Connection to sound service lost, pipewire package creation date is now 31 December 1969
I believe the pipewire package got corrupted after a failed update. In short, I was, updating the system using Pamac and it randomly closed the window. I had to resume the update using manjaro-chroot with an usb because I couldn’t login due to the system not finding the kernel. When I finally got into the system I found I had no sound. Is there a correct way to solve this? If I even try to use alsamixer I get
> alsamixer
[E] pw.loop [loop.c:70 pw_loop_new()] 0x560359d117b0: can't make support.system handle: No existe el fichero o el directorio
zsh: segmentation fault (core dumped)  alsamixer
This is my inxi -F:
  Host: ideapad Kernel: 6.6.107-1-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.3.6 Distro: Manjaro Linux
  Type: Laptop System: LENOVO product: 81D1 v: Lenovo ideapad 330-15IGM
    serial: <superuser required>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN
    serial: <superuser required> UEFI: LENOVO v: 7XCN41WW date: 06/17/2021
  ID-1: BAT0 charge: 21.4 Wh (100%) condition: 21.4/30 Wh (71.2%)
  Info: quad core model: Intel Pentium Silver N5000 bits: 64 type: MCP cache:
    L2: 4 MiB
  Speed (MHz): avg: 800 min/max: 800/2700 cores: 1: 800 2: 800 3: 800 4: 800
  Device-1: Intel GeminiLake [UHD Graphics 605] driver: i915 v: kernel
  Device-2: Chicony EasyCamera driver: uvcvideo type: USB
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8 driver: X:
    loaded: modesetting dri: iris gpu: i915 resolution: 1366x768~60Hz
  API: EGL v: 1.5 drivers: iris,swrast platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
    renderer: Mesa Intel UHD Graphics 605 (GLK 3)
  API: Vulkan v: 1.4.321 drivers: intel surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
    driver: snd_hda_intel
  API: ALSA v: k6.6.107-1-MANJARO status: kernel-api
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
  IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: 8c:16:45:b0:34:c1
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    driver: ath10k_pci
  IF: wlp2s0 state: up mac: 30:d1:6b:e2:07:49
  Device-1: Qualcomm Atheros driver: btusb type: USB
Use of uninitialized value $_ in pattern match (m//) at /usr/bin/inxi line 22681.
  Local Storage: total: 465.76 GiB used: 140.19 GiB (30.1%)
  ID-1: /dev/sda vendor: Western Digital model: WD5000LPCX-24VHAT0
  ID-1: / size: 167.11 GiB used: 140.16 GiB (83.9%) fs: ext4 dev: /dev/sda5
  ID-2: /boot/efi size: 256 MiB used: 28.8 MiB (11.2%) fs: vfat
    dev: /dev/sda1
  ID-1: swap-1 type: partition size: 3.65 GiB used: 256 KiB (0.0%) dev: /zram0
  System Temperatures: cpu: 45.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 4 GiB available: 3.65 GiB used: 1.6 GiB (43.8%)
  Processes: 180 Uptime: 34m Shell: Zsh inxi: 3.3.39
And this is the pacman -Qi pipewire output:
> pacman -Qi pipewire
error: could not open file /var/lib/pacman/local/pipewire-1:1.4.8-2/desc: No such file or directory
Version         : 1:1.4.8-2
Description     : None
Architecture    : None
URL             : None
Licenses        : None
Groups          : None
Provides        : None
Depends On      : None
Optional Deps   : None
Required By     : easyeffects  gst-plugin-pipewire  manjaro-pipewire  pipewire-alsa  pipewire-audio  pipewire-jack  pipewire-media-session
                  pipewire-pulse  pipewire-v4l2  pipewire-x11-bell  pipewire-zeroconf  xdg-desktop-portal
Optional For    : chromium  electron17  electron27  electron29-bin  qt5-webengine  qt6-webengine  sdl3
Conflicts With  : None
Replaces        : None
Installed Size  : 0.00 B
Packager        : None
Build Date      : Wed Dec 31 20:00:00 1969
Install Date    : Wed Dec 31 20:00:00 1969
Install Reason  : Explicitly installed
Install Script  : No
Validated By    : Unknown
Thanks for the help. Changed the pacman -Qi pipewire output to english. Sorry about that.
While it is possible to see what the different lines are, I’ll give you a tip, that preceding a CLI command with LC_ALL=C switches locale for this instance of the command so that the results are in English. :wink:
edit: Ofc, this is provided there’s a localization done in the command or application you are running.
my spanish is below zero but as i can read nada means nothing and “no se pudo abrir….” is something like “no existing archiv”. i would try to update the mirror-servers first. and check again if the package is avaiable.
