19/04/2022 22:08 kernel amdgpu 0000:29:00.0: [drm] fb0: amdgpudrmfb frame buffer device
19/04/2022 22:08 systemd Mounted /boot/efi.
19/04/2022 22:08 systemd Reached target Local File Systems.
19/04/2022 22:08 systemd Rebuild Dynamic Linker Cache was skipped because all trigger condition checks failed.
19/04/2022 22:08 systemd Starting Set Up Additional Binary Formats...
19/04/2022 22:08 systemd Store a System Token in an EFI Variable was skipped because of a failed condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderFeatures-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
19/04/2022 22:08 systemd Commit a transient machine-id on disk was skipped because of a failed condition check (ConditionPathIsMountPoint=/etc/machine-id).
19/04/2022 22:08 systemd Starting Create Volatile Files and Directories...
19/04/2022 22:08 systemd proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 504 (systemd-binfmt)
19/04/2022 22:08 systemd Mounting Arbitrary Executable File Formats File System...
19/04/2022 22:08 kernel intel_rapl_common: Found RAPL domain package
19/04/2022 22:08 kernel intel_rapl_common: Found RAPL domain core
19/04/2022 22:08 systemd Mounted Arbitrary Executable File Formats File System.
19/04/2022 22:08 systemd Finished Set Up Additional Binary Formats.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
19/04/2022 22:08 kernel amdgpu 0000:29:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
19/04/2022 22:08 kernel [drm] Initialized amdgpu 3.44.0 20150101 for 0000:29:00.0 on minor 0
19/04/2022 22:08 systemd Finished Create Volatile Files and Directories.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Rebuild Journal Catalog was skipped because of a failed condition check (ConditionNeedsUpdate=/var).
19/04/2022 22:08 audit BPF prog-id=9 op=LOAD
19/04/2022 22:08 systemd Starting Network Time Synchronization...
19/04/2022 22:08 systemd Update is Completed was skipped because all trigger condition checks failed.
19/04/2022 22:08 systemd Starting Record System Boot/Shutdown in UTMP...
19/04/2022 22:08 audit SYSTEM_BOOT pid=508 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Finished Record System Boot/Shutdown in UTMP.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Created slice Slice /system/systemd-backlight.
19/04/2022 22:08 systemd Starting Load/Save Screen Backlight Brightness of backlight:acpi_video0...
19/04/2022 22:08 systemd Started Network Time Synchronization.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Reached target System Time Set.
19/04/2022 22:08 systemd Finished Load/Save Screen Backlight Brightness of backlight:acpi_video0.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:acpi_video0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Reached target System Initialization.
19/04/2022 22:08 systemd Started CUPS Scheduler.
19/04/2022 22:08 systemd Started Daily rotation of log files.
19/04/2022 22:08 systemd Started Daily man-db regeneration.
19/04/2022 22:08 systemd Started Monthly clean packages cache.
19/04/2022 22:08 systemd Started Generate mirrorlist weekly.
19/04/2022 22:08 systemd Started pkgfile database update timer.
19/04/2022 22:08 systemd Started Daily verification of password and group files.
19/04/2022 22:08 systemd Started Daily Cleanup of Temporary Directories.
19/04/2022 22:08 systemd Reached target Path Units.
19/04/2022 22:08 systemd Reached target Timer Units.
19/04/2022 22:08 systemd Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
19/04/2022 22:08 systemd Listening on CUPS Scheduler.
19/04/2022 22:08 systemd Listening on D-Bus System Message Bus Socket.
19/04/2022 22:08 systemd Listening on Libvirt local socket.
19/04/2022 22:08 systemd Listening on Libvirt admin socket.
19/04/2022 22:08 systemd Listening on Libvirt local read-only socket.
19/04/2022 22:08 systemd Starting Socket activation for snappy daemon...
19/04/2022 22:08 systemd Listening on Virtual machine lock manager socket.
19/04/2022 22:08 systemd Listening on Virtual machine log manager socket.
19/04/2022 22:08 systemd Listening on Socket activation for snappy daemon.
19/04/2022 22:08 systemd Reached target Socket Units.
19/04/2022 22:08 systemd Reached target Basic System.
19/04/2022 22:08 systemd Starting Save/Restore Sound Card State...
19/04/2022 22:08 systemd Manage Sound Card State (restore and store) was skipped because of a failed condition check (ConditionPathExists=/etc/alsa/state-daemon.conf).
19/04/2022 22:08 systemd Starting Avahi mDNS/DNS-SD Stack...
19/04/2022 22:08 systemd Started Periodic Command Scheduler.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Starting D-Bus System Message Bus...
19/04/2022 22:08 crond (CRON) STARTUP (1.6.0)
19/04/2022 22:08 crond (CRON) INFO (Syslog will be used instead of sendmail.)
19/04/2022 22:08 crond (CRON) INFO (RANDOM_DELAY will be scaled with factor 62% if used.)
19/04/2022 22:08 crond (CRON) INFO (running with inotify support)
19/04/2022 22:08 systemd Starting Initialize hardware monitoring sensors...
19/04/2022 22:08 systemd Starting Authorization Manager...
19/04/2022 22:08 systemd Starting Snap Daemon...
19/04/2022 22:08 audit BPF prog-id=10 op=LOAD
19/04/2022 22:08 audit BPF prog-id=11 op=LOAD
19/04/2022 22:08 audit BPF prog-id=12 op=LOAD
19/04/2022 22:08 systemd Starting User Login Management...
19/04/2022 22:08 audit BPF prog-id=13 op=LOAD
19/04/2022 22:08 audit BPF prog-id=14 op=LOAD
19/04/2022 22:08 systemd Starting Virtual Machine and Container Registration Service...
19/04/2022 22:08 systemd Finished Save/Restore Sound Card State.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Reached target Sound Card.
19/04/2022 22:08 avahi-daemon Found user 'avahi' (UID 971) and group 'avahi' (GID 971).
19/04/2022 22:08 avahi-daemon Successfully dropped root privileges.
19/04/2022 22:08 avahi-daemon avahi-daemon 0.8 starting up.
19/04/2022 22:08 kernel nct6775: Found NCT6795D or compatible chip at 0x4e:0xa20
19/04/2022 22:08 systemd Finished Initialize hardware monitoring sensors.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lm_sensors comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd-logind New seat seat0.
19/04/2022 22:08 polkitd Started polkitd version 0.120
19/04/2022 22:08 systemd-logind Watching system buttons on /dev/input/event1 (Power Button)
19/04/2022 22:08 systemd-logind Watching system buttons on /dev/input/event0 (Power Button)
19/04/2022 22:08 systemd-logind Watching system buttons on /dev/input/event4 (MOSART Semi. 2.4G Keyboard Mouse)
19/04/2022 22:08 systemd-logind Watching system buttons on /dev/input/event8 (MOSART Semi. 2.4G Keyboard Mouse Consumer Control)
19/04/2022 22:08 systemd-logind Watching system buttons on /dev/input/event9 (MOSART Semi. 2.4G Keyboard Mouse System Control)
19/04/2022 22:08 systemd Started D-Bus System Message Bus.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 avahi-daemon Successfully called chroot().
19/04/2022 22:08 avahi-daemon Successfully dropped remaining capabilities.
19/04/2022 22:08 avahi-daemon No service file found in /etc/avahi/services.
19/04/2022 22:08 systemd Starting Network Manager...
19/04/2022 22:08 systemd Started Avahi mDNS/DNS-SD Stack.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-machined comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 avahi-daemon Joining mDNS multicast group on interface lo.IPv6 with address ::1.
19/04/2022 22:08 systemd Started Virtual Machine and Container Registration Service.
19/04/2022 22:08 avahi-daemon New relevant interface lo.IPv6 for mDNS.
19/04/2022 22:08 systemd Started User Login Management.
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.freedesktop.systemd1'
19/04/2022 22:08 avahi-daemon Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
19/04/2022 22:08 avahi-daemon New relevant interface lo.IPv4 for mDNS.
19/04/2022 22:08 avahi-daemon Network interface enumeration completed.
19/04/2022 22:08 avahi-daemon Registering new address record for ::1 on lo.*.
19/04/2022 22:08 avahi-daemon Registering new address record for 127.0.0.1 on lo.IPv4.
19/04/2022 22:08 snapd AppArmor status: apparmor is enabled but some kernel features are missing: dbus, network
19/04/2022 22:08 polkitd Loading rules from directory /etc/polkit-1/rules.d
19/04/2022 22:08 polkitd Loading rules from directory /usr/share/polkit-1/rules.d
19/04/2022 22:08 NetworkManager <info> [1650402483.2141] NetworkManager (version 1.36.4-1) is starting... (for the first time)
19/04/2022 22:08 NetworkManager <info> [1650402483.2141] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
19/04/2022 22:08 systemd Started Network Manager.
19/04/2022 22:08 NetworkManager <info> [1650402483.2167] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Reached target Network.
19/04/2022 22:08 polkitd Finished loading, compiling and executing 10 rules
19/04/2022 22:08 systemd Starting Network Manager Wait Online...
19/04/2022 22:08 polkitd Acquired the name org.freedesktop.PolicyKit1 on the system bus
19/04/2022 22:08 systemd Starting CUPS Scheduler...
19/04/2022 22:08 systemd Starting Virtualization daemon...
19/04/2022 22:08 systemd Starting Permit User Sessions...
19/04/2022 22:08 systemd Started Authorization Manager.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Starting Modem Manager...
19/04/2022 22:08 NetworkManager <info> [1650402483.2240] manager[0x55f547e7b000]: monitoring kernel firmware directory '/lib/firmware'.
19/04/2022 22:08 snapd overlord.go:263: Acquiring state lock file
19/04/2022 22:08 snapd overlord.go:268: Acquired state lock file
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.6' (uid=0 pid=540 comm="/usr/bin/NetworkManager --no-daemon")
19/04/2022 22:08 systemd Finished Permit User Sessions.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Started Simple Desktop Display Manager.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit BPF prog-id=15 op=LOAD
19/04/2022 22:08 audit BPF prog-id=16 op=LOAD
19/04/2022 22:08 audit BPF prog-id=17 op=LOAD
19/04/2022 22:08 systemd Starting Hostname Service...
