Hello, I resurrected/put back together a Ryzen 3 system on an B350M Gaming Pro mother Board and installed Manjaro on it with XFCE for use as a server.
It’s got a bit older NVIDA card it it as well. It crashes. A lot, to a black screen. Sometimes it reboots, but most time it just hard locks to the point where capslock doesn’t trigger it’s LED on the keyboard.
I’ve tried open source and proprietary drives for the video, looking through the logs as best as I know how, turning off sleep, and hibernation, and even pulled its wifi card, but I’ve yet to find the issue. I also rolled back the kernel, and it’s still happening.
Is there a method of getting crash dumps from a kernel panic? I suspect it’s the motherboard bios, but MSI doesn’t allow a bios rollback and I’ve not discovered a work around if one exists.
It is of course frustrating, because at the moment I see no rhyme or reason to it…and I’ve never seen it happen in real time sadly.
I’m at the point of perhaps moving all my docker containers to another PC, which is frustrating. Even if the PC would just reboot it would be better than a hard lock.
Thanks in advance for any assistance.
Here’s the system info from inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.136-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=e33c020c-78d4-4754-81bc-fae92e7b4a41 rw quiet apparmor=1
security=apparmor resume=UUID=e73fe0e8-3fa2-4b67-9e9a-e90b9a8b4a7f
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7A39 v: 1.0
serial: <superuser required>
Mobo: MSI model: B350M GAMING PRO (MS-7A39) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.P3
date: 07/16/2022
RAM: total: 15.61 GiB used: 6.92 GiB (44.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 3 1300X bits: 64 type: MCP arch: Zen level: v3
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
microcode: 0x8001138
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1593 high: 2058 min/max: 1550/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1496 2: 1388
3: 1433 4: 2058 bogomips: 28010
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
succor svm svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 29:00.0 chip-ID: 10de:1c03
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 29:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 2b:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.10.136-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-1610b3b2c6a7 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: br-1cd8729ecbda state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-276bd3965a26 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-4: br-4c467f11bf01 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-5: br-928dcc537b74 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
all]
IF-ID-6: br-f0fdad466cbb state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
all]
IF-ID-7: br-ff2cb78ee69f state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
all]
IF-ID-8: docker0 state: down mac: <filter>
all]
IF-ID-9: veth000d0a5 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: veth0e45d4b state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: veth1c3c1f7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: veth232c019 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: veth30a49b9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: veth365092f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: veth3d56ccb state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: veth46071c7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: veth4bacc94 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-18: veth550e9e0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-19: veth5cf8b44 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-20: veth7311911 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-21: veth7492f95 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-22: veth8f46d98 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-23: vetha59060a state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-24: vethc9c4bd7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-25: vethd66170e state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-26: vethda21635 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-27: vethdce5480 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-28: vethf244741 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-29: vethf685a98 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Local Storage: total: 931.51 GiB used: 23.79 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD Blue SA510
2.5 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 8100 scheme: GPT
ID-1: / raw-size: 914.12 GiB size: 898.7 GiB (98.31%) used: 23.79 GiB (2.6%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: e33c020c-78d4-4754-81bc-fae92e7b4a41
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: B552-FD79
ID-1: swap-1 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: e73fe0e8-3fa2-4b67-9e9a-e90b9a8b4a7f
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: HP HP Business Slim Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 03f0:2f4a class-ID: 0300
Device-2: 3-2:3 info: Microsoft Ergonomic Mouse type: Mouse,HID
power: 100mA chip-ID: 045e:082e class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 38.5 C mobo: N/A gpu: nvidia temp: 43 C
Processes: 335 Uptime: 59m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: 1132 pm: pacman pkgs: 1129 libs: 319 tools: pamac,yay pm: flatpak
pkgs: 0 pm: snap pkgs: 3 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.21