Which version of Pamac GUI is installed - pamac-gtk or pamac-gtk3?
pamac search -i pamac | grep -A1 gtk
Previous topics suggest pamac-gtk is for Gnome only
pamac-gtk3 is better option for KDE, Xfce and Cinnamon
inxi data shows deprecated session manager pipewire-media-session is installed
ArchWiki - PipeWire - Session Manager
PipeWire implements no connection logic internally. The burden of watching for new streams and connecting them to the appropriate output device or application is left to an external component known as a session manager.
WirePlumber is the recommended session manager.
pipewire-media-session is deprecated and no longer recommended. It was mostly implemented for testing and as an example for building new session managers.
If packages were updated successfully in chroot, I would suspect that pipewire was the only corrupted package and dependency packages were not corrupted
I suggest reinstall the corrupted package
pamac reinstall pipewire
and install WirePlumber to replace pipewire-media-session
pamac install wireplumber
Hello. I can’t reinstall pipewire. This is the output of pamac reinstall pipewire:
> LC_ALL=C pamac reinstall pipewire
Preparing...
Warning: pipewire-1:1.4.8-2 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
Warning: could not fully load metadata for package pipewire-1:1.4.8-2
Error: Failed to prepare transaction: invalid or corrupted package
I think I have the fastest mirrors. This the output of pacman-mirrors --fasttrack && sudo pacman -Syu
> sudo pacman-mirrors --fasttrack && sudo pacman -Syu
[sudo] password for jsanchez:
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  0.935 Global         : https://mirrors2.manjaro.org/
::INFO Writing mirror list
::Global          : https://mirrors2.manjaro.org/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
:: Sincronizando las bases de datos de los paquetes...
 core está actualizado
 extra está actualizado
 multilib está actualizado
:: Iniciando actualización completa del sistema...
advertencia: ksystemstats: la versión instalada (6.4.0-1) es más nueva que extra (6.3.6-1)
advertencia: libresprite: la versión instalada (1:1.1+dev-2) es más nueva que extra (1.2-2)
 ...el sistema ya está actualizado.
And yes, I have pamac-gtk. I will change to pamac-gtk3later.
there is something wrong with the sources of your mirrors.
can you try
sudo pacman-mirrors -c all && sudo pacman -Syu
Delete corrupted package tarball and signature file from pacman cache
rm /var/cache/pacman/pkg/pipewire-1:1.4.8-2-x86_64.pkg.tar.zst /var/cache/pacman/pkg/pipewire-1:1.4.8-2-x86_64.pkg.tar.zst.sig
This is the output:
> sudo pacman-mirrors -c all && sudo pacman -Syu              ✔  2m 52s 
::INFO Using default mirror file
  2.685 Australia      : https://mirror.aarnet.edu.au/pub/manjaro/
  1.588 Australia      : https://gsl-syd.mm.fcix.net/manjaro/
  1.196 Austria        : https://mirror.easyname.at/manjaro/
  1.058 Austria        : https://mirror.alwyzon.net/manjaro/
  3.793 Bangladesh     : https://mirror.xeonbd.com/manjaro/
  1.562 Belarus        : https://mirror.datacenter.by/pub/mirrors/manjaro/
  1.211 Belgium        : https://ftp.belnet.be/mirrors/manjaro/repos/
  1.107 Belgium        : https://mirror.futureweb.be/manjaro/
  1.249 Brazil         : https://manjaro.c3sl.ufpr.br/
  1.280 Brazil         : https://linorg.usp.br/manjaro/
  1.187 Bulgaria       : https://mirror.telepoint.bg/manjaro/
  1.590 Bulgaria       : https://manjaro.ipacct.com/manjaro/
  0.675 Canada         : https://mirror.csclub.uwaterloo.ca/manjaro/
  0.733 Canada         : https://mirror.xenyth.net/manjaro/
  0.663 Canada         : https://muug.ca/mirror/manjaro/
  2.298 China          : https://mirror.nju.edu.cn/manjaro/
  ..... China          : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
  2.305 China          : https://mirrors.jlu.edu.cn/manjaro/
  0.601 Colombia       : https://edgeuno-bog2.mm.fcix.net/manjaro/
  0.771 Colombia       : https://mirrors.atlas.net.co/manjaro/
  1.507 Czech_Republic : https://mirror.dkm.cz/manjaro/
  1.175 Czech_Republic : https://mirror.it4i.cz/manjaro/
  1.098 Denmark        : https://mirrors.dotsrc.org/manjaro/
  1.442 France         : https://mirrors.eric.ovh/manjaro/
  0.975 France         : https://ftp.free.org/mirrors/repo.manjaro.org/repos/