19/04/2022 22:08 kernel scsi 9:0:0:0: Direct-Access ASA INC ASA Flash Disk 8.07 PQ: 0 ANSI: 4
19/04/2022 22:08 kernel sd 9:0:0:0: Attached scsi generic sg3 type 0
19/04/2022 22:08 kernel sd 9:0:0:0: [sdd] 62914560 512-byte logical blocks: (32.2 GB/30.0 GiB)
19/04/2022 22:08 kernel sd 9:0:0:0: [sdd] Write Protect is off
19/04/2022 22:08 kernel sd 9:0:0:0: [sdd] Mode Sense: 23 00 00 00
19/04/2022 22:08 kernel sd 9:0:0:0: [sdd] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
19/04/2022 22:08 snapd daemon.go:247: started snapd/2.55.2-1 (series 16; classic; devmode) manjaro/ (amd64) linux/5.16.18-1-MANJARO.
19/04/2022 22:08 kernel sdd: sdd1
19/04/2022 22:08 kernel sd 9:0:0:0: [sdd] Attached SCSI removable disk
19/04/2022 22:08 kernel loop3: detected capacity change from 0 to 8
19/04/2022 22:08 ModemManager <info> ModemManager (version 1.18.6-1) starting in system bus...
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.freedesktop.hostname1'
19/04/2022 22:08 systemd Started Hostname Service.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 snapd daemon.go:340: adjusting startup timeout by 45s (pessimistic estimate of 30s plus 5s per snap)
19/04/2022 22:08 NetworkManager <info> [1650402483.2877] hostname: hostname: using hostnamed
19/04/2022 22:08 NetworkManager <info> [1650402483.2878] hostname: static hostname changed from (none) to "dislok-ms"
19/04/2022 22:08 NetworkManager <info> [1650402483.2881] dns-mgr[0x55f547e4c250]: init: dns=default,systemd-resolved rc-manager=symlink
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 NetworkManager <info> [1650402483.3098] manager[0x55f547e7b000]: rfkill: Wi-Fi hardware radio set enabled
19/04/2022 22:08 NetworkManager <info> [1650402483.3099] manager[0x55f547e7b000]: rfkill: WWAN hardware radio set enabled
19/04/2022 22:08 systemd Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
19/04/2022 22:08 systemd Started Snap Daemon.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.13' (uid=0 pid=519 comm="/usr/lib/snapd/snapd")
19/04/2022 22:08 NetworkManager <info> [1650402483.3256] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-team.so)
19/04/2022 22:08 audit BPF prog-id=18 op=LOAD
19/04/2022 22:08 audit BPF prog-id=19 op=LOAD
19/04/2022 22:08 audit BPF prog-id=20 op=LOAD
19/04/2022 22:08 NetworkManager <info> [1650402483.3268] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-adsl.so)
19/04/2022 22:08 systemd Starting Time & Date Service...
19/04/2022 22:08 NetworkManager <info> [1650402483.3326] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-bluetooth.so)
19/04/2022 22:08 NetworkManager <info> [1650402483.3337] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-wwan.so)
19/04/2022 22:08 NetworkManager <info> [1650402483.3355] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-ovs.so)
19/04/2022 22:08 NetworkManager <info> [1650402483.3373] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-wifi.so)
19/04/2022 22:08 NetworkManager <info> [1650402483.3375] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
19/04/2022 22:08 NetworkManager <info> [1650402483.3376] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
19/04/2022 22:08 NetworkManager <info> [1650402483.3376] manager: Networking is enabled by state file
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=540 comm="/usr/bin/NetworkManager --no-daemon")
19/04/2022 22:08 NetworkManager <info> [1650402483.3387] settings: Loaded settings plugin: keyfile (internal)
19/04/2022 22:08 sddm Initializing...
19/04/2022 22:08 systemd Starting Network Manager Script Dispatcher Service...
19/04/2022 22:08 systemd Started Virtualization daemon.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 NetworkManager <info> [1650402483.3419] dhcp-init: Using DHCP client 'internal'
19/04/2022 22:08 NetworkManager <info> [1650402483.3420] device (lo): carrier: link connected
19/04/2022 22:08 NetworkManager <info> [1650402483.3422] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
19/04/2022 22:08 NetworkManager <info> [1650402483.3431] manager: (enp37s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
19/04/2022 22:08 NetworkManager <info> [1650402483.3443] settings: (enp37s0): created default wired connection 'Wired connection 1'
19/04/2022 22:08 NetworkManager <info> [1650402483.3443] device (enp37s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
19/04/2022 22:08 sddm Starting...
19/04/2022 22:08 sddm Logind interface found
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
19/04/2022 22:08 systemd Started Network Manager Script Dispatcher Service.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 sddm Adding new display on vt 1 ...
19/04/2022 22:08 sddm Loading theme configuration from ""
19/04/2022 22:08 sddm Display server starting...
19/04/2022 22:08 sddm Adding cookie to "/var/run/sddm/{a3aa37e8-d9f7-4ed1-ac2a-aaac04f337a0}"
19/04/2022 22:08 kernel NET: Registered PF_QIPCRTR protocol family
19/04/2022 22:08 ModemManager [qrtr] socket lookup from 1:0
19/04/2022 22:08 ModemManager [qrtr] initial lookup finished
19/04/2022 22:08 systemd Started Modem Manager.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 sddm Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{a3aa37e8-d9f7-4ed1-ac2a-aaac04f337a0} -noreset -displayfd 17
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.freedesktop.timedate1'
19/04/2022 22:08 systemd Started Time & Date Service.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel Generic FE-GE Realtek PHY r8169-0-2500:00: attached PHY driver (mii_bus:phy_addr=r8169-0-2500:00, irq=MAC)
19/04/2022 22:08 kernel r8169 0000:25:00.0 enp37s0: Link is Down
19/04/2022 22:08 NetworkManager <info> [1650402483.5719] ovsdb: disconnected from ovsdb
19/04/2022 22:08 NetworkManager <info> [1650402483.5730] modem-manager: ModemManager available
19/04/2022 22:08 NetworkManager <info> [1650402483.6057] manager: (virbr0): new Bridge device (/org/freedesktop/NetworkManager/Devices/3)
19/04/2022 22:08 kernel bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
19/04/2022 22:08 audit NETFILTER_CFG table=filter:2 family=2 entries=2 op=nft_register_chain pid=643 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=128 a0=3 a1=7fff2d7d0df0 a2=0 a3=7fff2d7d0ddc items=0 ppid=570 pid=643 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D6E65772D636861696E004C4942564952545F494E50
19/04/2022 22:08 audit NETFILTER_CFG table=filter:3 family=2 entries=2 op=nft_register_chain pid=644 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=308 a0=3 a1=7ffcc05be720 a2=0 a3=7ffcc05be70c items=0 ppid=570 pid=644 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E7365727400494E505554002D2D6A756D70004C4942564952545F494E50
19/04/2022 22:08 audit NETFILTER_CFG table=filter:4 family=2 entries=1 op=nft_register_chain pid=661 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=96 a0=3 a1=7ffe0aaa8540 a2=0 a3=7ffe0aaa852c items=0 ppid=570 pid=661 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D6E65772D636861696E004C4942564952545F4F5554
19/04/2022 22:08 audit NETFILTER_CFG table=filter:5 family=2 entries=2 op=nft_register_chain pid=662 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=308 a0=3 a1=7fffafa1e8e0 a2=0 a3=7fffafa1e8cc items=0 ppid=570 pid=662 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004F5554505554002D2D6A756D70004C4942564952545F4F5554
19/04/2022 22:08 audit NETFILTER_CFG table=filter:6 family=2 entries=1 op=nft_register_chain pid=663 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=96 a0=3 a1=7ffec24c5440 a2=0 a3=7ffec24c542c items=0 ppid=570 pid=663 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D6E65772D636861696E004C4942564952545F46574F
19/04/2022 22:08 audit NETFILTER_CFG table=filter:7 family=2 entries=2 op=nft_register_chain pid=664 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=308 a0=3 a1=7fff9ac83a40 a2=0 a3=7fff9ac83a2c items=0 ppid=570 pid=664 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E7365727400464F5257415244002D2D6A756D70004C4942564952545F46574F
19/04/2022 22:08 audit NETFILTER_CFG table=filter:8 family=2 entries=1 op=nft_register_chain pid=665 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=96 a0=3 a1=7ffd95082500 a2=0 a3=7ffd950824ec items=0 ppid=570 pid=665 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D6E65772D636861696E004C4942564952545F465749
19/04/2022 22:08 audit NETFILTER_CFG table=filter:9 family=2 entries=1 op=nft_register_rule pid=666 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=224 a0=3 a1=7ffe881a9190 a2=0 a3=7ffe881a917c items=0 ppid=570 pid=666 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E7365727400464F5257415244002D2D6A756D70004C4942564952545F465749
19/04/2022 22:08 audit NETFILTER_CFG table=filter:10 family=2 entries=1 op=nft_register_chain pid=667 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=96 a0=3 a1=7fff605e1790 a2=0 a3=7fff605e177c items=0 ppid=570 pid=667 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D6E65772D636861696E004C4942564952545F465758
19/04/2022 22:08 audit NETFILTER_CFG table=filter:11 family=2 entries=1 op=nft_register_rule pid=668 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=224 a0=3 a1=7ffd26aacff0 a2=0 a3=7ffd26aacfdc items=0 ppid=570 pid=668 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E7365727400464F5257415244002D2D6A756D70004C4942564952545F465758
