Could not satisfy dependencies:
- removing lib32-libffi breaks dependency ‘lib32-libffi’ required by lib32-llvm-libs
- removing lib32-libcap breaks dependency ‘lib32-libcap’ required by lib32-systemd
remove the things that require them as well
remove what is “required by” as well
these are present and cause the refusal to remove what you want to remove:
lib32-libffi
and lib32-libcap
in this case
This seemed to work: pacman -Rns $(pacman -Qtdq)
