After updating system on my laptop it’s wifi interface stopped working. I’ve already tried to load to a couple of kernels(5.14, 5.12, 5.9) and the issue stays the same so seems that it’s not a kernel problem.
In the logs it says that there is some problem with libnssutil3.so but I’m not expirienced enough to fix it. I’m kidnly asking for an assistence c:
journalctl -b -u NetworkManager
-- Journal begins at Sun 2021-05-23 11:08:16 EEST, ends at Wed 2021-07-21 20:35:56 EEST. --
Jul 21 18:57:52 laptop systemd[1]: Starting Network Manager...
Jul 21 18:57:53 laptop NetworkManager[487]: /usr/bin/NetworkManager: symbol lookup error: /usr/lib/libnssutil3.so: undefined symbol: SEC_ObjectIDTempl>
Jul 21 18:57:53 laptop systemd[1]: NetworkManager.service: Main process exited, code=exited, status=127/n/a
Jul 21 18:57:53 laptop systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
Jul 21 18:57:53 laptop systemd[1]: Failed to start Network Manager.
Jul 21 18:57:53 laptop systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 1.
Jul 21 18:57:53 laptop systemd[1]: Stopped Network Manager.
Jul 21 18:57:53 laptop systemd[1]: Starting Network Manager...
Jul 21 18:57:53 laptop NetworkManager[537]: /usr/bin/NetworkManager: symbol lookup error: /usr/lib/libnssutil3.so: undefined symbol: SEC_ObjectIDTempl>
Jul 21 18:57:53 laptop systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 2.
Jul 21 18:57:53 laptop NetworkManager[643]: /usr/bin/NetworkManager: symbol lookup error: /usr/lib/libnssutil3.so: undefined symbol: SEC_ObjectIDTempl>
Jul 21 18:57:53 laptop systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 3.
Jul 21 18:57:53 laptop NetworkManager[724]: /usr/bin/NetworkManager: symbol lookup error: /usr/lib/libnssutil3.so: undefined symbol: SEC_ObjectIDTempl>
Jul 21 18:57:53 laptop systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 4.
Jul 21 18:57:53 laptop NetworkManager[790]: /usr/bin/NetworkManager: symbol lookup error: /usr/lib/libnssutil3.so: undefined symbol: SEC_ObjectIDTempl>
Jul 21 18:57:54 laptop systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 5.
Jul 21 18:57:54 laptop systemd[1]: Stopped Network Manager.
Jul 21 18:57:54 laptop systemd[1]: NetworkManager.service: Start request repeated too quickly.
Jul 21 18:57:54 laptop systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
Jul 21 18:57:54 laptop systemd[1]: Failed to start Network Manager.
inxi -Fxzc0
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.22.3 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X521IA_M533IA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X521IA v: 1.0 serial: <filter> UEFI: American Megatrends v: X521IA.303 date: 07/31/2020
Battery: ID-1: BAT0 charge: 40.8 Wh (91.7%) condition: 44.5/50.0 Wh (88.9%) volts: 11.9 min: 11.9
model: ASUSTeK ASUS Battery status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP arch: Zen 2 rev: 1 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31949
Speed: 1397 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397
6: 1397 7: 1397 8: 1397
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 03:00.0
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 3-3:3
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.16-1-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.1.5 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 03:00.6
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.32 running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
IF: wlp1s0 state: down mac: <filter>
IF-ID-1: br-93abded52fd8 state: down mac: <filter>
IF-ID-2: br-ff6deb6e1c56 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 299.54 GiB (62.8%)
ID-1: /dev/nvme0n1 vendor: Kingston model: OM8PCP3512F-AB size: 476.94 GiB temp: 28.9 C
Partition: ID-1: / size: 476.74 GiB used: 299.54 GiB (62.8%) fs: f2fs dev: /dev/dm-0
mapped: luks-bff76b85-768a-4955-9bcf-776665a64fb0
ID-2: /boot/efi size: 196.9 MiB used: 474 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 38.5 C mobo: 38.0 C gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 288 Uptime: 21m Memory: 15.07 GiB used: 2.21 GiB (14.7%) Init: systemd Compilers: gcc: 11.1.0
clang: 12.0.1 Packages: 1717 Shell: fish v: 3.3.1 inxi: 3.3.06