19/04/2022 22:08 audit NETFILTER_CFG table=nat:12 family=2 entries=2 op=nft_register_chain pid=669 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=120 a0=3 a1=7ffcde197f70 a2=0 a3=7ffcde197f5c items=0 ppid=570 pid=669 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C65006E6174002D2D6E65772D636861696E004C4942564952545F505254
19/04/2022 22:08 audit NETFILTER_CFG table=nat:13 family=2 entries=2 op=nft_register_chain pid=670 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=304 a0=3 a1=7fff04a9c690 a2=0 a3=7fff04a9c67c items=0 ppid=570 pid=670 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C65006E6174002D2D696E7365727400504F5354524F5554494E47002D2D6A756D70004C4942564952545F505254
19/04/2022 22:08 audit NETFILTER_CFG table=mangle:14 family=2 entries=2 op=nft_register_chain pid=672 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=128 a0=3 a1=7ffc7b8fe440 a2=0 a3=7ffc7b8fe42c items=0 ppid=570 pid=672 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C65006D616E676C65002D2D6E65772D636861696E004C4942564952545F505254
19/04/2022 22:08 audit NETFILTER_CFG table=mangle:15 family=2 entries=2 op=nft_register_chain pid=673 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=316 a0=3 a1=7fff96b7b4b0 a2=0 a3=7fff96b7b49c items=0 ppid=570 pid=673 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C65006D616E676C65002D2D696E7365727400504F5354524F5554494E47002D2D6A756D70004C4942564952545F505254
19/04/2022 22:08 audit NETFILTER_CFG table=filter:16 family=10 entries=2 op=nft_register_chain pid=677 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=128 a0=3 a1=7ffea9cc4f10 a2=0 a3=7ffea9cc4efc items=0 ppid=570 pid=677 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C650066696C746572002D2D6E65772D636861696E004C4942564952545F494E50
19/04/2022 22:08 audit NETFILTER_CFG table=filter:17 family=10 entries=2 op=nft_register_chain pid=678 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=308 a0=3 a1=7ffcdac4a320 a2=0 a3=7ffcdac4a30c items=0 ppid=570 pid=678 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C650066696C746572002D2D696E7365727400494E505554002D2D6A756D70004C4942564952545F494E50
19/04/2022 22:08 audit NETFILTER_CFG table=filter:18 family=10 entries=1 op=nft_register_chain pid=679 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=96 a0=3 a1=7fff9d491050 a2=0 a3=7fff9d49103c items=0 ppid=570 pid=679 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C650066696C746572002D2D6E65772D636861696E004C4942564952545F4F5554
19/04/2022 22:08 audit NETFILTER_CFG table=filter:19 family=10 entries=2 op=nft_register_chain pid=680 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=308 a0=3 a1=7ffc1cdcc9c0 a2=0 a3=7ffc1cdcc9ac items=0 ppid=570 pid=680 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004F5554505554002D2D6A756D70004C4942564952545F4F5554
19/04/2022 22:08 audit NETFILTER_CFG table=filter:20 family=10 entries=1 op=nft_register_chain pid=681 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=96 a0=3 a1=7ffc4dc7a1e0 a2=0 a3=7ffc4dc7a1cc items=0 ppid=570 pid=681 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C650066696C746572002D2D6E65772D636861696E004C4942564952545F46574F
19/04/2022 22:08 audit NETFILTER_CFG table=filter:21 family=10 entries=2 op=nft_register_chain pid=682 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=308 a0=3 a1=7ffceb7f2570 a2=0 a3=7ffceb7f255c items=0 ppid=570 pid=682 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C650066696C746572002D2D696E7365727400464F5257415244002D2D6A756D70004C4942564952545F46574F
19/04/2022 22:08 audit NETFILTER_CFG table=filter:22 family=10 entries=1 op=nft_register_chain pid=683 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=96 a0=3 a1=7ffd07e86930 a2=0 a3=7ffd07e8691c items=0 ppid=570 pid=683 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C650066696C746572002D2D6E65772D636861696E004C4942564952545F465749
19/04/2022 22:08 audit NETFILTER_CFG table=filter:23 family=10 entries=1 op=nft_register_rule pid=684 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=224 a0=3 a1=7ffece00fb00 a2=0 a3=7ffece00faec items=0 ppid=570 pid=684 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C650066696C746572002D2D696E7365727400464F5257415244002D2D6A756D70004C4942564952545F465749
19/04/2022 22:08 audit NETFILTER_CFG table=filter:24 family=10 entries=1 op=nft_register_chain pid=685 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=96 a0=3 a1=7ffcd15de910 a2=0 a3=7ffcd15de8fc items=0 ppid=570 pid=685 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C650066696C746572002D2D6E65772D636861696E004C4942564952545F465758
19/04/2022 22:08 audit NETFILTER_CFG table=filter:25 family=10 entries=1 op=nft_register_rule pid=686 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=224 a0=3 a1=7ffd14d10690 a2=0 a3=7ffd14d1067c items=0 ppid=570 pid=686 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C650066696C746572002D2D696E7365727400464F5257415244002D2D6A756D70004C4942564952545F465758
19/04/2022 22:08 audit NETFILTER_CFG table=nat:26 family=10 entries=2 op=nft_register_chain pid=687 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=120 a0=3 a1=7ffe83452e20 a2=0 a3=7ffe83452e0c items=0 ppid=570 pid=687 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C65006E6174002D2D6E65772D636861696E004C4942564952545F505254
19/04/2022 22:08 audit NETFILTER_CFG table=nat:27 family=10 entries=2 op=nft_register_chain pid=688 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=304 a0=3 a1=7ffc88476d80 a2=0 a3=7ffc88476d6c items=0 ppid=570 pid=688 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C65006E6174002D2D696E7365727400504F5354524F5554494E47002D2D6A756D70004C4942564952545F505254
19/04/2022 22:08 audit NETFILTER_CFG table=mangle:28 family=10 entries=2 op=nft_register_chain pid=689 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=128 a0=3 a1=7ffd07194f20 a2=0 a3=7ffd07194f0c items=0 ppid=570 pid=689 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C65006D616E676C65002D2D6E65772D636861696E004C4942564952545F505254
19/04/2022 22:08 audit NETFILTER_CFG table=mangle:29 family=10 entries=2 op=nft_register_chain pid=690 subj==unconfined comm="ip6tables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=316 a0=3 a1=7ffe713f0da0 a2=0 a3=7ffe713f0d8c items=0 ppid=570 pid=690 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F6970367461626C6573002D77002D2D7461626C65006D616E676C65002D2D696E7365727400504F5354524F5554494E47002D2D6A756D70004C4942564952545F505254
19/04/2022 22:08 audit NETFILTER_CFG table=filter:30 family=2 entries=1 op=nft_register_rule pid=691 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=432 a0=3 a1=7ffe5ff4a830 a2=0 a3=7ffe5ff4a81c items=0 ppid=570 pid=691 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F494E50002D2D696E2D696E7465726661636500766972627230002D2D70726F746F636F6C00746370002D2D64657374696E6174696F6E2D706F7274003637002D2D6A756D70004143434550
19/04/2022 22:08 audit NETFILTER_CFG table=filter:31 family=2 entries=1 op=nft_register_rule pid=694 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=432 a0=3 a1=7ffe70d67880 a2=0 a3=7ffe70d6786c items=0 ppid=570 pid=694 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F494E50002D2D696E2D696E7465726661636500766972627230002D2D70726F746F636F6C00756470002D2D64657374696E6174696F6E2D706F7274003637002D2D6A756D70004143434550
19/04/2022 22:08 audit NETFILTER_CFG table=filter:32 family=2 entries=1 op=nft_register_rule pid=695 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=432 a0=3 a1=7ffcb558a600 a2=0 a3=7ffcb558a5ec items=0 ppid=570 pid=695 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F4F5554002D2D6F75742D696E7465726661636500766972627230002D2D70726F746F636F6C00746370002D2D64657374696E6174696F6E2D706F7274003638002D2D6A756D700041434345
19/04/2022 22:08 audit NETFILTER_CFG table=filter:33 family=2 entries=1 op=nft_register_rule pid=696 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=432 a0=3 a1=7fffaadb5970 a2=0 a3=7fffaadb595c items=0 ppid=570 pid=696 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F4F5554002D2D6F75742D696E7465726661636500766972627230002D2D70726F746F636F6C00756470002D2D64657374696E6174696F6E2D706F7274003638002D2D6A756D700041434345
19/04/2022 22:08 audit NETFILTER_CFG table=filter:34 family=2 entries=1 op=nft_register_rule pid=697 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=432 a0=3 a1=7ffd32e46930 a2=0 a3=7ffd32e4691c items=0 ppid=570 pid=697 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F494E50002D2D696E2D696E7465726661636500766972627230002D2D70726F746F636F6C00746370002D2D64657374696E6174696F6E2D706F7274003533002D2D6A756D70004143434550
19/04/2022 22:08 audit NETFILTER_CFG table=filter:35 family=2 entries=1 op=nft_register_rule pid=698 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=432 a0=3 a1=7fff12d4cc30 a2=0 a3=7fff12d4cc1c items=0 ppid=570 pid=698 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F494E50002D2D696E2D696E7465726661636500766972627230002D2D70726F746F636F6C00756470002D2D64657374696E6174696F6E2D706F7274003533002D2D6A756D70004143434550
19/04/2022 22:08 audit NETFILTER_CFG table=filter:36 family=2 entries=1 op=nft_register_rule pid=699 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=432 a0=3 a1=7fffabfc4e20 a2=0 a3=7fffabfc4e0c items=0 ppid=570 pid=699 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F4F5554002D2D6F75742D696E7465726661636500766972627230002D2D70726F746F636F6C00746370002D2D64657374696E6174696F6E2D706F7274003533002D2D6A756D700041434345
