Hi, I just woke my machine* from sleep and I got a moving mouse pointer on a bare desktop background, could summon the f2 terminal and login and check journalctl and it was flooded, never have I seen so many messages for one second, I ran out of patience holding down space in order to advance the pages and had to quit journalctl (asked for the last four minutes)
The error messages repeated were
[51291]: Attempting to run a JS callback during garbage collection. This is most likely caused by destroying a Clutter actor or GTK widget with ::destroy signal connected, or using the destroy>
and
The offending callback was SourceFunc().
Which is precisely the same as mentioned here: Goodbye Gnome, Hello Cinnamon - Linux - Level1Techs Forums
I understand that the issue is with one of my Gnome extensions but since I like using these (after having customized my desktop) and don’t know whether this list is in any way “excessive” I’d like to ask if there’s a known issue with either of these extensions?
Else I may be forced to try a different desktop environ.
These are the extensions I currently employ:
ArcMenu
Dash to Panel
AppIndicator and KStatusNotifierItem Support
Pamac Updates Indicator
User Themes
Thanks for any advice
System: Kernel: 5.9.8-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: GNOME 3.38.1 tk: GTK 3.24.23
wm: gnome-shell dm: GDM 3.38.1 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Gigabyte model: B550I AORUS PRO AX v: x.x serial: <filter> UEFI: American Megatrends v: F10
date: 09/18/2020
CPU: Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86276
Speed: 2049 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2073 2: 3952 3: 2195 4: 2195 5: 2078
6: 2195 7: 2195 8: 2196 9: 2095 10: 3708 11: 2059 12: 2195
Graphics: Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ASUSTeK driver: nvidia v: 455.45.01 bus ID: 07:00.0
chip ID: 10de:1f08
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: nvidia resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01 direct render: Yes
Audio: Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 07:00.1
chip ID: 10de:10f9
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 09:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.9.8-2-MANJARO
Network: Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel port: f000 bus ID: 05:00.0
chip ID: 10ec:8125
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000 bus ID: 06:00.0 chip ID: 8086:2723
IF: wlp6s0 state: down mac: <filter>
Drives: Local Storage: total: 1.42 TiB used: 280.65 GiB (19.3%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB speed: 6.0 Gb/s serial: <filter> rev: 2B6Q
scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD5000AACS-00G8B0 size: 465.76 GiB speed: 3.0 Gb/s serial: <filter>
rev: 4C05 scheme: MBR
ID-3: /dev/sdc vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB speed: 6.0 Gb/s serial: <filter> rev: 1B6Q
scheme: GPT
ID-4: /dev/sdd type: USB vendor: Corsair model: Voyager GT 3.0 size: 59.65 GiB serial: <filter> rev: 1.00
Partition: ID-1: / size: 440.22 GiB used: 214.86 GiB (48.8%) fs: ext4 dev: /dev/sda2
Swap: ID-1: swap-1 type: partition size: 17.21 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
Sensors: System Temperatures: cpu: 41.4 C mobo: N/A gpu: nvidia temp: 47 C
Info: Processes: 320 Uptime: 19m Memory: 15.64 GiB used: 2.03 GiB (13.0%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1464 Shell: Zsh v: 5.8 running in: tilix inxi: 3.1.08
