I had Manjaro on my desktop. Last night (Friday) my desktop (with 2x3Tb drives) died. I tried to turn it on and nothing. No light, nothing.
Looks like something happened to the CPU/motherboard.
Took both hard drives out of the computer and I have a SATA external USB toaster. When I tried to mount either of these drives on my laptop I get:
[ 1147.342929] usb 3-3: USB disconnect, device number 4
[ 1147.343593] sd 2:0:0:0: [sdb] Synchronizing SCSI cache
[ 1147.343645] sd 2:0:0:0: [sdb] Synchronize Cache(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 1185.002677] usb 3-3: new SuperSpeed Gen 1 USB device number 5 using xhci_hcd
[ 1185.029620] usb 3-3: New USB device found, idVendor=174c, idProduct=5106, bcdDevice= 0.01
[ 1185.029625] usb 3-3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 1185.029627] usb 3-3: Product: AS2105
[ 1185.029627] usb 3-3: Manufacturer: ASMedia
[ 1185.029628] usb 3-3: SerialNumber: 00000000000000000000
[ 1185.033789] usb 3-3: UAS is blacklisted for this device, using usb-storage instead
[ 1185.033795] usb-storage 3-3:1.0: USB Mass Storage device detected
[ 1185.034258] scsi host2: usb-storage 3-3:1.0
[ 1186.039831] scsi 2:0:0:0: Direct-Access ASMT 2105 0 PQ: 0 ANSI: 6
[ 1186.040290] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 1194.951738] sd 2:0:0:0: [sdb] 732566646 4096-byte logical blocks: (3.00 TB/2.73 TiB)
[ 1194.952290] sd 2:0:0:0: [sdb] Write Protect is off
[ 1194.952292] sd 2:0:0:0: [sdb] Mode Sense: 43 00 00 00
[ 1194.952821] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1194.993833] sd 2:0:0:0: [sdb] Attached SCSI disk
and fdisk -l /dev/sdb gives
Disk /dev/sdb: 2.7 TiB, 3000592982016 bytes, 732566646 sectors
Disk model: 2105
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sdb1 1 4294967295 4294967295 16T ee GPT
Same for both drives.
When I use some other drives (include a 4Tb) on the sata USB toaster, it works.
gparted reports no partition table. How can I recover the partition table?
Thanks