19/04/2022 22:08 audit NETFILTER_CFG table=filter:37 family=2 entries=1 op=nft_register_rule pid=700 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=432 a0=3 a1=7ffe6727c700 a2=0 a3=7ffe6727c6ec items=0 ppid=570 pid=700 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F4F5554002D2D6F75742D696E7465726661636500766972627230002D2D70726F746F636F6C00756470002D2D64657374696E6174696F6E2D706F7274003533002D2D6A756D700041434345
19/04/2022 22:08 audit NETFILTER_CFG table=filter:38 family=2 entries=1 op=nft_register_rule pid=701 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=300 a0=3 a1=7ffe55af7b80 a2=0 a3=7ffe55af7b6c items=0 ppid=570 pid=701 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F46574F002D2D696E2D696E7465726661636500766972627230002D2D6A756D700052454A454354
19/04/2022 22:08 audit NETFILTER_CFG table=filter:39 family=2 entries=1 op=nft_register_rule pid=703 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=300 a0=3 a1=7ffcd75194c0 a2=0 a3=7ffcd75194ac items=0 ppid=570 pid=703 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F465749002D2D6F75742D696E7465726661636500766972627230002D2D6A756D700052454A454354
19/04/2022 22:08 audit NETFILTER_CFG table=filter:40 family=2 entries=1 op=nft_register_rule pid=704 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=380 a0=3 a1=7ffd38056790 a2=0 a3=7ffd3805677c items=0 ppid=570 pid=704 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F465758002D2D696E2D696E7465726661636500766972627230002D2D6F75742D696E7465726661636500766972627230002D2D6A756D7000414343455054
19/04/2022 22:08 audit NETFILTER_CFG table=filter:41 family=2 entries=1 op=nft_register_rule pid=705 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=392 a0=3 a1=7ffd0b7e2f00 a2=0 a3=7ffd0b7e2eec items=0 ppid=570 pid=705 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F46574F002D2D736F75726365003139322E3136382E3132322E302F3234002D2D696E2D696E7465726661636500766972627230002D2D6A756D7000414343455054
19/04/2022 22:08 audit NETFILTER_CFG table=filter:42 family=2 entries=1 op=nft_register_rule pid=706 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=608 a0=3 a1=7ffd88670c10 a2=0 a3=7ffd88670bfc items=0 ppid=570 pid=706 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C650066696C746572002D2D696E73657274004C4942564952545F465749002D2D64657374696E6174696F6E003139322E3136382E3132322E302F3234002D2D6F75742D696E7465726661636500766972627230002D2D6D6174636800636F6E6E747261636B
19/04/2022 22:08 audit NETFILTER_CFG table=nat:43 family=2 entries=1 op=nft_register_rule pid=708 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=424 a0=3 a1=7ffc5d51ddc0 a2=0 a3=7ffc5d51ddac items=0 ppid=570 pid=708 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C65006E6174002D2D696E73657274004C4942564952545F505254002D2D736F75726365003139322E3136382E3132322E302F32340000002D2D64657374696E6174696F6E003139322E3136382E3132322E302F3234002D2D6A756D70004D41535155455241
19/04/2022 22:08 audit NETFILTER_CFG table=nat:44 family=2 entries=1 op=nft_register_rule pid=710 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=504 a0=3 a1=7ffd10502880 a2=0 a3=7ffd1050286c items=0 ppid=570 pid=710 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C65006E6174002D2D696E73657274004C4942564952545F505254002D2D736F75726365003139322E3136382E3132322E302F3234002D70007564700000002D2D64657374696E6174696F6E003139322E3136382E3132322E302F3234002D2D6A756D70004D
19/04/2022 22:08 audit NETFILTER_CFG table=nat:45 family=2 entries=1 op=nft_register_rule pid=711 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=504 a0=3 a1=7ffcdfef0970 a2=0 a3=7ffcdfef095c items=0 ppid=570 pid=711 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C65006E6174002D2D696E73657274004C4942564952545F505254002D2D736F75726365003139322E3136382E3132322E302F3234002D70007463700000002D2D64657374696E6174696F6E003139322E3136382E3132322E302F3234002D2D6A756D70004D
19/04/2022 22:08 audit NETFILTER_CFG table=nat:46 family=2 entries=1 op=nft_register_rule pid=712 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=400 a0=3 a1=7ffdf24d3e30 a2=0 a3=7ffdf24d3e1c items=0 ppid=570 pid=712 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C65006E6174002D2D696E73657274004C4942564952545F505254002D2D736F75726365003139322E3136382E3132322E302F3234002D2D64657374696E6174696F6E003235352E3235352E3235352E3235352F3332002D2D6A756D700052455455524E
19/04/2022 22:08 audit NETFILTER_CFG table=nat:47 family=2 entries=1 op=nft_register_rule pid=713 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=400 a0=3 a1=7fff9bd64ae0 a2=0 a3=7fff9bd64acc items=0 ppid=570 pid=713 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C65006E6174002D2D696E73657274004C4942564952545F505254002D2D736F75726365003139322E3136382E3132322E302F3234002D2D64657374696E6174696F6E003232342E302E302E302F3234002D2D6A756D700052455455524E
19/04/2022 22:08 systemd tmp-sanity\x2dmountpoint\x2d3280852882.mount: Deactivated successfully.
19/04/2022 22:08 audit NETFILTER_CFG table=mangle:48 family=2 entries=1 op=nft_register_rule pid=715 subj==unconfined comm="iptables"
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=46 success=yes exit=440 a0=3 a1=7fff2f188200 a2=0 a3=7fff2f1881ec items=0 ppid=570 pid=715 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F62696E2F69707461626C6573002D77002D2D7461626C65006D616E676C65002D2D696E73657274004C4942564952545F505254002D2D6F75742D696E7465726661636500766972627230002D2D70726F746F636F6C00756470002D2D64657374696E6174696F6E2D706F7274003638002D2D6A756D700043484543
19/04/2022 22:08 avahi-daemon Joining mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1.
19/04/2022 22:08 avahi-daemon New relevant interface virbr0.IPv4 for mDNS.
19/04/2022 22:08 avahi-daemon Registering new address record for 192.168.122.1 on virbr0.IPv4.
19/04/2022 22:08 NetworkManager <info> [1650402483.9209] device (virbr0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
19/04/2022 22:08 NetworkManager <info> [1650402483.9212] device (virbr0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
19/04/2022 22:08 NetworkManager <info> [1650402483.9218] device (virbr0): Activation: starting connection 'virbr0' (330e93ab-fb94-4260-aae1-a5591fbdc9c2)
19/04/2022 22:08 NetworkManager <info> [1650402483.9220] device (virbr0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
19/04/2022 22:08 NetworkManager <info> [1650402483.9223] device (virbr0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
19/04/2022 22:08 NetworkManager <info> [1650402483.9224] device (virbr0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
19/04/2022 22:08 NetworkManager <info> [1650402483.9226] device (virbr0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
19/04/2022 22:08 NetworkManager <info> [1650402483.9249] device (virbr0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
19/04/2022 22:08 NetworkManager <info> [1650402483.9251] device (virbr0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
19/04/2022 22:08 NetworkManager <info> [1650402483.9254] manager: NetworkManager state is now CONNECTED_LOCAL
19/04/2022 22:08 NetworkManager <info> [1650402483.9256] device (virbr0): Activation: successful, device activated.
19/04/2022 22:08 dnsmasq started, version 2.86 cachesize 150
19/04/2022 22:08 dnsmasq compile time options: IPv6 GNU-getopt DBus no-UBus i18n IDN2 DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC loop-detect inotify dumpfile
19/04/2022 22:08 dnsmasq-dhcp DHCP, IP range 192.168.122.2 -- 192.168.122.254, lease time 1h
19/04/2022 22:08 dnsmasq-dhcp DHCP, sockets bound exclusively to interface virbr0
19/04/2022 22:08 dnsmasq reading /etc/resolv.conf
19/04/2022 22:08 dnsmasq using nameserver 8.8.8.8#53
19/04/2022 22:08 dnsmasq using nameserver 8.8.4.4#53
19/04/2022 22:08 dnsmasq read /etc/hosts - 5 addresses
19/04/2022 22:08 dnsmasq read /var/lib/libvirt/dnsmasq/default.addnhosts - 0 addresses
19/04/2022 22:08 dnsmasq-dhcp read /var/lib/libvirt/dnsmasq/default.hostsfile
19/04/2022 22:08 sddm Setting default cursor
19/04/2022 22:08 sddm Running display setup script "/usr/share/sddm/scripts/Xsetup"
19/04/2022 22:08 sddm Display server started.
19/04/2022 22:08 sddm Socket server starting...
19/04/2022 22:08 sddm Socket server started.
19/04/2022 22:08 sddm Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
19/04/2022 22:08 sddm Greeter starting...
19/04/2022 22:08 sddm-helper [PAM] Starting...
19/04/2022 22:08 audit USER_AUTH pid=732 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit USER_ACCT pid=732 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 sddm-helper [PAM] Authenticating...
19/04/2022 22:08 sddm-helper [PAM] returning.
19/04/2022 22:08 kernel kauditd_printk_skb: 198 callbacks suppressed
19/04/2022 22:08 kernel audit: type=1100 audit(1650402484.500:108): pid=732 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1101 audit(1650402484.500:109): pid=732 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1103 audit(1650402484.504:110): pid=732 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit CRED_ACQ pid=732 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 sddm-helper pam_unix(sddm-greeter:session): session opened for user sddm(uid=962) by (uid=0)
19/04/2022 22:08 systemd Created slice User Slice of UID 962.
19/04/2022 22:08 systemd Starting User Runtime Directory /run/user/962...
19/04/2022 22:08 systemd-logind New session c1 of user sddm.
19/04/2022 22:08 systemd Finished User Runtime Directory /run/user/962.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Starting User Manager for UID 962...
