Hi everyone !
My system is 1 ssd with Manjaro (Bios)
and one hdd with ububtu (Bios) too.
The way to convert to (u)efi is to add /efi partition , disable the CSM , change BIOS boot mode to “UEFI only” , and that’s it ?
inxi -p
Partition: ID-1: / size: 36.41 GiB used: 20.11 GiB (55.2%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 68.28 GiB used: 6.11 GiB (8.9%) fs: ext4 dev: /dev/sda6
ID-3: /run/timeshift/backup size: 41.58 GiB used: 28.67 GiB (69.0%) fs: ext4 dev: /dev/sdb7
[joe@joe-Manjaro ~]$ cat /proc/partitions
parted -l
Model: ATA Patriot Burst (scsi)
Disk /dev/sda: 120GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 40,0GB 40,0GB primary ext4 boot
2 40,0GB 120GB 80,0GB extended
5 40,0GB 45,0GB 4998MB logical linux-swap(v1)
6 45,0GB 120GB 75,0GB logical ext4
Model: ATA WDC WD5000AAVS-0 (scsi)
Disk /dev/sdb: 500GB
Disk Flags:
1 1049kB 24,5GB 24,5GB primary ext4 boot
3 24,5GB 170GB 145GB primary ext4
2 170GB 500GB 331GB extended lba
7 170GB 215GB 45,6GB logical ext4
5 215GB 329GB 114GB logical ext4
6 329GB 500GB 171GB logical fat32
Thanx in advance!
joe-77:
No. If you have no good reason to change better stay in BIOS mode. For a clean UEFI installation your disks should be partitiioned in gpt for example.
A conversion is possible but prone to fail. If you have to ask how to do it then you probably are not experienced enough that we can recommend you to do it.
would you suggest a clean installation from the beginning?
Why do you want to switch, what are your reasons?
Very good question! We moved on to the next one!
I really thought it was better, more modern and that it has advantages over the “old” BIOS but I probably forget the saying “what works we do NOT change it”.
Exactly, don’t change something if everything is fine. I run my system in BIOS mode as well and have no reasons to change it even if I could.
I like the way you think! Thank you I will follow your advice!
Είμαι πραγματικά ευχαριστημένος!
(Happy to hear!)
Λογω κεκτημενης ταχυτητας εβαλα το Ελληνικο κειμενο αντι του google-translate !!!
Ασχετο αλλα η google εχει κανει πολυ καλη δουλεια στην μεταφραση!!
Να σαι καλα! καλη συνεχεια απο Θεσσαλονικη μερια !!!
Due to the acquired speed I put the Greek text instead of google-translate !!! : rofl:
Irrelevant but google has done a very good job in translation !!
Be well! good continuation from Thessaloniki !!!
what is this here
6 329GB 500GB 171GB logical fat32 <-- ?
process to get GPT & /boot/efi and UEFI options good on boot is not so simple
can you report
inxi -Fza
Kernel: 5.10.34-1-lts x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts
root=UUID=76f581c1-f4d3-4e5a-af7d-e20fb435b240 rw quiet apparmor=1
Desktop: MATE 1.24.2 info: mate-panel wm: marco 1.24.2 vt: 7
Type: Desktop Mobo: ASRock model: H81M-DGS R2.0 serial: <filter>
BIOS: American Megatrends v: P1.60 date: 07/23/2015
Info: Dual Core model: Intel Core i3-4150 bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
L2: 3 MiB
bogomips: 27992
Speed: 3499 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3499 2: 3499
3: 3499 4: 3499
Type: l1tf
Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
vendor: ASRock driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:041e
class-ID: 0300
Display: x11 server: X.org 1.20.11 compositor: marco v: 1.24.2 driver:
loaded: modesetting alternate: fbdev,intel,vesa
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: ASRock driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Sound Server-1: ALSA v: k5.10.34-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
vendor: ASRock driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 581.33 GiB used: 54.59 GiB (9.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: Burst size: 111.79 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 61.3 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000AAVS-00G9B0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 4C05 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Generic model: Flash Disk
size: 3.78 GiB block-size: physical: 512 B logical: 512 B rotation: SSD
serial: <filter> rev: 8.07 scheme: MBR
ID-1: / raw-size: 37.25 GiB size: 36.41 GiB (97.75%)
used: 19.12 GiB (52.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 69.88 GiB size: 68.28 GiB (97.71%)
used: 6.13 GiB (9.0%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 27.5 C mobo: 31.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1664 fan-3: 2468 fan-4: 0 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.28
Processes: 193 Uptime: 40m wakeups: 0 Memory: 7.45 GiB
used: 2.05 GiB (27.5%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: 1463 pacman: 1460 lib: 438 flatpak: 0
snap: 3 Shell: Bash v: 5.1.4 running-in: mate-terminal inxi: 3.3.04
About
That’s my hdd partition for data only.
I don’t remember why left fat32 formated!
system
Closed
29 May 2021 06:07
12
