Constant plasmashell error/warning "Unable to assign [undefined] to (...)" in Plasma 5.15
#1
Hello,
anyone has any solution to this nagging issue? Whenever an app, especially GTK one, is showing any window or user interacts with it there’s a ton of entries in logs related to 2 positions in plasmashell modules/files:
plasmashell[844]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:343: Unable to assign [undefined] to int
plasmashell[844]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:367: Unable to assign [undefined] to QString
Any one knows of a solution to this?
FYI I am running current (installed 18.0.2 and now updated to 18.0.3) KDE flavor of Manjaro:
  Host: MarKDE Kernel: 4.19.23-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 8.2.1 Desktop: KDE Plasma 5.15.0 Distro: Manjaro Linux
KDE packages:
$ pacman -Qs plasma
local/bluedevil 1:5.15.0-1 (plasma)
    Integrate the Bluetooth technology within KDE workspace and applications
local/breeze 5.15.0-1 (plasma)
    Artwork, styles and assets for the Breeze visual style for the Plasma
    Desktop
local/kactivitymanagerd 5.15.0-1 (plasma)
    System service to manage user's activities and track the usage patterns
local/kde-cli-tools 5.15.0-1 (plasma)
    Tools based on KDE Frameworks 5 to better interact with the system
local/kde-gtk-config 5.15.0-1 (plasma)
    GTK2 and GTK3 Configurator for KDE
local/kdecoration 5.15.0-1 (plasma)
    Plugin based library to create window decorations
local/kdeplasma-addons 5.15.0-1 (plasma)
    All kind of addons to improve your Plasma experience
local/kgamma5 5.15.0-1 (plasma)
    Adjust your monitor's gamma settings
local/khotkeys 5.15.0-1 (plasma)
    KHotKeys
local/kinfocenter 5.15.0-1 (plasma)
    A utility that provides information about a computer system
local/kmenuedit 5.15.0-1 (plasma)
    KDE menu editor
local/knetattach 5.15.0-1 (plasma)
    Wizard which makes it easier to integrate network resources with the
    Plasma Desktop
local/kscreen 5.15.0-1 (plasma)
    KDE's screen management software
local/kscreenlocker 5.15.0-1 (plasma)
    Library and components for secure lock screen architecture
local/ksshaskpass 5.15.0-1 (plasma)
    ssh-add helper that uses kwallet and kpassworddialog
local/ksysguard 5.15.0-1 (plasma)
    Track and control the processes running in your system
local/kwallet-pam 5.15.0-1 (plasma)
    KWallet PAM integration
local/kwayland-integration 5.15.0-1 (plasma)
    Provides integration plugins for various KDE frameworks for the wayland
    windowing system
local/kwin 5.15.0-1 (plasma)
    An easy to use, but flexible, composited Window Manager
local/kwrited 5.15.0-1 (plasma)
    KDE daemon listening for wall and write messages
local/libkscreen 5.15.0-1 (plasma)
    KDE screen management software
local/libksysguard 5.15.0-1 (plasma)
    Libraries for ksysguard
local/manjaro-settings-manager-kcm 0.5.5-3
    Manjaro Linux System Settings Tool (KCM for Plasma 5)
local/manjaro-settings-manager-knotifier 0.5.5-3
    Manjaro Linux System Settings Tool (Notifier for Plasma 5)
local/milou 5.15.0-1 (plasma)
    A dedicated search application built on top of Baloo
local/plasma-desktop 5.15.0-1 (plasma)
    KDE Plasma Desktop
local/plasma-framework 5.55.0-1 (kf5)
    Plasma library and runtime components based upon KF5 and Qt5
local/plasma-integration 5.15.0-1 (plasma)
    Qt Platform Theme integration plugins for the Plasma workspaces
local/plasma-nm 5.15.0-1 (plasma)
    Plasma applet written in QML for managing network connections
local/plasma-pa 5.15.0-1 (plasma)
    Plasma applet for audio volume management using PulseAudio
local/plasma-workspace 5.15.0-1 (plasma)
    KDE Plasma Workspace
local/plasma-workspace-wallpapers 5.15.0-1 (plasma)
    Additional wallpapers for the Plasma Workspace
local/plasma5-themes-breath 0.4.0-1
    breath theme for KDE Plasma 5
local/polkit-kde-agent 5.15.0-1 (plasma)
    Daemon providing a polkit authentication UI for KDE
local/powerdevil 5.15.0-1 (plasma)
    Manages the power consumption settings of a Plasma Shell
local/sddm-kcm 5.15.0-1 (plasma)
    KDE Config Module for SDDM
local/systemsettings 5.15.0-1 (plasma)
    KDE system manager for hardware, software, and workspaces
local/user-manager 5.15.0-1 (plasma)
    A simple system settings module to manage the users of your system
GTK packages:
$ pacman -Qs gtk
local/adwaita-maia-gtk3 20161221-1
    Adwaita theme with maia colors, gtk3-only version
local/at-spi2-atk 2.30.0-1
    A GTK+ module that bridges ATK to D-Bus at-spi
local/gtk-engine-murrine 0.98.2-3
    GTK2 engine to make your desktop look like a 'murrina', an italian word
    meaning the art glass works done by Venicians glass blowers.