19/04/2022 22:08 kernel audit: type=1130 audit(1650402484.517:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.21' (uid=0 pid=735 comm="(systemd)")
19/04/2022 22:08 dbus-daemon [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
19/04/2022 22:08 systemd pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
19/04/2022 22:08 audit USER_ACCT pid=735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit CRED_ACQ pid=735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
19/04/2022 22:08 systemd pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffd18d2e040 a2=3 a3=0 items=0 ppid=1 pid=735 auid=962 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle="(systemd)"
19/04/2022 22:08 systemd pam_unix(systemd-user:session): session opened for user sddm(uid=962) by (uid=0)
19/04/2022 22:08 systemd pam_env(systemd-user:session): deprecated reading of user environment enabled
19/04/2022 22:08 audit USER_START pid=735 uid=0 auid=962 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1101 audit(1650402484.527:112): pid=735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1103 audit(1650402484.527:113): pid=735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
19/04/2022 22:08 kernel audit: type=1006 audit(1650402484.527:114): pid=735 uid=0 subj==unconfined old-auid=4294967295 auid=962 tty=(none) old-ses=4294967295 ses=1 res=1
19/04/2022 22:08 kernel audit: type=1300 audit(1650402484.527:114): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffd18d2e040 a2=3 a3=0 items=0 ppid=1 pid=735 auid=962 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
19/04/2022 22:08 kernel audit: type=1327 audit(1650402484.527:114): proctitle="(systemd)"
19/04/2022 22:08 kernel audit: type=1105 audit(1650402484.527:115): pid=735 uid=0 auid=962 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Queued start job for default target Main User Target.
19/04/2022 22:08 systemd Created slice User Application Slice.
19/04/2022 22:08 systemd Reached target Paths.
19/04/2022 22:08 systemd Reached target Timers.
19/04/2022 22:08 systemd Starting D-Bus User Message Bus Socket...
19/04/2022 22:08 systemd Listening on GnuPG network certificate management daemon.
19/04/2022 22:08 systemd Listening on GCR ssh-agent wrapper.
19/04/2022 22:08 systemd Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
19/04/2022 22:08 systemd Listening on GnuPG cryptographic agent and passphrase cache (restricted).
19/04/2022 22:08 systemd Listening on GnuPG cryptographic agent (ssh-agent emulation).
19/04/2022 22:08 systemd Listening on GnuPG cryptographic agent and passphrase cache.
19/04/2022 22:08 systemd Listening on p11-kit server.
19/04/2022 22:08 systemd Listening on PipeWire Multimedia System Socket.
19/04/2022 22:08 systemd Listening on Sound System.
19/04/2022 22:08 systemd Listening on D-Bus User Message Bus Socket.
19/04/2022 22:08 systemd Reached target Sockets.
19/04/2022 22:08 systemd Started User Manager for UID 962.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Started Session c1 of User sddm.
19/04/2022 22:08 systemd Starting Update XDG user dir configuration...
19/04/2022 22:08 xdg-user-dirs-update Can't save user-dirs.dirs
19/04/2022 22:08 systemd xdg-user-dirs-update.service: Main process exited, code=exited, status=1/FAILURE
19/04/2022 22:08 systemd xdg-user-dirs-update.service: Failed with result 'exit-code'.
19/04/2022 22:08 systemd Failed to start Update XDG user dir configuration.
19/04/2022 22:08 systemd Reached target Main User Target.
19/04/2022 22:08 systemd Startup finished in 157ms.
19/04/2022 22:08 audit USER_START pid=732 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
19/04/2022 22:08 sddm Greeter session started successfully
19/04/2022 22:08 sddm-greeter High-DPI autoscaling not Enabled
19/04/2022 22:08 avahi-daemon Server startup complete. Host name is dislok-ms.local. Local service cookie is 1214678080.
19/04/2022 22:08 sddm-greeter Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
19/04/2022 22:08 sddm-greeter Reading from "/usr/share/xsessions/plasma.desktop"
19/04/2022 22:08 sddm-greeter Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
19/04/2022 22:08 systemd Created slice User Core Session Slice.
19/04/2022 22:08 systemd Starting D-Bus User Message Bus...
19/04/2022 22:08 systemd Started D-Bus User Message Bus.
19/04/2022 22:08 sddm-greeter Connected to the daemon.
19/04/2022 22:08 sddm-greeter QFont::fromString: Invalid description '(empty)'
19/04/2022 22:08 sddm Message received from greeter: Connect
19/04/2022 22:08 sddm-greeter Loading file:///usr/share/sddm/themes/breath/Main.qml...
19/04/2022 22:08 sddm-greeter QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fffde8689d0), parent's thread is QThread(0x5579d3e0c050), current thread is QThread(0x5579d3f5a6e0)
19/04/2022 22:08 sddm-greeter QObject::installEventFilter(): Cannot filter events for objects in a different thread.
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.23' (uid=962 pid=753 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-muZqdS")
19/04/2022 22:08 systemd Starting Disk Manager...
19/04/2022 22:08 udisks2.service udisks daemon version 2.9.4 starting
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.freedesktop.UDisks2'
19/04/2022 22:08 systemd Started Disk Manager.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.23' (uid=962 pid=753 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-muZqdS")
19/04/2022 22:08 audit BPF prog-id=21 op=LOAD
19/04/2022 22:08 audit BPF prog-id=22 op=LOAD
19/04/2022 22:08 systemd Starting Daemon for power management...
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.freedesktop.UPower'
19/04/2022 22:08 systemd Started Daemon for power management.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 udisks2.service Acquired the name org.freedesktop.UDisks2 on the system message bus
19/04/2022 22:08 sddm-greeter file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
19/04/2022 22:08 sddm-greeter qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
19/04/2022 22:08 sddm-greeter qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
19/04/2022 22:08 ModemManager <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:12:00.2/0000:20:04.0/0000:25:00.0': not supported by any plugin
19/04/2022 22:08 sddm-greeter file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
19/04/2022 22:08 sddm-greeter Adding view for "DVI-D-0" QRect(0,0 1600x900)
19/04/2022 22:08 sddm-greeter QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.24'
19/04/2022 22:08 sddm-greeter Message received from daemon: Capabilities
19/04/2022 22:08 sddm-greeter Message received from daemon: HostName
19/04/2022 22:08 NetworkManager <info> [1650402486.6884] device (enp37s0): carrier: link connected
19/04/2022 22:08 NetworkManager <info> [1650402486.6889] device (enp37s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
19/04/2022 22:08 NetworkManager <info> [1650402486.6898] policy: auto-activating connection 'Wired connection 1' (ae8380b6-6798-3ff0-97af-778f9038589a)
19/04/2022 22:08 kernel IPv6: ADDRCONF(NETDEV_CHANGE): enp37s0: link becomes ready
19/04/2022 22:08 kernel r8169 0000:25:00.0 enp37s0: Link is Up - 100Mbps/Full - flow control rx/tx
19/04/2022 22:08 NetworkManager <info> [1650402486.6903] device (enp37s0): Activation: starting connection 'Wired connection 1' (ae8380b6-6798-3ff0-97af-778f9038589a)
19/04/2022 22:08 NetworkManager <info> [1650402486.6903] device (enp37s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
19/04/2022 22:08 NetworkManager <info> [1650402486.6905] manager: NetworkManager state is now CONNECTING
19/04/2022 22:08 NetworkManager <info> [1650402486.6906] device (enp37s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
19/04/2022 22:08 NetworkManager <info> [1650402486.6912] device (enp37s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
19/04/2022 22:08 NetworkManager <info> [1650402486.6915] dhcp4 (enp37s0): activation: beginning transaction (timeout in 45 seconds)
19/04/2022 22:08 avahi-daemon Joining mDNS multicast group on interface enp37s0.IPv6 with address fe80::dc62:8953:520d:d536.
19/04/2022 22:08 avahi-daemon New relevant interface enp37s0.IPv6 for mDNS.
19/04/2022 22:08 avahi-daemon Registering new address record for fe80::dc62:8953:520d:d536 on enp37s0.*.
19/04/2022 22:08 NetworkManager <info> [1650402486.6989] dhcp4 (enp37s0): state changed new lease, address=192.168.1.11
19/04/2022 22:08 avahi-daemon Joining mDNS multicast group on interface enp37s0.IPv4 with address 192.168.1.11.
19/04/2022 22:08 avahi-daemon New relevant interface enp37s0.IPv4 for mDNS.
19/04/2022 22:08 avahi-daemon Registering new address record for 192.168.1.11 on enp37s0.IPv4.
19/04/2022 22:08 NetworkManager <info> [1650402486.7000] device (enp37s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
19/04/2022 22:08 NetworkManager <info> [1650402486.7013] device (enp37s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
19/04/2022 22:08 NetworkManager <info> [1650402486.7014] device (enp37s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
19/04/2022 22:08 NetworkManager <info> [1650402486.7016] manager: NetworkManager state is now CONNECTED_LOCAL
19/04/2022 22:08 NetworkManager <info> [1650402486.7018] manager: NetworkManager state is now CONNECTED_SITE
19/04/2022 22:08 NetworkManager <info> [1650402486.7019] policy: set 'Wired connection 1' (enp37s0) as default for IPv4 routing and DNS
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=540 comm="/usr/bin/NetworkManager --no-daemon")
19/04/2022 22:08 dbus-daemon [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
19/04/2022 22:08 NetworkManager <info> [1650402486.7043] device (enp37s0): Activation: successful, device activated.
19/04/2022 22:08 NetworkManager <info> [1650402486.7053] manager: startup complete
19/04/2022 22:08 systemd Finished Network Manager Wait Online.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Reached target Network is Online.
19/04/2022 22:08 systemd Starting Samba NMB Daemon...
19/04/2022 22:08 nmbd [2022/04/19 22:08:06.782297, 0] ../../source3/nmbd/nmbd.c:901(main)
19/04/2022 22:08 nmbd nmbd version 4.16.0 started.
19/04/2022 22:08 nmbd Copyright Andrew Tridgell and the Samba Team 1992-2022
19/04/2022 22:08 nmbd [2022/04/19 22:08:06.783785, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 nmbd reopen_one_log: Unable to open new log file '/usr/local/samba/var/log.nmbd': No such file or directory
19/04/2022 22:08 nmbd [2022/04/19 22:08:06.783887, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 systemd Started Samba NMB Daemon.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Starting Samba SMB Daemon...
