Could not Initialize GLX
Howdy,
Its my first post here. I have searched for answers to this. Here and in the Arch forums. I found a similar issue from an Arch user, and it appeared to be Graphics issues (this user had Nvidia drivers installed) I don't appear to have Nvidia drivers. I do think I'm looking at a graphics issue here.
Brand new installation; The only changes I've made are in troubleshooting this. Any help would be great.
The error I get when I try to run the Eve launcher is first; followed by system configuration data which I see regularly requested on these forums. I'd be happy to provide more info should anyone need it to help me.
[glen@freedomLAP evelauncher]$ sh ./evelauncher.sh
QObject::startTimer: Timers can only be used with threads started with QThread
Could not initialize GLX
./evelauncher.sh: line 14: 16827 Aborted                 (core dumped) "$dirname/$appname" "$@"
My System's setup:
inxi -Fxz
  Host: freedomLAP Kernel: 5.4.6-2-MANJARO x86_64 bits: 64 compiler: gcc
  v: 9.2.0 Desktop: KDE Plasma 5.17.4 Distro: Manjaro Linux
  Type: Laptop System: TOSHIBA product: Satellite P55W-C v: PSPVTU-008001
  serial: <filter>
  Mobo: FF40 model: 0693 v: 2.0 serial: <filter> UEFI: INSYDE v: 1.20
  date: 10/07/2015
  ID-1: BAT0 charge: 37.0 Wh condition: 37.0/45.5 Wh (81%)
  model: TKBSS G71C000JW110 status: Unknown
  Topology: Dual Core model: Intel Core i7-6500U bits: 64 type: MT MCP
  arch: Skylake rev: 3 L2 cache: 4096 KiB
  bogomips: 20810
  Speed: 800 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 800 2: 800
  3: 800 4: 800
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Toshiba
  driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.20.6 driver: intel unloaded: modesetting
  resolution: 2560x1440~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
  v: 4.6 Mesa 19.3.1 direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Toshiba
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3
  Sound Server: ALSA v: k5.4.6-2-MANJARO
  Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3040
  bus ID: 01:00.0
  Local Storage: total: 894.25 GiB used: 64.92 GiB (7.3%)
  ID-1: /dev/sda vendor: SanDisk model: Ultra II 960GB size: 894.25 GiB
  ID-1: / size: 671.86 GiB used: 64.92 GiB (9.7%) fs: ext4 dev: /dev/sda1
  ID-2: swap-1 size: 14.65 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
  System Temperatures: cpu: 48.0 C mobo: N/A
  Processes: 188 Uptime: 2d 54m Memory: 11.56 GiB used: 2.11 GiB (18.2%)
  Init: systemd Compilers: gcc: 9.2.0 clang: 9.0.0 Shell: bash v: 5.0.11
  inxi: 3.0.37
lspci:
lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation Skylake GT2 [HD Graphics 520] (rev 07)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Network controller: Intel Corporation Wireless 7265 (rev 61)
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
---Glen
This is a Windows game and looking here gives me the impression that this is unofficial and/or just a wine wrapper. After finding this game on Lutris reveals that it is a Steam game, so just install it from Steam instead and see if it launches. Make sure you enable Steam Play for unsupported titles in the Steam settings.
Hi,
Thanks for replying. I'll try to run it on steam. Even steam has issues though - there are things which are not displaying correctly on steam. I'm thinking the issue is going to persist. I'll update after attempting your solution. Thanks.
No problem and take your time!
