to reinstall GRUB
 core is up to date
 extra is up to date
 multilib is up to date
warning: grub-2:2.12-3 is up to date -- reinstalling
resolving dependencies...
Packages (2) thunderbird-128.5.1-1  grub-2:2.12-3
Total Download Size:    61.08 MiB
Total Installed Size:  272.06 MiB
Net Upgrade Size:        0.12 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
 thunderbird-128.5.1-1-x86_64                                                             61.1 MiB  49.8 MiB/s 00:01 [######################################################################] 100%
(2/2) checking keys in keyring        [######################################################################] 100%
(2/2) checking package integrity        [######################################################################] 100%
(2/2) loading package files        [######################################################################] 100%
(2/2) checking for file conflicts        [######################################################################] 100%
(2/2) checking available disk space        [######################################################################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
First run mode (config file not found)
Selected default snapshot type: BTRFS
Using system disk as snapshot device for creating snapshots in BTRFS mode
** (process:64): CRITICAL **: 09:20:37.619: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:64): CRITICAL **: 09:20:37.619: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
** (process:64): CRITICAL **: 09:20:37.621: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:64): CRITICAL **: 09:20:37.621: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
E: Selected snapshot device is not a system disk
E: Select BTRFS system disk with root subvolume (@)
** (process:106): CRITICAL **: 09:20:37.712: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:106): CRITICAL **: 09:20:37.713: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
** (process:106): CRITICAL **: 09:20:37.713: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
Found theme: /usr/share/grub/themes/Elegant-wave-window-left-dark/theme.txt
Found linux image: /boot/vmlinuz-6.11-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.11-x86_64.img
Found initrd fallback image: /boot/initramfs-6.11-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdd1.  Check your device.map.
Detecting snapshots ...
Found snapshot: 2024-11-09 13:04:43 | timeshift-btrfs/snapshots/2024-11-09_13-04-43/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2024-10-28 23:39:24 | timeshift-btrfs/snapshots/2024-10-28_23-39-23/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2024-10-26 18:22:22 | timeshift-btrfs/snapshots/2024-10-26_18-22-22/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found 3 snapshot(s)
Unmount /tmp/grub-btrfs.qblz5NR5DA .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(2/2) Remove Thunderbird Distribution Settings
(1/2) reinstalling grub        [######################################################################] 100%
:: To use the new features provided in this GRUB update, it is recommended
   to install it to the MBR or UEFI. Due to potential configuration
   incompatibilities, it is advised to run both, installation and generation
   of configuration:
     # UEFI: https://wiki.archlinux.org/title/GRUB#Installation
     # BIOS: https://wiki.archlinux.org/title/GRUB#Installation_2
(2/2) upgrading thunderbird        [######################################################################] 100%
(1/6) Arming ConditionNeedsUpdate...
(2/6) Installing Grub to MBR/EFI
WARNING: EFI directory not found! Grub couldn't be installed.
error: command failed to execute correctly
(3/6) Updating icon theme caches...
(4/6) Updating the info directory file...
(5/6) Copy Thunderbird Distribution Settings
(6/6) Updating the desktop file MIME type cache...
Output if I continue with next steps
[manjaro-gnome /]# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
[manjaro-gnome /]# grub-mkconfig -o /boot/grub/grub.cfg
Found 3 snapshot(s)
Unmount /tmp/grub-btrfs.EnLpkQqivu .. Success
done
Thank you very much for your help!
EDIT: yeaahh, write from my Manjaro booted!! :heart_eyes:
