Considering switching to Manjaro - basic advice needed please
Hi all
Im thinking of moving to Manjaro and would love some pointers. The install will be in Lenovo X1 Carbon Gen 6, with Intel© Core™ i7-8650U CPU and 16GB RAM and Intel graphics. My current kernal is 6.8.0-48. Im curent on Lunux Mint 22 Cinnamon.
I need a version which supports the HiDPI monitor my X1C has, so probably fractional scaling will be needed. I moved from MATE to Cinnamon after a decade as this really did not play well with my new X1C6.
I also need something with good graphics support for Intel. The reason Im considering a change from Mint is that in Cinnamon I get annoying video playback stuttering (in VLC/Kodi from my DLNA server) for which there seems not to be a solution
Apart from that there are no special Use Cases like gaming or dual monitors to worry about
any pointers KDE? XFCE? would be appreciated!
… but it does appear :wink:
perhaps because you apparently typed above the arrow :nerd_face:
→ pun intended
beyond that: no pointers - use what you like
TLDR:
Easier if you approach gurus in Linux Mint forum to resolve your issue, unless you are adventurous enough to take the learning curve.
Long version:
If you have been comfortable with Linux Mint, I’m not sure if you are willing to take the learning curve in Manjaro - just to resolve your playback issue.
In addition, you are also looking to change from Cinnamon to KDE - another learning curve.
I came from W10, and before I made the jump to penguin camp, I have tried almost 10 different distros.
Linux Mint was closest to my like, till I got quite fed up with their app update mechanism, and some shortcomings.
Then I jumped to Manjaro KDE.
Manjaro has many quality that I like, eg. Pamac.
And KDE is also quite powerful and suits my usage.
Manjaro is not perfect, and neither is KDE.
But without the presence of better distro than Manjaro, I will just stay.
About the issues you have raised, I have no comment as I have not encountered them.
True that - I’d think long and hard before switching from Mint to Manjaro as a casual user.
Resolve your issue in Mint - perhaps use another player.
Me personally - I avoid VLC wherever I can - which is practically everywhere - so:
I don’t use it. :man_shrugging:
I will probably do a dual boot to tst an experiment - I have 1TB in my laptop so plenty of space
If you are looking for an alternate to VLC, I have heard many good things about smplayer which I believe is available almost everywhere.
SMPlayer doesnt support upnp/dlna unfortunately
Is Smplayer actually using mplayer or is it / can it also use mpv (the more modern version of mplayer)?
the answer is:
apt search smplayer
i   smplayer    - Complete front-end for MPlayer and mpv
it can use either one
For mpv, there is a plugin - that’s what I read.
GitHub - chachmu/mpvDLNA: A plugin to allow mpv to browse and watch content hosted on DLNA servers
Generally users are expected to perform their own research.
That said, a good start might be to establish the general compatibility of you machine for use with Linux.
To that end, this link might be useful;
Additionally, there is a Tutorials category in this forum; plus the Manjaro Wiki; both of which provide a wealth of information.
Good luck.
Basic advice: read, read and read some more (Manjaro wiki, Manjaro tutorials, Arch wiki etc)
Always read Update Announcements in this Forum
Don’t take advice from you tube.
Grub Customizer is discouraged. Don’t do it!
If you are having an issue, use the search function of this forum. It is likely any issue that you may encounter or question you may have has been asked and answered already.
Boot up a live KDE ISO from USB, try KDE without any installation. Do the same for other flavors offered by Manjaro (but I would recommend KDE myself).
thanks - that is the solution!
And thanks to everyone else who took the trouble to reply
Welcome to the forum! :wave:
What is?
Please mark the reply that solved your issue by clicking the icon below the post and clicking the :white_check_mark: button. :wink:
Wherever you go, good luck. I’ve been on Linux as my daily driver since the mid-90’s. I’ve used most of the major distros, except Arch. Manjaro was my intro to Arch based linux and I must admit I like it. Sometimes the large DL’s to keep the rolling release current are a pain, but… everything has advantages/disadvantages.
Manjaro can be a very dependable system, as long as maintenance is kept up!
I’ve seen far too many threads in which the sordid details, once (usually seemingly painfully) extracted from the OP, reveal ancient .pacnew files which haven’t been tended to since the Dinosaurs roamed the planet and the Community repo. still being shown in the Pacman output. :wink:
Keep it current, monitor the Announcements threads for whichever branch you’re on, and you might end up with a system which runs for as long as mine and quite a few others’.