19/04/2022 22:08 smbd [2022/04/19 22:08:06.830844, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 smbd reopen_one_log: Unable to open new log file '/usr/local/samba/var/log.smbd': No such file or directory
19/04/2022 22:08 smbd [2022/04/19 22:08:06.830882, 0] ../../source3/smbd/server.c:1741(main)
19/04/2022 22:08 smbd smbd version 4.16.0 started.
19/04/2022 22:08 smbd Copyright Andrew Tridgell and the Samba Team 1992-2022
19/04/2022 22:08 smbd [2022/04/19 22:08:06.832184, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 smbd [2022/04/19 22:08:06.832265, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 smbd [2022/04/19 22:08:06.832487, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 smbd [2022/04/19 22:08:06.832558, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 smbd [2022/04/19 22:08:06.832586, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 smbd [2022/04/19 22:08:06.832645, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 smbd [2022/04/19 22:08:06.841250, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 smbd [2022/04/19 22:08:06.841690, 0] ../../lib/util/debug.c:1224(reopen_one_log)
19/04/2022 22:08 systemd Started Samba SMB Daemon.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Reached target Multi-User System.
19/04/2022 22:08 systemd Reached target Graphical Interface.
19/04/2022 22:08 systemd Startup finished in 14.972s (firmware) + 5.672s (loader) + 2.349s (kernel) + 5.242s (userspace) = 28.236s.
19/04/2022 22:08 NetworkManager <info> [1650402487.0130] manager: NetworkManager state is now CONNECTED_GLOBAL
19/04/2022 22:08 sddm Message received from greeter: Login
19/04/2022 22:08 sddm Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
19/04/2022 22:08 sddm Session "/usr/share/wayland-sessions/plasmawayland.desktop" selected, command: "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland"
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.27' (uid=0 pid=818 comm="/usr/lib/sddm/sddm-helper --socket /tmp/sddm-authd")
19/04/2022 22:08 sddm-helper pam_systemd_home(sddm:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
19/04/2022 22:08 sddm-helper [PAM] Preparing to converse...
19/04/2022 22:08 sddm-helper [PAM] Conversation with 1 messages
19/04/2022 22:08 sddm-helper pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
19/04/2022 22:08 audit USER_AUTH pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="dislok" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit USER_ACCT pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="dislok" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 sddm Authenticated successfully
19/04/2022 22:08 sddm-greeter Message received from daemon: LoginSucceeded
19/04/2022 22:08 audit CRED_ACQ pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="dislok" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7fff2c1d8b00 a2=4 a3=0 items=0 ppid=574 pid=818 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
19/04/2022 22:08 audit PROCTITLE proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746864303964333431662D393836312D343365312D623161352D633931363064356465336236002D2D69640031002D2D7374617274002F7573722F6C69622F706C61736D612D646275732D72756E2D7365
19/04/2022 22:08 sddm-helper pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
19/04/2022 22:08 kernel kauditd_printk_skb: 9 callbacks suppressed
19/04/2022 22:08 kernel audit: type=1100 audit(1650402489.620:125): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="dislok" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1101 audit(1650402489.620:126): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="dislok" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1103 audit(1650402489.620:127): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="dislok" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1006 audit(1650402489.620:128): pid=818 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
19/04/2022 22:08 kernel audit: type=1300 audit(1650402489.620:128): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7fff2c1d8b00 a2=4 a3=0 items=0 ppid=574 pid=818 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
19/04/2022 22:08 kernel audit: type=1327 audit(1650402489.620:128): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746864303964333431662D393836312D343365312D623161352D633931363064356465336236002D2D69640031002D2D7374617274002F7573722F6C69622F706C61736D612D646275732D72756E2D7365
19/04/2022 22:08 sddm-helper pam_unix(sddm:session): session opened for user dislok(uid=1000) by (uid=0)
19/04/2022 22:08 systemd Created slice User Slice of UID 1000.
19/04/2022 22:08 systemd Starting User Runtime Directory /run/user/1000...
19/04/2022 22:08 systemd-logind New session 2 of user dislok.
19/04/2022 22:08 systemd Finished User Runtime Directory /run/user/1000.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Starting User Manager for UID 1000...
19/04/2022 22:08 kernel audit: type=1130 audit(1650402489.634:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.29' (uid=0 pid=820 comm="(systemd)")
19/04/2022 22:08 audit USER_ACCT pid=820 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="dislok" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit CRED_ACQ pid=820 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="dislok" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
19/04/2022 22:08 audit SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffd18d2e040 a2=4 a3=0 items=0 ppid=1 pid=820 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
19/04/2022 22:08 systemd pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[dislok] ruser=[<unknown>] rhost=[<unknown>]
19/04/2022 22:08 systemd pam_unix(systemd-user:session): session opened for user dislok(uid=1000) by (uid=0)
19/04/2022 22:08 audit USER_START pid=820 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="dislok" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1101 audit(1650402489.640:130): pid=820 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="dislok" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1103 audit(1650402489.640:131): pid=820 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="dislok" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
19/04/2022 22:08 kernel audit: type=1006 audit(1650402489.640:132): pid=820 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
19/04/2022 22:08 sddm-helper [PAM] Closing session
19/04/2022 22:08 sddm-helper pam_unix(sddm-greeter:session): session closed for user sddm
19/04/2022 22:08 audit USER_END pid=732 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
19/04/2022 22:08 audit CRED_DISP pid=732 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
19/04/2022 22:08 sddm-helper [PAM] Ended.
19/04/2022 22:08 sddm Auth: sddm-helper exited successfully
19/04/2022 22:08 sddm Greeter stopped.
19/04/2022 22:08 systemd session-c1.scope: Deactivated successfully.
19/04/2022 22:08 systemd-logind Session c1 logged out. Waiting for processes to exit.
19/04/2022 22:08 systemd-logind Removed session c1.
19/04/2022 22:08 systemd-xdg-autostart-generator /home/dislok/.config/autostart/org.kde.latte-dock.desktop:87: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
19/04/2022 22:08 systemd-xdg-autostart-generator Exec binary '/usr/bin/latte-dock' does not exist: No such file or directory
19/04/2022 22:08 systemd-xdg-autostart-generator Not generating service for XDG autostart app-org.kde.latte\x2ddock@autostart.service, error parsing Exec= line: No such file or directory
19/04/2022 22:08 systemd Reached target Basic System.
19/04/2022 22:08 systemd Started User Manager for UID 1000.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Started Session 2 of User dislok.
19/04/2022 22:08 sddm-helper pam_env(sddm:session): deprecated reading of user environment enabled
19/04/2022 22:08 sddm-helper pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
19/04/2022 22:08 systemd Finished Update XDG user dir configuration.
19/04/2022 22:08 systemd Startup finished in 187ms.
19/04/2022 22:08 sddm-helper pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
19/04/2022 22:08 audit USER_START pid=818 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="dislok" exe="/usr/lib/sddm/sddm-helper" hostname=dislok-ms addr=? terminal=/dev/tty2 res=success'
19/04/2022 22:08 sddm-helper Starting: "/usr/share/sddm/scripts/wayland-session /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland"
19/04/2022 22:08 sddm-helper Jumping to VT 2
19/04/2022 22:08 sddm-helper VT mode didn't need to be fixed
19/04/2022 22:08 sddm Session started
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.32' (uid=1000 pid=833 comm="/usr/bin/startplasma-wayland")
19/04/2022 22:08 audit BPF prog-id=23 op=LOAD
19/04/2022 22:08 audit BPF prog-id=24 op=LOAD
19/04/2022 22:08 audit BPF prog-id=25 op=LOAD
19/04/2022 22:08 systemd Starting Locale Service...
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.freedesktop.locale1'
19/04/2022 22:08 systemd Started Locale Service.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.freedesktop.systemd1'
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating service name='org.kde.KSplash' requested by ':1.0' (uid=1000 pid=833 comm="/usr/bin/startplasma-wayland")
19/04/2022 22:08 systemd Reloading.
19/04/2022 22:08 klauncher Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
19/04/2022 22:08 klauncher Icon theme "Cobalt" not found.
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.kde.KSplash'
19/04/2022 22:08 ksplashqml Icon theme "Cobalt" not found.
19/04/2022 22:08 systemd NetworkManager-dispatcher.service: Deactivated successfully.
19/04/2022 22:08 audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 NetworkManager <info> [1650402493.8805] agent-manager: agent[68b539e83e22b023,:1.35/org.kde.plasma.networkmanagement/1000]: agent registered
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating via systemd: service name='ca.desrt.dconf' unit='dconf.service' requested by ':1.11' (uid=1000 pid=942 comm="/usr/bin/kded5")
19/04/2022 22:08 systemd Starting User preferences database...
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'ca.desrt.dconf'
19/04/2022 22:08 systemd Started User preferences database.
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating via systemd: service name='org.kde.ActivityManager' unit='plasma-kactivitymanagerd.service' requested by ':1.14' (uid=1000 pid=959 comm="/usr/lib/org_kde_powerdevil")
19/04/2022 22:08 systemd Created slice User Background Tasks Slice.
19/04/2022 22:08 systemd Starting KActivityManager Activity manager Service...
19/04/2022 22:08 kwalletd5 Icon theme "Cobalt" not found.
19/04/2022 22:08 systemd Starting Sound Service...
19/04/2022 22:08 dbus-daemon [system] Activating service name='org.kde.powerdevil.discretegpuhelper' requested by ':1.36' (uid=1000 pid=959 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.kde.ActivityManager'
19/04/2022 22:08 systemd Started KActivityManager Activity manager Service.
19/04/2022 22:08 polkitd Registered Authentication Agent for unix-session:2 (system bus name :1.40 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.41' (uid=1000 pid=1004 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
19/04/2022 22:08 systemd Starting RealtimeKit Scheduling Policy Service...
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 rtkit-daemon Successfully called chroot.
19/04/2022 22:08 systemd Started RealtimeKit Scheduling Policy Service.
19/04/2022 22:08 rtkit-daemon Successfully dropped privileges.
