Hello all.
I got a problem with Manjaro 22 Silkaris.
My os crashes sometimes, and I don’t understand why.
The screen turns black and the fans start turning really fast, at 100% of their capacities.
My hardware is :
MSI B550
Rysen 5800X
Ram 32Go DDr4
Manjaro runing on a SSD.
Nvidia RTX 2060 EVO
Do you have any idea why these crash happens ?
Thanks.
TriMoon
November 28, 2022, 1:42pm
2
It could be related to what you are doing at that moment.
No one can help with random crashes unless you help them understand WHEN it happens…
so please be as verbose as you can, like i was doing this then i did that and this hapened…
Plus ofcourse: How to provide good information
Okay, thanks.
Last time it happens I was watching a movie using Stremio and the screen turned black, fans turning 100% but there were still sound.
The first time it happens I don’t remember what I was doing, I think I just left the computer idling, I just left my room and when I came back I found it with black screen and fans turning.
I’m gonna try to install the official nvidia driver, maybe it’ll helps.
can you provide from terminal
inxi -Fza
sensors
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4f6e9318-4b89-4973-8ef0-7d4b30ec6adf rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.80
date: 12/30/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3102 high: 3738 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3576 2: 3359
3: 3198 4: 2877 5: 2880 6: 2919 7: 2878 8: 2879 9: 3532 10: 3738 11: 2963
12: 2880 13: 2306 14: 3619 15: 2879 16: 3151 bogomips: 121647
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 2b:00.0 chip-ID: 10de:1f08 class-ID: 0300
Device-2: Microdia Webcam Vitade AF type: USB driver: uvcvideo
bus-ID: 5-3:2 chip-ID: 0c45:6366 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
bus-ID: 2b:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.05 TiB used: 27.12 GiB (1.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZRX-00A8LB0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 27.12 GiB (11.9%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34
used: 312 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
System Temperatures: cpu: 57.8 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 372 Uptime: 47m wakeups: 0 Memory: 31.27 GiB
used: 6.13 GiB (19.6%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1358
pm: pacman pkgs: 1354 libs: 383 tools: pamac pm: flatpak pkgs: 4 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
~ sensors ✔
k10temp-pci-00c3
Adapter: PCI adapter
Tctl: +60.0°C
Tccd1: +47.2°C
Anyway since I installed the Nvidia non-free drivers, it works like a sharm
you have a high temp inside your desktop : more than 50°C
add kernel 6.0
sudo mhwd-kernel -i linux60
redo after
sudo sensors-detect
can you add thes parameters on boot kernel
in /etc/default/grub
on line GRUB_CMDLINE_LINUX_DEFAULT=
sudo nano /etc/default/grub
sudo update-grub
amd_iommu=on iommu=pt processor.max_cstate=5 amd_pstate.shared_mem=1 systemd.unified_cgroup_hierarchy=true"
see this for amd pstate ( with kernel 6.0 or more )
It does not work.
❯ sudo cpupower frequency-info
analyzing CPU 0:
no or unknown cpufreq driver is active on this CPU
Does it work for you?
