Hello
I have a somewhat strange problem with my SSD that is automounted via systemd following the instructions, I found in the tutorial here.
The mounting and access is all working well, but I observe and hear a constant activation of the SSD.
Disconnecting the drive via
sudo systemctl disable --now home-christian-passport.automount
immediately stops traffic, and i also don’t hear the drive getting active again. My assumption is that I have set an option wrong, but for the live of me I can’t figure it out
[Unit]
Description=passportEXT
[Mount]
What=/dev/disk/by-uuid/8cab75e7-0d58-4e4c-b7d7-518aacb65c4b
Where=/home/christian/passport
Type=ext4
Options= rw,noatime
#TimeoutSec=seconds
[Install]
WantedBy=multi-user.target
[Unit]
Description=Automount PassportEXT
[Automount]
TimeoutIdleSec=10
[Install]
I have added the KDE tag to this as I’m running an XFCE DE on a machine that came preinstalled with plasma. I mention that as I have found a couple of entries mentioning a similar behavior with khelper, but neither of those were offering a solution.
While I don’t think the INXI output will give reasonable info,
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=6df714e4-3531-4c3a-b021-525f88beda09 rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: BESSTAR TECH model: UM700 serial: <superuser required>
UEFI: American Megatrends v: 5.14 date: 11/04/2021
Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1295 high: 1567 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1393 2: 1567
3: 1294 4: 1318 5: 1235 6: 1201 7: 1178 8: 1177 bogomips: 36744
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 04:00.0 chip-ID: 1002:15d8
class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: :0.0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: HP V24 serial: <filter>
built: 2021 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 618mm (24.3") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.42.0
5.15.28-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.1
chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel alternate: snd_rn_pci_acp3x,snd_pci_acp5x pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Realtek
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid bus-ID: 3-2.1:4
chip-ID: 0d8c:0014 class-ID: 0300
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 link-max: gen: 2 speed: 5 GT/s port: N/A
bus-ID: 03:00.0 chip-ID: 8086:15f3 class-ID: 0200
bus-ID: 3-2.2:5 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 2.3 TiB used: 204.5 GiB (8.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-A01
lanes: 4 type: SSD serial: <filter> rev: EDFK0S03 temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD My Passport 25E1 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1021 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB model: General USB Flash Disk
size: 14.57 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 204.5 GiB (43.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 26.0 C mobo: N/A gpu: amdgpu temp: 49.0 C
Processes: 274 Uptime: 19m wakeups: 0 Memory: 13.67 GiB
used: 1.57 GiB (11.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1676 lib: 422 flatpak: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.14