19/04/2022 22:08 rtkit-daemon Successfully limited resources.
19/04/2022 22:08 rtkit-daemon Canary thread running.
19/04/2022 22:08 rtkit-daemon Running.
19/04/2022 22:08 rtkit-daemon Watchdog thread running.
19/04/2022 22:08 rtkit-daemon Successfully made thread 1004 of process 1004 owned by '1000' high priority at nice level -11.
19/04/2022 22:08 rtkit-daemon Supervising 1 threads of 1 processes of 1 users.
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.kde.powerdevil.discretegpuhelper'
19/04/2022 22:08 dbus-daemon [system] Activating service name='org.kde.powerdevil.chargethresholdhelper' requested by ':1.36' (uid=1000 pid=959 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.kde.powerdevil.chargethresholdhelper'
19/04/2022 22:08 dbus-daemon [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.36' (uid=1000 pid=959 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service' requested by ':1.51' (uid=1000 pid=992 comm="/usr/lib/DiscoverNotifier")
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
19/04/2022 22:08 systemd Starting PackageKit Daemon...
19/04/2022 22:08 PackageKit daemon start
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.28' (uid=1000 pid=1010 comm="/usr/bin/matray --delay")
19/04/2022 22:08 systemd Starting Accessibility services bus...
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.a11y.Bus'
19/04/2022 22:08 systemd Started Accessibility services bus.
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.freedesktop.PackageKit'
19/04/2022 22:08 systemd Started PackageKit Daemon.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=packagekit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 at-spi-bus-launcher dbus-daemon[1093]: Activating service name='org.a11y.atspi.Registry' requested by ':1.2' (uid=1000 pid=862 comm="/usr/lib/kf5/klauncher --fd=9")
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.24' (uid=1000 pid=1010 comm="/usr/bin/matray --delay")
19/04/2022 22:08 systemd Starting Virtual filesystem service...
19/04/2022 22:08 at-spi-bus-launcher dbus-daemon[1093]: Successfully activated service 'org.a11y.atspi.Registry'
19/04/2022 22:08 at-spi-bus-launcher SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.gtk.vfs.Daemon'
19/04/2022 22:08 systemd Started Virtual filesystem service.
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating via systemd: service name='org.freedesktop.portal.Desktop' unit='xdg-desktop-portal.service' requested by ':1.24' (uid=1000 pid=1010 comm="/usr/bin/matray --delay")
19/04/2022 22:08 systemd Starting Portal service...
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating service name='org.freedesktop.Notifications' requested by ':1.26' (uid=1000 pid=989 comm="/usr/lib/kdeconnectd")
19/04/2022 22:08 rtkit-daemon Successfully made thread 1136 of process 1004 owned by '1000' RT at priority 5.
19/04/2022 22:08 rtkit-daemon Supervising 2 threads of 1 processes of 1 users.
19/04/2022 22:08 rtkit-daemon Successfully made thread 1137 of process 1004 owned by '1000' RT at priority 5.
19/04/2022 22:08 rtkit-daemon Supervising 3 threads of 1 processes of 1 users.
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating via systemd: service name='org.freedesktop.portal.Documents' unit='xdg-document-portal.service' requested by ':1.43' (uid=1000 pid=1127 comm="/usr/lib/xdg-desktop-portal")
19/04/2022 22:08 systemd Starting flatpak document portal service...
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating via systemd: service name='org.freedesktop.impl.portal.PermissionStore' unit='xdg-permission-store.service' requested by ':1.44' (uid=1000 pid=1140 comm="/usr/lib/xdg-document-portal")
19/04/2022 22:08 systemd Starting sandboxed app permission store...
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
19/04/2022 22:08 systemd Started sandboxed app permission store.
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.freedesktop.portal.Documents'
19/04/2022 22:08 systemd Started flatpak document portal service.
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.kde' unit='plasma-xdg-desktop-portal-kde.service' requested by ':1.43' (uid=1000 pid=1127 comm="/usr/lib/xdg-desktop-portal")
19/04/2022 22:08 systemd Starting Xdg Desktop Portal For KDE...
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.freedesktop.impl.portal.desktop.kde'
19/04/2022 22:08 systemd Started Xdg Desktop Portal For KDE.
19/04/2022 22:08 xdg-desktop-portal-kde xdp-kde: Desktop portal registered successfully
19/04/2022 22:08 xdg-desktop-portal-kde Icon theme "Cobalt" not found.
19/04/2022 22:08 xdg-desktop-portal-kde xdp-kde-wayland-integration: Registry initialized
19/04/2022 22:08 xdg-desktop-portal-kde xdp-kde-wayland-integration: Adding output:
19/04/2022 22:08 xdg-desktop-portal-kde xdp-kde-wayland-integration: manufacturer: "Hewlett Packard"
19/04/2022 22:08 xdg-desktop-portal-kde xdp-kde-wayland-integration: model: "HP 2011/CNC128PGJM"
19/04/2022 22:08 xdg-desktop-portal-kde xdp-kde-wayland-integration: resolution: QSize(1600, 900)
19/04/2022 22:08 systemd Started PipeWire Multimedia Service.
19/04/2022 22:08 systemd Started PipeWire Media Session Manager.
19/04/2022 22:08 rtkit-daemon Successfully made thread 1165 of process 1165 owned by '1000' high priority at nice level -11.
19/04/2022 22:08 rtkit-daemon Supervising 4 threads of 2 processes of 1 users.
19/04/2022 22:08 rtkit-daemon Successfully made thread 1167 of process 1166 owned by '1000' RT at priority 20.
19/04/2022 22:08 rtkit-daemon Supervising 5 threads of 3 processes of 1 users.
19/04/2022 22:08 rtkit-daemon Successfully made thread 1168 of process 1165 owned by '1000' RT at priority 20.
19/04/2022 22:08 rtkit-daemon Supervising 6 threads of 3 processes of 1 users.
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.freedesktop.portal.Desktop'
19/04/2022 22:08 systemd Started Portal service.
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.62' (uid=1000 pid=1004 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
19/04/2022 22:08 systemd Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
19/04/2022 22:08 pulseaudio stat('/etc/pulse/default.pa.d'): No such file or directory
19/04/2022 22:08 systemd Started Sound Service.
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.9' (uid=1000 pid=942 comm="/usr/bin/kded5")
19/04/2022 22:08 systemd Starting Bluetooth OBEX service...
19/04/2022 22:08 obexd OBEX daemon 5.64
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.bluez.obex'
19/04/2022 22:08 systemd Started Bluetooth OBEX service.
19/04/2022 22:08 dbus-daemon [system] Activating service name='org.kde.kded.smart' requested by ':1.35' (uid=1000 pid=942 comm="/usr/bin/kded5") (using servicehelper)
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.kde.kded.smart'
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.freedesktop.Notifications'
19/04/2022 22:08 systemd Stopping User Manager for UID 962...
19/04/2022 22:08 systemd Activating special unit Exit the Session...
19/04/2022 22:08 systemd Stopped target Main User Target.
19/04/2022 22:08 systemd Stopping D-Bus User Message Bus...
19/04/2022 22:08 systemd Stopped D-Bus User Message Bus.
19/04/2022 22:08 systemd Removed slice User Core Session Slice.
19/04/2022 22:08 systemd Stopped target Basic System.
19/04/2022 22:08 systemd Stopped target Paths.
19/04/2022 22:08 systemd Stopped target Sockets.
19/04/2022 22:08 systemd Stopped target Timers.
19/04/2022 22:08 systemd Closed D-Bus User Message Bus Socket.
19/04/2022 22:08 systemd Closed GnuPG network certificate management daemon.
19/04/2022 22:08 systemd Closed GCR ssh-agent wrapper.
19/04/2022 22:08 systemd Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
19/04/2022 22:08 systemd Closed GnuPG cryptographic agent and passphrase cache (restricted).
19/04/2022 22:08 systemd Closed GnuPG cryptographic agent (ssh-agent emulation).
19/04/2022 22:08 systemd Closed GnuPG cryptographic agent and passphrase cache.
19/04/2022 22:08 systemd Closed p11-kit server.
19/04/2022 22:08 systemd Closed PipeWire Multimedia System Socket.
19/04/2022 22:08 systemd Closed Sound System.
19/04/2022 22:08 systemd Removed slice User Application Slice.
19/04/2022 22:08 systemd Reached target Shutdown.
19/04/2022 22:08 systemd Finished Exit the Session.
19/04/2022 22:08 systemd Reached target Exit the Session.
19/04/2022 22:08 systemd pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
19/04/2022 22:08 systemd user@962.service: Deactivated successfully.
19/04/2022 22:08 systemd Stopped User Manager for UID 962.
19/04/2022 22:08 audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel kauditd_printk_skb: 14 callbacks suppressed
19/04/2022 22:08 kernel audit: type=1131 audit(1650402499.970:145): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Stopping User Runtime Directory /run/user/962...
19/04/2022 22:08 systemd run-user-962.mount: Deactivated successfully.
19/04/2022 22:08 systemd user-runtime-dir@962.service: Deactivated successfully.
19/04/2022 22:08 systemd Stopped User Runtime Directory /run/user/962.
19/04/2022 22:08 audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1131 audit(1650402499.977:146): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 systemd Removed slice User Slice of UID 962.
19/04/2022 22:08 systemd user-962.slice: Consumed 1.112s CPU time.
19/04/2022 22:08 nmbd [2022/04/19 22:08:29.820488, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
19/04/2022 22:08 nmbd *****
19/04/2022 22:08 nmbd Samba name server DISLOK-MS is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.11
19/04/2022 22:08 nmbd [2022/04/19 22:08:29.820604, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
19/04/2022 22:08 nmbd Samba name server DISLOK-MS is now a local master browser for workgroup WORKGROUP on subnet 192.168.122.1
19/04/2022 22:08 systemd systemd-hostnamed.service: Deactivated successfully.