local/gtk-engines 2.21.0-4
    Theme engines for GTK+ 2
local/gtk-theme-breath 5.9.0-1
    Breath widget theme for GTK 2 and 3
local/gtk-update-icon-cache 3.24.5-1
    GTK+ icon cache updater
local/gtk2 2.24.32-1
    GObject-based multi-platform GUI toolkit (legacy)
local/gtk2+extra 3.3.4-1
    GtkExtra is a useful set of widgets for creating GUI's for the Xwindows
    system using GTK+
local/gtk3 3.24.5-1
local/gtkmm3 3.24.0-1
    C++ bindings for GTK+ 3
local/lib32-gtk2 2.24.32-1
    GObject-based multi-platform GUI toolkit (legacy) (32-bit)
local/pamac 7.3.4-1
    A Gtk3 frontend for libalpm
local/python-gobject 3.30.4-1
    Python Bindings for GLib/GObject/GIO/GTK+
local/vte3 0.54.3-1
    Virtual Terminal Emulator widget for use with GTK3
local/webkit2gtk 2.22.6-1
    GTK+ Web content engine library
local/wxgtk-common 3.0.4-2
    Common libraries and headers for wxgtk2 and wxgtk3
local/wxgtk3 3.0.4-2
    GTK+3 implementation of wxWidgets API for GUI
local/xdg-desktop-portal-gtk 1.2.0-1
    A GTK+ backend for xdg-desktop-portal
local/xsane 0.999-3
    A GTK-based X11 frontend for SANE and plugin for Gimp.
#2
Whats in there?
cat /usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml
BTW - I’m using icon-only task manager so I dont seethe same … but I have some similars stemming from lock/clock/userdelegate from breeze theme (Ithink this has to do with me messing with lockscreen theme … will have to check further later)
And in that case … there are literally intries with ‘undefined’ in them:
            style: softwareRendering ? Text.Outline : undefined
            styleColor: softwareRendering ? ColorScope.backgroundColor : undefined
#3
AFAIK it’s some task management for the Qt framework to manage a lot of UI stuff in KDE/plasma… Though it is, it seems, quite an old piece of the KDE environment (as stated in the file):
 *   Copyright (C) 2012-2013 by Eike Hein <hein@kde.org>                   *
#4
Was that all of it? Cuz mine has dozens of lines
#5
Of course not… I’ve quoted only the first line :wink:
I believe those of importance would be:
$ awk '{if (( NR > 340 ) && ( NR <= 370 )) { print NR,$0 }}' /usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml341                     });
342                     toolTipDelegate.pidParent = Qt.binding(function() {
343                         return model.AppPid;
344                     });
345                     toolTipDelegate.windows = Qt.binding(function() {
346                         return model.WinIdList;
347                     });
348                     toolTipDelegate.isGroup = Qt.binding(function() {
349                         return model.IsGroupParent == true;
350                     });
351                     toolTipDelegate.icon = Qt.binding(function() {
352                         return model.decoration;
353                     });
354                     toolTipDelegate.launcherUrl = Qt.binding(function() {
355                         return model.LauncherUrlWithoutIcon;
356                     });
357                     toolTipDelegate.isLauncher = Qt.binding(function() {
358                         return model.IsLauncher == true;
359                     });
360                     toolTipDelegate.isMinimizedParent = Qt.binding(function() {
361                         return model.IsMinimized == true;
362                     });
363                     toolTipDelegate.displayParent = Qt.binding(function() {
364                         return model.display;
365                     });
366                     toolTipDelegate.genericName = Qt.binding(function() {
367                         return model.GenericName;
368                     });
369                     toolTipDelegate.virtualDesktopParent = Qt.binding(function() {
370                         return model.VirtualDesktop != undefined ? model.VirtualDesktop : 0;
and
$ awk '{if (( NR > 360 ) && ( NR <= 390 )) { print NR,$0 }}' /usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml361                         return model.IsMinimized == true;
362                     });
365                     });
368                     });
371                     });
372                     toolTipDelegate.isOnAllVirtualDesktopsParent = Qt.binding(function() {
373                         return model.IsOnAllVirtualDesktops == true;
374                     });
375                     toolTipDelegate.activitiesParent = Qt.binding(function() {
376                         return model.Activities;
377                     });
378
379                     toolTipDelegate.smartLauncherCountVisible = Qt.binding(function() {
380                         return plasmoid.configuration.smartLaunchersEnabled && task.smartLauncherItem && task.smartLauncherItem.countVisible;
381                     });
382                     toolTipDelegate.smartLauncherCount = Qt.binding(function() {
383                         return toolTipDelegate.smartLauncherCountVisible ? task.smartLauncherItem.count : 0;
384                     });
385                 }
386             }
387         }
388     }
389
390     Loader {
#6
This might be related to the kwin errors/warnings shown in logs/journals, which are also aplenty:
lut 20 21:31:24 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4786, resource id: 48234761, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 21:31:27 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5633, resource id: 39846053, major code: 18 (ChangeProperty), minor code: 0
lut 20 21:31:53 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 6675, resource id: 48234829, major code: 14 (GetGeometry), minor code: 0
lut 20 22:05:35 MarKDE plasmashell[844]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:343: Unable to assign [undefined] to int
lut 20 22:05:35 MarKDE plasmashell[844]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 6533, resource id: 2097159, major code: 142 (Unknown), minor code: 3
lut 20 22:07:17 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39776, resource id: 48263674, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:07:43 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42736, resource id: 48264351, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:07:43 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 42737, resource id: 48264351, major code: 14 (GetGeometry), minor code: 0
lut 20 22:07:43 MarKDE plasmashell[844]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:343: Unable to assign [undefined] to int
lut 20 22:07:43 MarKDE plasmashell[844]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 7096, resource id: 2097159, major code: 142 (Unknown), minor code: 3
$ journalctl | grep "kwin\|plasmashell" | tail -50
