laosom
14 February 2022 14:52
1
Hi,
I have an Nvidia GTX 1650 with display port, running Manjaro KDE Plasma 5.23.5
Kernel 5.15 LTS, Nvidia diver 510.47.03.
I experience freezes after resume from suspend since the driver reached version 470.94 and newer.
Can you advise what is buggy here ?
Nvidia bug report here
https://drive.google.com/file/d/1J5H98DwlcWg2Ld92moTHER0i1X9e-1c2/view?usp=sharing
laosom
14 February 2022 14:54
2
Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=09220bf5-ce61-4336-8683-50ea73ed5429 rw quiet apparmor=1
security=apparmor resume=UUID=f8ebcad0-8528-48c4-ba5c-9c79bbc26781
udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: LENOVO product: 10A6S0W703 v: ThinkCentre M93p
serial: <superuser required>
Mobo: LENOVO model: SHARKBAY v: 0B98401 WIN serial: <superuser required>
UEFI: LENOVO v: FBKTDEAUS date: 06/16/2020
RAM: total: 7.69 GiB used: 4.12 GiB (53.6%)
RAM Report:
Info: model: Intel Core i5-4440 bits: 64 type: MCP arch: Haswell family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 2883 high: 3108 min/max: 800/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2705 2: 3108 3: 3046
4: 2676 bogomips: 24753
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 510.47.03
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f82
class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1280x1024 s-dpi: 85 s-size: 382x302mm (15.0x11.9")
s-diag: 487mm (19.2")
Monitor-1: DP-0 res: 1280x1024 hz: 60 dpi: 86 size: 376x301mm (14.8x11.9")
diag: 482mm (19")
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Ethernet I217-LM vendor: Lenovo driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Local Storage: total: 3.3 TiB used: 2.37 TiB (71.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000AAKX-75U6AA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1H19
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Z400s 2.5 7MM 128GB
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 9012 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba
model: External USB 3.0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 5438 scheme: GPT
Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7240S rev: 1.02
dev-links: cdrom
ID-1: / raw-size: 110.15 GiB size: 107.92 GiB (97.98%)
used: 62.19 GiB (57.6%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 09220bf5-ce61-4336-8683-50ea73ed5429
used: 284 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 23CC-A430
ID-5: /run/timeshift/backup raw-size: 50.75 GiB size: 49.71 GiB (97.94%)
used: 42.1 GiB (84.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 5c1629a1-aecf-4ef7-a386-718a3c625116
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 2.5 MiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: f8ebcad0-8528-48c4-ba5c-9c79bbc26781
ID-1: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 15 rev: 2.0
Device-1: 3-3:3 info: Logitech Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 046d:c045 class-ID: 0301
Device-2: 3-4:4 info: Monterey Keyboard type: Keyboard,HID
power: 100mA chip-ID: 0566:3002 class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Device-1: 4-1:2 info: Toshiba America Canvio Basics HDD type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0480:a202 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 50%
Processes: 249 Uptime: 5h 36m wakeups: 15 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1550
lib: 446 flatpak: 0 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
Hi @laosom ,
Than you for this. Do me and everyone trying to be of assistance a solid please. When you provide terminal output, please wrap the pasted text in three backticks, before and after the pasted text. Like this:
pasted text
A metus commodo
maecenas
diam enim condimentum
commodo felis sed
eget id orci mi accumsan.
instead of like this:
A metus commodo maecenas diam enim condimentum commodo felis sed eget id orci mi accumsan.
Thereby improving legibility and making it easier for those trying to be of assistance. Do me the mentioned solid and edit your post accordingly, please.
laosom
14 February 2022 18:10
4
Hi,
Thanks for the hint. Is this OK now ?
Unfortunately not. Those look like single-quotes, while I meant backticks, a.k.a. grave accent, a.k.a. somethingThatICant’tRememberanow.
laosom
14 February 2022 18:49
6
Sorry, my bad , “backticks” not dots .
Should be OK now.
