Thank you for the help everyone. It worked. When I launch Gimp I can see the new splash screen.
If you want to change the GIMP splash, and survive a future update, then place it inside
~/.config/GIMP/2.10/splashes
… that folder you can create, keep those custom configurations for another install too.
If you install the developer version of GIMP then use
~/.config/GIMP/2.99/splashes
Work in your home directory, always !
Thanks!
