Hi,
I recently updated Vivaldi to 3.6.2165.40 (stable, 64-bit, fully-updated Manjaro, kernel 5.4 LTS, nvidia drivers) and I’m getting a strange problem: Vivaldi seems to be maxing out one CPU core, and causing the fan to run, almost constantly. I’ve never seen Vivaldi do this in the past (I’ve been running V since day-1).
In Vivaldi’s Task Manager the “Browser” entry is showing > 100.0 CPU usage almost constantly – no other entries are even close to that (most are 0.0 most of the time).
In KDE’s System Monitor (set to “all processes, tree”) only the main parent/root Vivaldi process is showing any significant CPU usage.
In addition to this, when I close Vivaldi it doesn’t exit (and the CPU usage remains high). The Vivaldi window closes like it’s shutting down and many sub-processes become zombies but the main process and a few others continue running. killall vivaldi-bin
needs to be run 2X or 3X to get them all to exit.
Aside from this everything appears to be working perfectly.
I’ve been poking and prodding, searching and trying different things (rebooting, tweaking settings), and I created a thread on on Vivaldi forum, but no solution so far. I tried running Vivaldi from the command line but I did not see any output that seems related. I also tried running with a fresh/empty profile (no extensions, changed settings, or open tabs) but same.
I have ~14 tabs open but all are hibernated (except the one I’m writing in). All the same tabs were open in the previous Vivaldi version before I updated. And, as noted above, none of these (nor any extensions) are showing any significant CPU usage in the Task Manager. Hence, I don’t think the issue is related to any of these things.
I’m not sure what to try next and I’d really appreciate some help.
I’m using the Manjaro packages community/vivaldi and community/vivaldi-ffmpeg-codecs.
Has anyone else experienced this? Any ideas on how to figure out what’s going on?
Thanks!
~ray
PS: Vivaldi’s option to keep it running in the BG after exit is disabled and sync says it has completed and is idle.
