CPU Acceleration
Weird question but i need to pass through my gpu to qemu, but i only have one gpu, so i was wondering if there is a way to run the graphics from the cpu, using it as a renderer. I hope this explains my question adequately enough.
Also here are my system specs;
CPU i7 6700t - 2.8Ghz Boost 3.6Ghz 4 Core
RAM 8Gb DDR4
GPU GTX 960 oc
That cpu has integrated graphics you can just use those.
IntelĀ® HD Graphics 530
Problem, it is prebuilt, a Alienware alpha r2, so the inbuilt are disabled (I think)
Sorry for late reply aswell
check the firmware settings, you can usually configure that yourself
Im a bit of a noob, how lol
talk tomorrow
check the literature that came with your system please or the alienware website to find out how, some things you really have to look up and learn for yourself
Ok thanks
