I’m having cracking noises in my earphones after waking my laptop up from sleep. It doesn’t happen after a fresh reboot. I can also fix it by restarting pipewire
. Anyone has any idea how to fix it?
inxi -Fazy
Kernel: 5.12.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=fe64fafd-1c2a-4b55-846f-c264196ff166 rw nomce "acpi_osi=Windows
2018" quiet resume=UUID=4517ac81-4ac6-42a0-8e7a-a5870b5f98df
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Laptop 14-bf1xx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 83CE v: 59.38 serial: <filter> UEFI: Insyde v: F.31
date: 10/30/2017
ID-1: BAT1 charge: 42.3 Wh (100.0%) condition: 42.3/42.3 Wh (100.0%)
volts: 13.2 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Full
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 32012
Speed: 800 MHz min/max: 400/1800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
driver: nvidia v: 460.80 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:134d class-ID: 0302
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 04f2:b5d6 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 115 s-size: 424x238mm (16.7x9.4")
s-diag: 486mm (19.1")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.12.2-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.28 running: yes
vendor: Hewlett-Packard driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
IF-ID-1: br-ab1ab553cc42 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth06c2a6a state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: veth58f54c6 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: vethc7b1d77 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
bus-ID: 1-4:3 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.03 TiB used: 607.12 GiB (57.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
rotation: 5400 rpm serial: <filter> rev: RSM7 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SD8SN8U-128G-1006
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 0006 scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.72 GiB (97.43%) used: 34.47 GiB (70.8%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21
ID-2: /boot/efi raw-size: 277 MiB size: 276.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 60.87 GiB size: 59.67 GiB (98.02%)
used: 29.38 GiB (49.2%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
Kernel: swappiness: 1 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.1 GiB used: 99.2 MiB (1.2%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 41.5 C mobo: 29.8 C
Processes: 355 Uptime: 2h 28m wakeups: 7 Memory: 7.69 GiB
used: 5.63 GiB (73.3%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: 1866 pacman: 1865 lib: 436 flatpak: 1
Shell: fish v: 3.2.2 running-in: tmux: inxi: 3.3.04
