Constante frizado en plasma y cierre del proceso de kwin_X11 plasmashell
Hola , todo venia bien hasta que empezó a frizarse el sistema y cerrarse el proceso que levanta el entorno , me refiero al compositor y al entorno en si.
Entorno Plasma
$ plasma shell
Compositor
$kwin_x11
Ambos después de un rato dejan de funcionar y debo ejecutarlos manualmente desde la terminal :
kwin_x11
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 180, resource id: 71303178, major code: 20 (GetProperty), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 181, resource id: 71303178, major code: 20 (GetProperty), minor code: 0
kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym “XF86EmojiPicker”
kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym “XF86Dictate”
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1982, resource id: 25165855, major code: 3 (GetWindowAttributes), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1983, resource id: 25165855, major code: 14 (GetGeometry), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1999, resource id: 25165863, major code: 3 (GetWindowAttributes), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2000, resource id: 25165863, major code: 14 (GetGeometry), minor code: 0
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce GT 710/PCIe/SSE2
OpenGL version string: 3.1.0 NVIDIA 470.141.03
OpenGL shading language version string: 1.40 NVIDIA via Cg compiler
Driver: NVIDIA
Driver version: 470.141.3
GPU class: Unknown
OpenGL version: 3.1
GLSL version: 1.40
X server version: 1.21.1
Linux kernel version: 5.15.71
Requires strict binding: no
GLSL shaders: yes
Texture NPOT support: yes
Virtual Machine: no
QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 12207, resource id: 8388820, major code: 54 (FreePixmap), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 12208, resource id: 8388821, major code: 60 (FreeGC), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 12209, resource id: 8388822, major code: 54 (FreePixmap), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 12210, resource id: 8388823, major code: 60 (FreeGC), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 12211, resource id: 8388824, major code: 54 (FreePixmap), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 12212, resource id: 8388825, major code: 60 (FreeGC), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 12213, resource id: 8388826, major code: 54 (FreePixmap), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 12214, resource id: 8388827, major code: 60 (FreeGC), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 12215, resource id: 8388828, major code: 54 (FreePixmap), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 12216, resource id: 8388829, major code: 60 (FreeGC), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 12217, resource id: 8388830, major code: 54 (FreePixmap), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 12218, resource id: 8388831, major code: 60 (FreeGC), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 12219, resource id: 8388816, major code: 54 (FreePixmap), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 12220, resource id: 8388817, major code: 60 (FreeGC), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 12221, resource id: 8388818, major code: 54 (FreePixmap), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 12222, resource id: 8388819, major code: 60 (FreeGC), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3397, resource id: 62914712, major code: 18 (ChangeProperty), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3410, resource id: 60817435, major code: 18 (ChangeProperty), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4458, resource id: 60817437, major code: 18 (ChangeProperty), minor code: 0
[GFX1-]: glxtest: VA-API test failed: process crashed. Please check your VA-API drivers.
[2022-10-07T00:07:33Z ERROR glean_core::metrics::ping] Invalid reason code startup for ping background-update
Missing chrome or resource URL: resource://gre/modules/UpdateListener.sys.mjs
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8881, resource id: 6291681, major code: 18 (ChangeProperty), minor code: 0
Optare de cambiar el entorno a xfce 4 hasta que lo solucionen.
(solucionado)
