this has been a problem since i switched from pop_os and linux mint, they both worked perfectly fine, had no issues with hardware and stuff, but after i switched to Manjaro, and i think i did everything as it should be done on instalation, as i followed a whole lot of tutorials so i dont f anything up, Manjaro keeps getting me to even 100% CPU for no reason, as shown in the photo
Run htop and see what is causing the CPU usage. Probably baloo is indexing.
ksysguard is now showing lower cpu usage while htop shows 50% using only ksysguard
50% continuously on all cores?
yes, now after a restart its at 1%, but as soon as i open browser, games, even discord or steam, it just goes very high, i never had this problem before manjaro
Yeah but it doesn’t stay that high, only when you start the program right? That’s normal
i don’t feel like its normal, as i said, never had this issue with other linux distros or windows, my ram and gpu is perfectly fine, only cpu going way higher than it should, 100% sometimes for something as simple as a browser or just looking at some videos
can you return
inxi -Fza --no-host
top ( or htop order by %cpu )
i dont know how to copy the results, but currently its showing 150% cpu usage when runing a youtube video on 1080p60fps
could it be a browser issue? im using whale
Just copy the output with your mouse and paste it here in between three backticks ```
It houldnt go over 100%
1 [||||||||||||||||||||||||||||| 30.9%] 4 [|||||||||||||||||||||||||||||||| 34.6%]
2 [||||||||||||||||||||||||||| 29.1%] 5 [|||||||||||||||||||||||||||||||||||| 38.5%]
3 [|||||||||||||||||||||||||||||||||||||||||||||||| 51.0%] 6 [|||||||||||||||||||||||||||||| 32.0%]
Mem[|||||||||||||||||||||||||||||||||| 1.60G/7.72G] Tasks: 86, 304 thr; 3 running
Swp[ 0K/8.80G] Load average: 0.89 1.20 0.74
Uptime: 00:15:28
PID USER PRI NI VIRT RES SHR S CPU% MEM% TIME+ Command
4949 fernbache 20 0 8871M 326M 142M R 95.5 4.1 0:15.94 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
1645 fernbache 20 0 627M 243M 103M S 42.6 3.1 2:30.42 /opt/naver/whale/whale --type=gpu-process --field-trial-handle=4476197296163416587,7773840901010453318,131072 --enable-crash-reporter=, -
1614 fernbache 20 0 738M 231M 143M S 27.1 2.9 1:22.93 /opt/naver/whale/whale
816 fernbache 20 0 2908M 117M 94336 S 14.2 1.5 1:18.05 /usr/bin/kwin_x11
1675 fernbache 20 0 627M 243M 103M S 8.4 3.1 0:36.70 /opt/naver/whale/whale --type=gpu-process --field-trial-handle=4476197296163416587,7773840901010453318,131072 --enable-crash-reporter=, -
578 root 20 0 122M 72824 47860 R 11.0 0.9 0:55.40 /usr/lib/Xorg -nolisten tcp -auth /var/run/sddm/{f98feab2-2a41-4e27-bd55-978de0d5e794} -background none -noreset -displayfd 17 -seat seat
1641 fernbache 20 0 738M 231M 143M S 9.7 2.9 0:13.06 /opt/naver/whale/whale
1649 fernbache 20 0 358M 96408 65828 S 0.0 1.2 0:16.19 /opt/naver/whale/whale --type=utility --field-trial-handle=4476197296163416587,7773840901010453318,131072 --lang=en-US --service-sandbox-
6135 fernbache 20 0 8871M 326M 142M S 2.6 4.1 0:00.60 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
6130 fernbache 20 0 8871M 326M 142M S 5.2 4.1 0:00.63 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
1633 fernbache 20 0 738M 231M 143M S 5.2 2.9 0:19.33 /opt/naver/whale/whale
1654 fernbache 20 0 358M 96408 65828 S 0.0 1.2 0:12.93 /opt/naver/whale/whale --type=utility --field-trial-handle=4476197296163416587,7773840901010453318,131072 --lang=en-US --service-sandbox-
6132 fernbache 20 0 8871M 326M 142M S 4.5 4.1 0:00.53 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
6133 fernbache 20 0 8871M 326M 142M S 3.9 4.1 0:00.53 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
6126 fernbache 20 0 8871M 326M 142M S 3.9 4.1 0:00.51 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
1728 fernbache 20 0 627M 243M 103M S 4.5 3.1 0:24.96 /opt/naver/whale/whale --type=gpu-process --field-trial-handle=4476197296163416587,7773840901010453318,131072 --enable-crash-reporter=, -
4952 fernbache 20 0 8871M 326M 142M S 3.9 4.1 0:00.72 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
6134 fernbache 20 0 8871M 326M 142M S 3.9 4.1 0:00.53 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
6131 fernbache 20 0 8871M 326M 142M S 3.9 4.1 0:00.53 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
6129 fernbache 20 0 8871M 326M 142M S 3.2 4.1 0:00.51 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
6128 fernbache 20 0 8871M 326M 142M S 4.5 4.1 0:00.53 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
6127 fernbache 20 0 8871M 326M 142M S 4.5 4.1 0:00.54 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
932 fernbache 9 -11 1182M 13600 9776 S 3.9 0.2 0:06.45 /usr/bin/pulseaudio --daemonize=no --log-target=journal
6118 fernbache 20 0 8871M 326M 142M S 3.9 4.1 0:00.42 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
1673 fernbache 20 0 627M 243M 103M S 4.5 3.1 0:13.04 /opt/naver/whale/whale --type=gpu-process --field-trial-handle=4476197296163416587,7773840901010453318,131072 --enable-crash-reporter=, -
4956 fernbache 20 0 8871M 326M 142M S 3.2 4.1 0:00.21 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
6105 fernbache 20 0 8871M 326M 142M S 28.4 4.1 0:00.64 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
1679 fernbache 20 0 4549M 129M 99904 S 0.0 1.6 0:04.20 /opt/naver/whale/whale --type=renderer --disable-webrtc-apm-in-audio-service --field-trial-handle=4476197296163416587,7773840901010453318
818 fernbache 20 0 2908M 117M 94336 S 2.6 1.5 0:12.14 /usr/bin/kwin_x11
6041 fernbache 20 0 620M 81328 67484 S 3.9 1.0 0:00.72 /usr/bin/konsole -qwindowtitle Htop -qwindowicon htop -e /usr/bin/htop
1038 fernbache -6 0 1182M 13600 9776 S 1.9 0.2 0:03.25 /usr/bin/pulseaudio --daemonize=no --log-target=journal
F1Help F2Setup F3Search F4Filter F5Tree F6SortByF7Nice - F8Nice + F9Kill F10Quit
Mod note: I have edited your post for legibility. Please enclose any terminal output between two lines of three backticks (`) each.
No give us the output of inxi --full --admin --verbosity=7 --filter --no-host
says i got links in my posts when doing a paste here… sorry for being a complete noob, im new to linux, its just manjaro thats f’ing with my cpu, and i dont wanna switch cuz i love it
There are no links in the output of
From the output of htop I can see the CPU usage is about 35% on all cores mostly because of whale which I’m guessing is the whale-browser?
yes. i did some reinstalling of browser, switched to midori, and its alot lower cpu usage on videos, still not happy with the way my cpu is performing, it was way better before manjaro
When I play a video in firefox with my integrated GPU and i5 processor the CPU usage is also about 30%
I wouldn’t worry about it.