lut 20 21:32:02 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7374, resource id: 39846058, major code: 18 (ChangeProperty), minor code: 0
lut 20 21:32:02 MarKDE plasmashell[844]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:343: Unable to assign [undefined] to int
lut 20 21:32:02 MarKDE plasmashell[844]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:367: Unable to assign [undefined] to QString
lut 20 21:33:07 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10418, resource id: 48234993, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 21:37:09 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40995, resource id: 48235302, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 21:56:30 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58916, resource id: 48260256, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 21:56:30 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58917, resource id: 48260256, major code: 14 (GetGeometry), minor code: 0
lut 20 22:00:29 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8798, resource id: 48261412, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:00:29 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 8799, resource id: 48261412, major code: 14 (GetGeometry), minor code: 0
lut 20 22:01:43 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16490, resource id: 48261733, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:01:43 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 16491, resource id: 48261733, major code: 14 (GetGeometry), minor code: 0
lut 20 22:02:21 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18598, resource id: 48262345, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:02:21 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 18599, resource id: 48262345, major code: 14 (GetGeometry), minor code: 0
lut 20 22:03:59 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24988, resource id: 48262535, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:03:59 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 24989, resource id: 48262535, major code: 14 (GetGeometry), minor code: 0
lut 20 22:05:35 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30890, resource id: 48263109, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:05:35 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 30891, resource id: 48263109, major code: 14 (GetGeometry), minor code: 0
lut 20 22:15:24 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14911, resource id: 48264706, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:15:38 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17099, resource id: 48268543, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:15:38 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 17100, resource id: 48268543, major code: 14 (GetGeometry), minor code: 0
lut 20 22:18:22 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26820, resource id: 48269351, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:22:53 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 666, resource id: 48269585, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:22:53 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 667, resource id: 48269585, major code: 14 (GetGeometry), minor code: 0
lut 20 22:23:33 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6129, resource id: 48273536, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:23:33 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 6130, resource id: 48273536, major code: 14 (GetGeometry), minor code: 0
lut 20 22:26:11 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11199, resource id: 48274134, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:26:11 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 11200, resource id: 48274134, major code: 14 (GetGeometry), minor code: 0
lut 20 22:26:11 MarKDE plasmashell[844]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:343: Unable to assign [undefined] to int
lut 20 22:26:11 MarKDE plasmashell[844]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 8684, resource id: 2097159, major code: 142 (Unknown), minor code: 3
lut 20 22:26:22 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13869, resource id: 48274492, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:26:22 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 13870, resource id: 48274492, major code: 14 (GetGeometry), minor code: 0
lut 20 22:27:03 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15210, resource id: 48274722, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:29:16 MarKDE plasmashell[844]: libkcups: Renew-Subscription last error: 0 successful-ok
lut 20 22:30:30 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22208, resource id: 48274801, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:36:19 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53336, resource id: 48277506, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:36:20 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53502, resource id: 48278283, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:36:20 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53503, resource id: 48278283, major code: 14 (GetGeometry), minor code: 0
lut 20 22:36:39 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56183, resource id: 48278351, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:36:39 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 56184, resource id: 48278351, major code: 14 (GetGeometry), minor code: 0
lut 20 22:37:21 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59856, resource id: 48278571, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:37:21 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 59857, resource id: 48278571, major code: 14 (GetGeometry), minor code: 0
lut 20 22:41:08 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49758, resource id: 48278871, major code: 3 (GetWindowAttributes), minor code: 0
lut 20 22:42:32 MarKDE kwin_x11[834]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56360, resource id: 48284783, major code: 3 (GetWindowAttributes), minor code: 0
Do you have those as well?
Or maybe do you know of a fix for these?
#7
Yeah … mine are the same.
The guess is of course that GTK apps arent returning identifiers as QT expects them … but honestly, I have no idea. Maybe someone knows better.
#8
Seems GTK apps tend to overgenerate these errors, but even simple going through KDE system settings or selecting items for and from the panel or the main menu does generate those entries in logs… Mayhaps someone here is apt enough with KDE/kwin/plasmashell to offer some assistance and fix this…
