CPU usage doesn't match
CPU total about 30-40%, but in program list about 5-10%. What is the problem?
check with htop
It could be that KDE’s System Monitor only shows you user-run GUI applications, while hiding background and root/system processes.
This might be why adding up all the “Applications” doesn’t account for 30-40% CPU usage.
The culprit for such a high CPU use might be Xorg or plasmashell
The Overview tab only lists graphical applications opened by the user. Use the Processes tab for the complete list.
