Crash - help me isolate the issue with journalctl
This is possibly due to a recent known issue::
Please see the items listed under Known issues and solutions of Stable Update 2024-10-10.
Specifically, look for the following heading:
  • KDE Plasma hangs on Shutdown, Restart and Logout
To save you having to search too much, the workaround is to change your session settings:
System SettingsSessionDesktop SessionSession Restore:
Change “On login, launch apps that were open” to:
  • Start with an empty session
Naturally, you might then need to reboot.
thank you so much, I’m going to try that later on. (I will use also a different USB stick in case it’s faulty for the installer)
Instead of creating another Manjaro Installer USB,
consider creating a Ventoy USB:
Ventoy USB
Boot with a Ventoy USB, and ISO files are automatically listed in the Ventoy menu, and can be booted directly. A 32GB capacity USB should allow ample space to store several ISOs of your choice; an 8GB capacity USB might hold one, or two ISO’s; do the math.
Ventoy is available from the official Manjaro extra repository:
sudo pacman -S ventoy
Ventoy usage:
Usage:  Ventoy2Disk.sh CMD [ OPTION ] /dev/sdX
 CMD:
  -i  install Ventoy to sdX (fails if disk already installed with Ventoy)
  -I  force install Ventoy to sdX (no matter if installed or not)
  -u  update Ventoy in sdX
  -l  list Ventoy information in sdX
 OPTION: (optional)
  -r SIZE_MB  preserve some space at the bottom of the disk (only for install)
  -s/-S       enable/disable secure boot support (default is enabled)
  -g          use GPT partition style, default is MBR (only for install)
  -L          Label of the 1st exfat partition (default is Ventoy)
  -n          try non-destructive installation (only for install)
Creating the Ventoy USB:
Write the Ventoy system to an empty USB drive;
use /dev/sdX to target the device itself, and not a partition:
I use this command to create a Ventoy USB in UEFI mode;
Change it as needed to suit your environment:
sudo sh ventoy -i -r 100 -S -g -L VOLUME /dev/sdX
  • Enable -s or disable -S Secure Boot.
  • Substitute VOLUME for a volume label name to use.
  • Substitute /dev/sdX for the location of your USB device.
  • Preserve some space on the target device (example allows 100mb).
Updating the Ventoy USB:
Update the Ventoy system on an existing Ventoy USB;
ensure the updated Ventoy version is available in Manjaro; and then:
sudo ventoy -u /dev/sdX
  • The Ventoy USB update process is non-destructive.
See also: Ventoy (GitHub);
Thanks a lot. I changed the session restore settings and it made the system more stable (I used to get a crash right after opening a session, that’s not happening anymore). I can use the computer for 30min without any issues but usually then I get a crash all of a sudden. Also when I reboot the computer, the system regularly freezes after I inserted my password. I’m taking the computer to a specialist tomorrow for him to check the SSD. I also read that plasma 6.1 was quite unstable so that could be the issue. To be continued…
Ok so the SSD had an issue, it was running at 150 degrees which was triggering the crash. I got someone to change the SSD and now when I install Manjaro, I get a new type of error during the installation saying "failed to unpack image “/run/miso/bootmnt/manjaro/x86_64/rootfs.xfs” and below “rsync failed with error code 10”. Maybe there was an error when the image was created. I will try to redo the image on the usb stick or use Ventoy.
I gave up trying to install Manjaro and also Ubuntu. I was finally able to install Endeavour OS (which I don’t think I can use as a daily driver) and ended up with OpenSuse Tumbleweed.
It seems whatever caused the OP’s crashes remains unknown, and now, will likely never find a solution; at least, not here.
I dare say, it’s time for some close closure.
