Hello! I’m having a small issue with my laptop. When I remove the charger it runs up to 800 Mhz, I would like to increase this frequency however I don’t know how.
Here’s my inxi -Fza
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=759c5942-a42f-4370-bfe8-fa4cfa3281e8 rw quiet splash apparmor=1
security=apparmor resume=UUID=781fe0ae-7244-4c2d-b4e0-3ef218bf3d2a
udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: LENOVO product: 81UH v: Lenovo Legion Y740-15IRHg
serial: <filter> Chassis: type: 10 v: Lenovo Legion Y740-15IRHg
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
UEFI-[Legacy]: LENOVO v: BVCN11WW(V1.07) date: 07/04/2019
ID-1: BAT1 charge: 31.9 Wh (77.4%) condition: 41.2/57.4 Wh (71.8%)
volts: 12.4 min: 11.6 model: Celxpert L17C3PG2 type: Li-ion
serial: <filter> status: Charging
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE cache: L2: 12 MiB
bogomips: 62431
Speed: 4385 MHz min/max: 1692/4500 MHz Core speeds (MHz): 1: 4385 2: 4345
3: 4392 4: 4399 5: 4304 6: 4317 7: 4349 8: 4401 9: 4379 10: 4371 11: 4400
12: 4398
Type: l1tf
Device-1: NVIDIA TU106BM [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f51 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-7:4 chip-ID: 04f2:b604 class-ID: 0e02
serial: <filter>
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Intel Wireless-AC 9560 [Jefferson Peak]
vendor: Rivet Networks Killer driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 3f:00.0
IF: enp63s0 state: down mac: <filter>
IF-ID-1: br-3f3ff8afd4bd state: down mac: <filter>
IF-ID-2: br-ad25f982d2b0 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-afc1b131f59a state: down mac: <filter>
IF-ID-4: br-c630f90ded27 state: down mac: <filter>
IF-ID-5: docker0 state: down mac: <filter>
IF-ID-6: veth8959124 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: veth9413bb4 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: vethb692579 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 154.16 GiB (16.2%)
model: MZVLB1T0HALR-000L2 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 5L1QEXA7 temp: 33.9 C scheme: MBR
ID-1: / raw-size: 919.45 GiB size: 904.02 GiB (98.32%)
used: 154.16 GiB (17.1%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 34.41 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 57.0 C mobo: N/A gpu: nvidia temp: 53 C
Processes: 348 Uptime: 2h 24m wakeups: 9 Memory: 31.28 GiB
used: 4.74 GiB (15.1%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: 1523 pacman: 1516 lib: 446 flatpak: 0 snap: 7
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04
And my sudo cpupower frequency-info
analyzing CPU 0:
driver: intel_pstate
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: Cannot determine or is not supported.
hardware limits: 800 MHz - 4.50 GHz
available cpufreq governors: performance powersave
current policy: frequency should be within 1.69 GHz and 4.50 GHz.
The governor "performance" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 800 MHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
I’ve tried with cpupower-gui, however, I haven’t been able to modify the frequency
Any help is appreciated
