Hello.
I have a Huion Kamvas Pro 16 (2.5K) pen display and want to use it on Manjaro (using X11). I have found in the AUR a package download that has already been converted from .deb to Arch (June 8, 2026). I was curious if anyone has downloaded/used this package because I heard there have been some security issues with the AUR. I’m not sure it’s safe to download, and I’m not smart enough to fix my computer if something would go wrong. I’d appreciate any advice or recommendations to be able to use my pen display with Manjaro.
Thank you.
Welcome to the forum!
zelmarose:
Save the script below in your ~/.local/bin folder…
#!/usr/bin/env bash
# Pulls the live package list from the official Arch Linux HedgeDoc note.
LIST_URL="https://md.archlinux.org/s/SxbqukK6IA"
START_DATE=${START_DATE:-2026-01-01}
END_DATE=${END_DATE:-2026-06-12}
PACMAN_LOG_GLOB=${PACMAN_LOG_GLOB:-/var/log/pacman.log*}
CURRENT_FOUND=()
HISTORICAL_FOUND=()
LOG_WARNINGS=()
# 1. Fetch and parse the live infected package list
echo "Fetching infected package list from $LIST_URL..."
raw=$(curl -fsSL "$LIST_URL") || { echo "ERROR: failed to fetch $LIST_URL"; exit 1; }
mapfile -t INFECTED_PKGS < <(
echo "$raw" \
| sed 's/<[^>]*>//g' \
| grep -E '^[a-z0-9][a-z0-9_.+\-]*[a-z0-9]$' \
| sort -u
if [[ ${#INFECTED_PKGS[@]} -eq 0 ]]; then
echo "ERROR: parsed 0 packages — something went wrong with the fetch/parse."
exit 1
fi
# Helper functions
date_in_window() {
local date_value=$1
[[ "$date_value" < "$START_DATE" ]] && return 1
[[ "$date_value" > "$END_DATE" ]] && return 1
return 0
install_date_in_window() {
local raw_date=$1 normalized_date
normalized_date=$(LC_ALL=C date -d "$raw_date" +%F 2>/dev/null) || return 1
date_in_window "$normalized_date"
read_pacman_log_file() {
local file=$1
case "$file" in
*.gz)
if command -v gzip >/dev/null 2>&1; then
gzip -cd -- "$file"
else
LOG_WARNINGS+=("Skipped $file: gzip is not installed")
fi
*.xz)
if command -v xz >/dev/null 2>&1; then
xz -cd -- "$file"
else
LOG_WARNINGS+=("Skipped $file: xz is not installed")
fi
*.zst)
if command -v zstdcat >/dev/null 2>&1; then
zstdcat -- "$file"
else
LOG_WARNINGS+=("Skipped $file: zstdcat is not installed")
fi
*.bz2)
if command -v bzip2 >/dev/null 2>&1; then
bzip2 -cd -- "$file"
else
LOG_WARNINGS+=("Skipped $file: bzip2 is not installed")
fi
cat -- "$file"
esac
scan_pacman_logs() {
local file
local log_files=()
for file in $PACMAN_LOG_GLOB; do
[[ -e "$file" ]] && log_files+=("$file")
done
if [[ ${#log_files[@]} -eq 0 ]]; then
LOG_WARNINGS+=("No pacman log files matched: $PACMAN_LOG_GLOB")
return 0
fi
printf 'PKG\t%s\n' "${INFECTED_PKGS[@]}"
for file in "${log_files[@]}"; do
[[ -r "$file" ]] || { LOG_WARNINGS+=("Skipped $file: not readable"); continue; }
read_pacman_log_file "$file" | sed $'s/^/LOG\t/'
done
} | awk -v start="$START_DATE" -v end="$END_DATE" -F '\t' '
$1 == "PKG" {
infected[$2] = 1
next
$1 == "LOG" {
line = $2
date = substr(line, 2, 10)
if (date < start || date > end) next
msg = line
sub(/^\[[^]]+\] \[ALPM\] /, "", msg)
split(msg, fields, " ")
action = fields[1]
pkg = fields[2]
if ((action == "installed" || action == "upgraded" || action == "reinstalled") && infected[pkg]) {
key = pkg SUBSEP date SUBSEP action SUBSEP line
if (!seen[key]++) {
printf "%s\t%s\t%s\t%s\n", pkg, date, action, line
' | sort -u
print_pkg_list() {
local -n arr=$1
local pkg
for pkg in "${arr[@]}"; do
echo " - $pkg"
done
# 2. Checks
echo
echo "Checking for infected AUR packages (${#INFECTED_PKGS[@]} total)..."
echo "Campaign window: $START_DATE through $END_DATE"
echo
echo "Checking currently installed foreign packages..."
while IFS= read -r pkg; do
install_date=$(LC_ALL=C pacman -Qi -- "$pkg" 2>/dev/null | awk -F ': ' '/^Install Date/ { print $2; exit }')
if [[ -n "$install_date" ]] && install_date_in_window "$install_date"; then
CURRENT_FOUND+=("$pkg (Install Date: $install_date)")
fi
done < <(pacman -Qmq "${INFECTED_PKGS[@]}" 2>/dev/null)
if [[ ${#CURRENT_FOUND[@]} -eq 0 ]]; then
echo " Clean: no currently installed known infected package has an install date in the campaign window."
else
echo " WARNING: ${#CURRENT_FOUND[@]} currently installed possibly infected package(s):"
print_pkg_list CURRENT_FOUND
fi
echo
echo "Checking historical pacman logs..."
while IFS=$'\t' read -r pkg date action line; do
HISTORICAL_FOUND+=("$pkg ($action on $date) :: $line")
done < <(scan_pacman_logs)
if [[ ${#HISTORICAL_FOUND[@]} -eq 0 ]]; then
echo " Clean: no known infected package install/upgrade/reinstall events found in pacman logs during the campaign window."
else
echo " WARNING: ${#HISTORICAL_FOUND[@]} historical pacman log event(s) matched:"
print_pkg_list HISTORICAL_FOUND
fi
if [[ ${#LOG_WARNINGS[@]} -gt 0 ]]; then
echo
echo "Log scan notes:"
print_pkg_list LOG_WARNINGS
fi
echo
if [[ ${#CURRENT_FOUND[@]} -eq 0 && ${#HISTORICAL_FOUND[@]} -eq 0 ]]; then
echo "Clean: no matches found by current-package or historical-log checks."
else
echo "WARNING: matches were found. Review the package build files/cache and consider incident-response steps."
fi
echo
… and give it execute permission. On my system, I’ve named it aur-malware-check.
chmod 700 .local/bin/aur-malware-check
Then execute the script from your regular user account…
aur-malware-check
This will tell you whether anything you have or recently had installed was in the list of infected PKGBUILDs on the AUR.
It wasn’t and the current pkgbuild looks perfectly safe to me. I think you are good to go in this case.
Many binary AUR packages are unpacked from a .deb, .rpm or .AppImage. Perfectly normal.
@Teo @Yochanan
Thank you all for your replies. I’m going to download it now.
I saved the script too, thank you. And thanks for the welcome!
system
Closed
20 June 2026 23:18
6