19/04/2022 22:08 audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1131 audit(1650402513.317:147): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit BPF prog-id=0 op=UNLOAD
19/04/2022 22:08 kernel audit: type=1334 audit(1650402513.464:148): prog-id=0 op=UNLOAD
19/04/2022 22:08 kernel audit: type=1334 audit(1650402513.464:149): prog-id=0 op=UNLOAD
19/04/2022 22:08 kernel audit: type=1334 audit(1650402513.464:150): prog-id=0 op=UNLOAD
19/04/2022 22:08 systemd systemd-timedated.service: Deactivated successfully.
19/04/2022 22:08 audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1131 audit(1650402513.614:151): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1334 audit(1650402513.634:152): prog-id=0 op=UNLOAD
19/04/2022 22:08 kernel audit: type=1334 audit(1650402513.634:153): prog-id=0 op=UNLOAD
19/04/2022 22:08 kernel audit: type=1334 audit(1650402513.634:154): prog-id=0 op=UNLOAD
19/04/2022 22:08 PackageKit get-updates transaction /1_daceabdc from uid 1000 finished with success after 209ms
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating service name='org.manjaro.pamac.manager' requested by ':1.18' (uid=1000 pid=957 comm="/usr/bin/plasmashell")
19/04/2022 22:08 PackageKit get-updates transaction /2_cabcdcca from uid 1000 finished with success after 1ms
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.74' (uid=1000 pid=992 comm="/usr/lib/DiscoverNotifier")
19/04/2022 22:08 systemd Reached target User and Group Name Lookups.
19/04/2022 22:08 audit BPF prog-id=26 op=LOAD
19/04/2022 22:08 systemd Starting Accounts Service...
19/04/2022 22:08 kernel audit: type=1334 audit(1650402515.467:155): prog-id=26 op=LOAD
19/04/2022 22:08 accounts-daemon started daemon version 22.08.0
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.freedesktop.Accounts'
19/04/2022 22:08 systemd Started Accounts Service.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1130 audit(1650402515.500:156): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.manjaro.pamac.manager'
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.76' (uid=1000 pid=1289 comm="/usr/bin/pamac-manager --gapplication-service")
19/04/2022 22:08 systemd Starting Pamac Daemon...
19/04/2022 22:08 dbus-daemon [system] Successfully activated service 'org.manjaro.pamac.daemon'
19/04/2022 22:08 systemd Started Pamac Daemon.
19/04/2022 22:08 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 user@1000.service gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
19/04/2022 22:08 dbus-daemon [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
19/04/2022 22:08 pulseaudio GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
19/04/2022 22:08 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.81' (uid=0 pid=1374 comm="/usr/lib/polkit-1/polkit-agent-helper-1 dislok")
19/04/2022 22:08 polkit-agent-helper-1 pam_systemd_home(polkit-1:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
19/04/2022 22:08 systemd-timesyncd Timed out waiting for reply from 197.224.66.40:123 (2.manjaro.pool.ntp.org).
19/04/2022 22:08 systemd-timesyncd Initial synchronization to time server 196.200.160.123:123 (2.manjaro.pool.ntp.org).
19/04/2022 22:08 xdg-desktop-portal-kde xdp-kde-background: GetAppState called: no parameters
19/04/2022 22:08 audit USER_AUTH pid=1374 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="dislok" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 audit USER_ACCT pid=1374 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="dislok" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel kauditd_printk_skb: 1 callbacks suppressed
19/04/2022 22:08 kernel audit: type=1100 audit(1650402528.027:158): pid=1374 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="dislok" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 kernel audit: type=1101 audit(1650402528.027:159): pid=1374 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="dislok" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
19/04/2022 22:08 polkitd Operator of unix-session:2 successfully authenticated as unix-user:dislok to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.76 [/usr/bin/pamac-manager --gapplication-service] (owned by unix-user:dislok)
19/04/2022 22:08 PackageKit get-updates transaction /3_ebcdaade from uid 1000 finished with success after 203ms
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.54' (uid=1000 pid=1289 comm="/usr/bin/pamac-manager --gapplication-service")
19/04/2022 22:08 systemd Starting Virtual filesystem metadata service...
19/04/2022 22:08 dbus-daemon [session uid=1000 pid=842] Successfully activated service 'org.gtk.vfs.Metadata'
19/04/2022 22:08 systemd Started Virtual filesystem metadata service.
19/04/2022 22:09 systemd Started Falkon - Web Browser.
19/04/2022 22:09 systemd systemd-localed.service: Deactivated successfully.
19/04/2022 22:09 audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:09 kernel audit: type=1131 audit(1650402546.980:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:09 audit BPF prog-id=0 op=UNLOAD
19/04/2022 22:09 kernel audit: type=1334 audit(1650402547.117:161): prog-id=0 op=UNLOAD
19/04/2022 22:09 kernel audit: type=1334 audit(1650402547.117:162): prog-id=0 op=UNLOAD
19/04/2022 22:09 kernel audit: type=1334 audit(1650402547.117:163): prog-id=0 op=UNLOAD
19/04/2022 22:09 xdg-desktop-portal-kde xdp-kde-background: GetAppState called: no parameters
19/04/2022 22:10 systemd libvirtd.service: Deactivated successfully.
19/04/2022 22:10 audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:10 systemd libvirtd.service: Unit process 721 (dnsmasq) remains running after unit stopped.
19/04/2022 22:10 systemd libvirtd.service: Unit process 722 (dnsmasq) remains running after unit stopped.
19/04/2022 22:10 kernel audit: type=1131 audit(1650402605.039:164): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:10 xdg-desktop-portal-kde xdp-kde-background: GetAppState called: no parameters
19/04/2022 22:10 systemd Started KSystemLog - System Log Viewer.
19/04/2022 22:10 audit USER_AUTH pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 audit USER_ACCT pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 audit CRED_ACQ pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 audit USER_START pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 su (to root) dislok on pts/2
19/04/2022 22:10 su pam_unix(su:session): session opened for user root(uid=0) by (uid=1000)
19/04/2022 22:10 kernel audit: type=1100 audit(1650402651.826:165): pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 kernel audit: type=1101 audit(1650402651.826:166): pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 kernel audit: type=1103 audit(1650402651.826:167): pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 kernel audit: type=1105 audit(1650402651.826:168): pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 su pam_unix(su:session): session closed for user root
19/04/2022 22:10 audit USER_END pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 audit CRED_DISP pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 kernel audit: type=1106 audit(1650402651.829:169): pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 kernel audit: type=1104 audit(1650402651.829:170): pid=1562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 audit USER_AUTH pid=1565 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 audit USER_ACCT pid=1565 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 audit CRED_ACQ pid=1565 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 audit USER_START pid=1565 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 kernel audit: type=1100 audit(1650402651.949:171): pid=1565 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 kernel audit: type=1101 audit(1650402651.949:172): pid=1565 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 kernel audit: type=1103 audit(1650402651.949:173): pid=1565 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:10 kernel audit: type=1105 audit(1650402651.949:174): pid=1565 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/2 res=success'
19/04/2022 22:11 xdg-desktop-portal-kde xdp-kde-background: GetAppState called: no parameters
19/04/2022 22:11 systemd Started Spectacle - Screenshot Capture Utility.
19/04/2022 22:12 xdg-desktop-portal-kde xdp-kde-background: GetAppState called: no parameters
19/04/2022 22:12 systemd app-org.kde.spectacle-e2073bd23ae14167bc257c3f7ee541f1.scope: Consumed 3.483s CPU time.
19/04/2022 22:12 kioslave5 Icon theme "Cobalt" not found.
19/04/2022 22:13 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.13' (uid=0 pid=519 comm="/usr/lib/snapd/snapd")
19/04/2022 22:13 audit BPF prog-id=27 op=LOAD
19/04/2022 22:13 audit BPF prog-id=28 op=LOAD
19/04/2022 22:13 audit BPF prog-id=29 op=LOAD
19/04/2022 22:13 systemd Starting Time & Date Service...
19/04/2022 22:13 kernel audit: type=1334 audit(1650402785.066:175): prog-id=27 op=LOAD
19/04/2022 22:13 kernel audit: type=1334 audit(1650402785.066:176): prog-id=28 op=LOAD
19/04/2022 22:13 kernel audit: type=1334 audit(1650402785.066:177): prog-id=29 op=LOAD
19/04/2022 22:13 dbus-daemon [system] Successfully activated service 'org.freedesktop.timedate1'
19/04/2022 22:13 systemd Started Time & Date Service.
19/04/2022 22:13 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:13 kernel audit: type=1130 audit(1650402785.099:178): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:13 xdg-desktop-portal-kde xdp-kde-background: GetAppState called: no parameters
19/04/2022 22:13 PackageKit uid 1000 is trying to obtain org.freedesktop.packagekit.system-sources-refresh auth (only_trusted:0)
19/04/2022 22:13 PackageKit uid 1000 obtained auth for org.freedesktop.packagekit.system-sources-refresh
19/04/2022 22:13 PackageKit refresh-cache transaction /4_eaabeaab from uid 1000 finished with success after 0ms
19/04/2022 22:13 PackageKit get-updates transaction /5_ccbadecd from uid 1000 finished with success after 1ms
19/04/2022 22:13 systemd systemd-timedated.service: Deactivated successfully.
19/04/2022 22:13 audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:13 kernel audit: type=1131 audit(1650402815.133:179): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
19/04/2022 22:13 audit BPF prog-id=0 op=UNLOAD
19/04/2022 22:13 kernel audit: type=1334 audit(1650402815.160:180): prog-id=0 op=UNLOAD
19/04/2022 22:13 kernel audit: type=1334 audit(1650402815.160:181): prog-id=0 op=UNLOAD
19/04/2022 22:13 kernel audit: type=1334 audit(1650402815.160:182): prog-id=0 op=UNLOAD
19/04/2022 22:14 xdg-desktop-portal-kde xdp-kde-background: GetAppState called: no parameters
19/04/2022 22:15 xdg-desktop-portal-kde xdp-kde-background: GetAppState called: no parameters
