Hello everybody,
after my return from vacations my system tells my that the connection to sound service is lost - and I am not able to restore it. I have read through several posts here but I find no solution.
Here come some information:
inxi --admin --verbosity=7 --filter --no-host --width 1 ✘
Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=0d218fb4-18ec-4775-b315-f5d84d155a8c rw quiet
cryptdevice=UUID=93ce3209-9d45-4029-a341-11b51d505acc:luks-93ce3209-9d45-4029-a341-11b51d505acc
root=/dev/mapper/luks-93ce3209-9d45-4029-a341-11b51d505acc splash
resume=/dev/mapper/luks-4a65bb64-d328-4642-9981-d37a0cef521d
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Laptop System: LENOVO product: 20XF006GGE v: ThinkPad T14s Gen 2a
Mobo: LENOVO model: 20XF006GGE v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20XF_BU_Think_FM_ThinkPad
T14s Gen 2a uuid: <superuser required> UEFI: LENOVO v: R1NET56W (1.26)
date: 02/21/2023
ID-1: BAT0 charge: 57.0 Wh (100.0%) condition: 57.0/57.0 Wh (99.9%)
power: 16.2 W volts: 16.4 min: 15.4 model: LGC 5B10W13976 type: Li-poly
serial: <filter> status: charging cycles: 35
Device-1: hid-34:88:5d:ec:74:a3-battery model: Keyboard K380 serial: N/A
charge: N/A status: discharging
Device-2: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 30.19 GiB used: 9.32 GiB (30.9%)
Device-1: Channel-A DIMM 0 type: LPDDR4 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 4266 MT/s volts: min: 0.6 max: 0.6
width (bits): data: 32 total: 32 manufacturer: Micron Technology
part-no: MT53E2G32D4NQ-046 serial: N/A
Device-2: Channel-B DIMM 0 type: LPDDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA500011
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/4507 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 60719
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
affected
Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-3,DP-4,eDP-1
empty: DP-1, DP-2, DP-5, HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 51.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 13d3:5405
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x3240 s-dpi: 96 s-size: 2030x856mm (79.92x33.70")
s-diag: 2203mm (86.74") monitors: <missing: xrandr>
Monitor-1: DP-3 model: ASUS VG289 serial: <filter> built: 2022
res: 3840x2160 dpi: 157 gamma: 1.2 size: 621x341mm (24.45x13.43")
diag: 708mm (27.9") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: DP-4 model: ASUS VG289 serial: <filter> built: 2021
Monitor-3: eDP-1 model: AU Optronics 0x573d built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 18.1.8 DRM 3.54 6.6.65-1-MANJARO) device-ID: 1002:1638
memory: 1000 MiB unified: no
API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638
surfaces: xcb,xlib
Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Lenovo driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
chip-ID: 1022:15e3 class-ID: 0403
Device-4: GN Netcom Jabra SPEAK 510 USB driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.1.2:7
chip-ID: 0b0e:0422 class-ID: 0300 serial: <filter>
Device-5: Lenovo ThinkPad USB-C Dock Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-1.2:5 chip-ID: 17ef:30b0 class-ID: 0300
serial: <filter>
API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: off with: pulseaudio-alsa
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.1:4
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp6s0f3u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wwan0 state: down mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:3 chip-ID: 8087:0029
class-ID: e001
Device-1: luks-93ce3209-9d45-4029-a341-11b51d505acc maj-min: 254:0
type: LUKS dm: dm-0 size: 920.36 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 920.36 GiB
Device-2: luks-4a65bb64-d328-4642-9981-d37a0cef521d maj-min: 254:1
type: LUKS dm: dm-1 size: 33.21 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 33.21 GiB
Local Storage: total: 953.87 GiB used: 226.37 GiB (23.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-1T00-1001 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11170101 temp: 50.9 C scheme: GPT
ID-1: / raw-size: 920.36 GiB size: 904.84 GiB (98.31%)
used: 225.48 GiB (24.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-93ce3209-9d45-4029-a341-11b51d505acc label: N/A
uuid: 0d218fb4-18ec-4775-b315-f5d84d155a8c
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: CB29-D79A
ID-1: swap-1 type: partition size: 33.21 GiB used: 906.5 MiB (2.7%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-4a65bb64-d328-4642-9981-d37a0cef521d label: swap
uuid: d93910d8-3bc2-4a05-a93f-10bd87125297
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-2:2 info: IMC Networks Integrated Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:5405 class-ID: fe01 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-4: 3-1:2 info: Lenovo USB2.0 Hub ports: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30af
Hub-5: 3-1.1:4 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30ac
Device-1: 3-1.1.2:7 info: GN Netcom Jabra SPEAK 510 USB type: audio,HID
driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Hub-6: 3-1.1.3:8 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30ae
Device-1: 3-1.2:5 info: Lenovo ThinkPad USB-C Dock Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 17ef:30b0 class-ID: 0300 serial: <filter>
Device-2: 3-1.3:6 info: Lenovo 40AY type: billboard driver: N/A
chip-ID: 17ef:30a9 class-ID: 1100 serial: <filter>
Device-3: 3-3:3 info: Alcor Micro AU9540 Smartcard Reader type: smart card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 50mA chip-ID: 058f:9540 class-ID: 0b00
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-8: 4-1:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:30ab
Device-1: 4-1.1:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
Hub-9: 4-1.3:3 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:30ad
Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-3:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
Device-2: 5-4:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-11: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 63.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): fan-1: 3000 fan-2: 3000
Processes: 452 Power: uptime: 23m states: freeze,mem,disk suspend: s2idle
image: 12.06 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: 1519 pm: pacman pkgs: 1504 libs: 429 tools: pamac,yay pm: flatpak
pkgs: 0 pm: snap pkgs: 15 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh
v: 5.9 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
also I have tried the proposals of @nikgnomic from this post Audio Devices Not Showing in Manjaro - Seeking Assistance - #2 by Olli without success:
systemctl --user restart pulseaudio 99 ✘
Job for pulseaudio.service failed because the control process exited with error code.
See "systemctl --user status pulseaudio.service" and "journalctl --user -xeu pulseaudio.service" for details.```
and
systemctl --user stop pulseaudio.socket pulseaudio.service
systemctl --user stop -l --no-pager status pulseaudio.* zsh: no matches found: pulseaudio.*
pactl list cards 1 ✘
Verbindungsfehler: Verbindung verweigert
pa_context_new() fehlgeschlagen: Verbindung verweigert
as well as
pacmd list-sinks
Es läuft kein PulseAudio-Dienst oder nicht als Sitzungsdienst.
sudo alsactl restore
Found hardware: "acp" "" "" "" ""
Hardware is initialized using a generic method
Can anybody help me here?
Thanks in advance!
Thorsten
