What contains the xz compresses firmware image ?
I have experience with configuring and compiling kernels - Gentoo user time for 2 years.
You could try building the linux-firmware-uncompressed
I am however in doubt of how the kernel interact with the firmware files - meaning - does firmware files - or could they - expose an ABI which potentially breaks a kernel below a certain version?
This is the chicken egg problem.
firmware is normally optional so might not even been needed on your system
There is no ABI between a firmware blobs itself and the kernel. The kernel (module) just takes the firmware file and uploads it into the devices RAM when the system is booted. For example iwlwifi picks up the firmware blob for you wifi adapter and loads it into itâs memory. The firmware is being run by the devices microchip, so the kernel does not care what it contains at all.
Otherwise youâd need different firmware packages for the different kernel versionsâŚ
The problem is that the firmware-loader component in the kernel (that thing that takes those blobs and uploads it to the device) only supports compressed firmware files since version 5.3.
It should be perfectly fine to use uncompressed firmware files with kernel < 5.3.
So yeah, the AUR package should do the trick indeed.
Well, there is no problem. Arch doesnât have any 4.x kernels anymore, so they can decide to compress and split their firmware. If we want to continue as is, our firmware packages can only been split to reduce size. 5.x kernels can support both variants and 4.x only uncompressed firmware files.
We can simply ignore the Fedora changes and continue as is: upgpkg: linux-firmware 20220119.0c6a7b3-1: update to lastest git comm⌠¡ archlinux/svntogit-packages@4bf18f5 ¡ GitHub
âProblemâ was probably the wrong wording.
I just wanted to make the point that as long as you deliver the firmware uncompressed, the older kernels will support it as well
I added a poll to Twitter. Letâs see âŚ
How can vote a person without twitter account ?
Add a pool on the Manjaro forum ?
In the end it wonât matter what polls would say. Our kernel team has to decide if they want to continue or not. But here is a poll:
Should Manjaro continue to drop 4.x kernels and use compressed firmware files?
0 voters
I only need the kernel 4.19 - all other 4.x kernels can be dropped.
@Keruskerfuerst 4.x kernels got re-added with todayâs testing update. This includes 4.19:
- We readded 4.x kernels. Note that 4.4 series is now marked EOL
- linux-firmware we kept split-up, however we ship them uncompressed to support 4.x kernels still
Thanks at all for that!
All other 4.x kernels can be removed: 4.4.x, 4.9.x and 4.14.x.
P.S.: kernels 4.4.x, 4.9.x and 4.14.x do sound a bit slow.
