Crash where OS and programs inside of Monitor 1 become unresponsive, but monitor 2 remains totally unaffected
Having a crash i can’t figure out. I’m usually playing a game when this happens; the game will freeze leading to my whole primary monitor becoming completely frozen and unresponsive, however, my second monitor remains totally fine and responsive. Using steam to close the game seems to do the trick, however it seems to be happening more and more with multiple games. I’m thinking it must be a KDE thing, but I’m unsure at this point.
I’ve had a look through the logs the last several times this has happened and nothing stands out to me. Would really appreciate any help as this has happened as often as twice within a day so far.
Password for privatebin.io for journal logs is: “manjarohelpers”
Hello and welcome to the Manjaro Community! :wave:
It will be helpful if you include your inxi output; we always ask for this on support topics as e.g. we’ll know if you are using Wayland or x11 (this might make the difference):
inxi -zv8
Note: The output is filtered for privacy when using this command.
Paste between three backticks ``` or three tildes ~~~, on their own lines above and below the pasted text, like this:
Pasted text from the Terminal
… as this formats the output for the Forum.
It’s also important you select all the text from the Terminal (inclusive of the command) as it’s easy to miss some.
Cheers! :wink:
Hey thanks, and thanks for the advice. I’ve used the inxi -zv8 command and the output is as follows:
  inxi -zv8
  Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=dbfe8f95-47ef-4ece-a136-20ad0800a4e9 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
  Type: Desktop Mobo: Gigabyte model: B450M S2H serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: F67b
    date: 07/11/2024
  System RAM: total: 32 GiB available: 31.27 GiB used: 3.76 GiB (12.0%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK32GX4M2E3200C16 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
    desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3826 min/max: 550/4208 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3826 2: 3826 3: 3826
    4: 3826 5: 3826 6: 3826 7: 3826 8: 3826 9: 3826 10: 3826 11: 3826 12: 3826
    bogomips: 86273
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
    XT/6600M] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1
    empty: DP-2,DP-3,Writeback-1 bus-ID: 0c:00.0 chip-ID: 1002:73ff
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right model: HP 25x
    serial: <filter> built: 2020 res: N/A dpi: 90 gamma: 1.2 chroma: red:
    x: 0.655 y: 0.333 green: x: 0.325 y: 0.627 blue: x: 0.157 y: 0.075 white:
    x: 0.314 y: 0.329 size: 544x303mm (21.42x11.93") diag: 623mm (24.5")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900,
    1280x800, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: left model: Acer K242HYL
    serial: <filter> built: 2020 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 93 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green: x: 0.318 y: 0.624
    blue: x: 0.153 y: 0.078 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
    LLVM 19.1.7 DRM 3.61 6.12.28-1-MANJARO) device-ID: 1002:73ff
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 25.0.5-arch1.1
    device-ID: 1002:73ff surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 0c:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Blue Microphones
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 046d:0ab7 class-ID: 0300
    serial: <filter>
  Device-4: Texas Instruments ATH-G1WL
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 0451:16ba class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
    chip-ID: 10ec:818b class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
    lanes: 1 port: d000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: vincent state: unknown speed: N/A duplex: N/A mac: N/A
  Device-1: Broadcom BCM20702A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0a5c:21e8
  Local Storage: total: 2.05 TiB used: 35.21 GiB (1.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
    model: WDC WDS250G1B0C-00S6U0 size: 232.89 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 201000WD temp: 28.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
    tech: SSD serial: <filter> fw-rev: 061 scheme: GPT
  ID-1: / raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
    used: 35.21 GiB (15.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: dbfe8f95-47ef-4ece-a136-20ad0800a4e9
    used: 616 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 423B-DDBC
  ID-3: /home raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
  ID-4: /var/cache raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
  ID-5: /var/log raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
  ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: StorageHDD
    uuid: 887ED06D7ED05592
  ID-2: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ext4 label: N/A
    uuid: b27ea83a-d96e-4d65-84f7-84f10c17399f
  Device-1: 1-3:2 info: Logitech Blue Microphones type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    chip-ID: 046d:0ab7 class-ID: 0300 serial: <filter>
  Device-2: 1-4:3 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
  Device-1: 3-1:2 info: BigBen Interactive PC Compact Controller
    type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0
    chip-ID: 146b:0603 class-ID: ff00 serial: <filter>
  Device-2: 3-2:3 info: Texas Instruments ATH-G1WL type: audio,HID
    chip-ID: 0451:16ba class-ID: 0300 serial: <filter>
  Device-3: 3-3:4 info: SteelSeries ApS Apex 5 type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1038:161c class-ID: 0300
  Device-4: 3-4:5 info: Razer USA Basilisk V3 type: mouse,keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0099 class-ID: 0300
  System Temperatures: cpu: 41.2 C mobo: 21.0 C gpu: amdgpu temp: 28.0 C
    mem: 20.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: pm: pacman pkgs: 1412 libs: 420 tools: pamac pm: flatpak pkgs: 0
    1: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    4: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    5: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    6: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    7: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    8: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 405
  1: cpu: 37.4% command: firefox pid: 2367 mem: 464.6 MiB (1.4%)
  2: cpu: 33.5% command: exe pid: 1828 mem: 512.5 MiB (1.6%)
  3: cpu: 28.1% command: steamwebhelper pid: 3336 mem: 235.2 MiB (0.7%)
  4: cpu: 24.5% command: steamwebhelper pid: 2550 mem: 506.0 MiB (1.5%)
  5: cpu: 12.8% command: steamwebhelper pid: 2324 mem: 194.4 MiB (0.6%)
  Memory top: 5 of 405
  1: mem: 512.5 MiB (1.6%) command: exe pid: 1828 cpu: 33.5%
  2: mem: 506.0 MiB (1.5%) command: steamwebhelper pid: 2550 cpu: 24.5%
  3: mem: 464.6 MiB (1.4%) command: firefox pid: 2367 cpu: 37.4%
  4: mem: 437.8 MiB (1.3%) command: plasmashell pid: 1148 cpu: 12.2%
  5: mem: 365.3 MiB (1.1%) command: ./steamwebhelper pid: 2300 cpu: 10.0%
  Processes: 405 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.38
Does the problem also occur in a Plasma Wayland session?
You can change your Plasma session from X11 to Wayland by selecting the session type at the login screen (Wayland is the default for Plasma).
If you have set up autologin to skip the password screen, you can change to a Wayland session by opening System Settings → Colors & Themes → Login Screen (SDDM) → Behavior.
I haven’t tried Wayland yet, but I’ve been meaning to. I’ll use Wayland for a couple of days and if it occurs I will let you know.
Wayland received many multiscreen features and fixes, while X11 bugs are now being marked with “X11-only” on KDE bug tracker, they are filtered to be closed as “RESOLVED UNMAINTAINED” when they remove support for the X11 session.
Nate Graham
The reality is that Plasma’s X support is on life support, and most X11-specific bugs will never be fixed. I’m just being honest with you here rather than stringing you along by pretending that something might happen when it won’t.