  1.129 France         : https://mirror.ibakerserver.pt/manjaro/
  1.182 France         : https://manjaro.ynh.ovh/
  1.028 France         : https://manjaro.syxpi.fr/manjaro/
  2.065 Georgia        : https://manjaro.grena.ge/
  1.296 Germany        : https://mirror.alpix.eu/manjaro/
  0.929 Germany        : http://ftp.uni-kl.de/pub/linux/manjaro/
  1.288 Germany        : https://ftp.gwdg.de/pub/linux/manjaro/
  1.121 Germany        : https://mirror.23m.com/manjaro/
  1.087 Germany        : https://ftp.halifax.rwth-aachen.de/manjaro/
  1.057 Germany        : https://ftp.tu-chemnitz.de/pub/linux/manjaro/
  3.044 Germany        : https://mirror.netcologne.de/manjaro/
  1.387 Germany        : https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/
  0.294 Germany        : https://manjaro.kurdy.org/
  0.600 Global         : https://mirrors.manjaro.org/repo/
  0.274 Global         : https://mirrors2.manjaro.org/
  0.438 Global         : https://mirrors.cicku.me/manjaro/
  1.603 Greece         : https://fosszone.csd.auth.gr/manjaro/
  1.587 Greece         : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  1.479 Hungary        : https://quantum-mirror.hu/mirrors/pub/manjaro/
  2.780 Indonesia      : https://kartolo.sby.datautama.net.id/manjaro/
  1.551 Iran           : https://mirror.mobinhost.com/manjaro/
  2.140 Iran           : https://repo.iut.ac.ir/repo/manjaro/
  1.331 Italy          : https://manjaro.mirror.garr.it/manjaro/
  2.025 Italy          : https://ba.mirror.garr.it/mirrors/manjaro/
  1.913 Italy          : https://ct.mirror.garr.it/mirrors/manjaro/
  1.361 Japan          : https://ftp.riken.jp/Linux/manjaro/
  1.693 Japan          : https://mirrors.xtom.jp/manjaro/
  2.208 Japan          : https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
  1.379 Japan          : https://mirror.phoepsilonix.love/manjaro/
  2.315 Kenya          : https://manjaro.mirror.liquidtelecom.com/
  2.193 Mauritius      : https://manjarolinux-mirror.cloud.mu/
  1.140 Netherlands    : https://manjaro.mirror.wearetriple.com/
  1.274 Netherlands    : https://manjaro.mirrors.lavatech.top/
  1.501 Netherlands    : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  1.182 Netherlands    : https://ftp.snt.utwente.nl/pub/linux/manjaro/
  0.979 Netherlands    : https://mirror.koddos.net/manjaro/
  1.598 Netherlands    : https://mirror.bouwhuis.network/manjaro/
  1.949 New_Zealand    : https://mirror.2degrees.nz/manjaro/
  1.301 Poland         : https://ftp.psnc.pl/linux/manjaro/
  1.850 Russia         : https://mirror.kamtv.ru/manjaro/
  1.827 Russia         : https://mirror.truenetwork.ru/manjaro/
  1.247 Serbia         : https://mirror1.sox.rs/manjaro/
  1.737 Singapore      : https://mirror.freedif.org/Manjaro/
  1.589 Singapore      : http://ossmirror.mycloud.services/os/linux/manjaro/
  0.332 Slovenia       : https://mirror.komelt.dev/manjaro/
  2.017 South_Africa   : https://mirror.dimensiondata.com/mirrors/manjaro.org/
  1.086 Spain          : https://mirror.raiolanetworks.com/manjaro/
  ..... Spain          : https://ftp.caliu.cat/pub/distribucions/manjaro/
  1.479 Sweden         : https://ftp.lysator.liu.se/pub/manjaro/
  1.487 Sweden         : https://ftpmirror1.infania.net/mirror/manjaro/
  1.042 Switzerland    : https://mirror.init7.net/manjaro/
  1.088 Switzerland    : https://ipng.mm.fcix.net/manjaro/
  1.217 Turkey         : https://ftp.linux.org.tr/manjaro/
  1.321 Ukraine        : https://distrohub.kyiv.ua/manjaro/
  ..... Ukraine        : https://mirror.hostiko.network/manjaro/
  0.949 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/
  ..... United_Kingdom : https://manjaro.mirrors.uk2.net/
  1.009 United_Kingdom : https://mirror.vinehost.net/manjaro/
  1.084 United_Kingdom : https://ask4.mm.fcix.net/manjaro/
  0.820 United_States  : https://mirror.fcix.net/manjaro/
  0.677 United_States  : https://nnenix.mm.fcix.net/manjaro/
  0.924 United_States  : https://ziply.mm.fcix.net/manjaro/
  0.594 United_States  : https://cofractal-ewr.mm.fcix.net/manjaro/
  0.757 United_States  : https://irltoolkit.mm.fcix.net/manjaro/
  0.650 United_States  : https://repo.ialab.dsu.edu/manjaro/
  0.758 United_States  : https://mirrors.ocf.berkeley.edu/manjaro/
  0.627 United_States  : https://mirror.math.princeton.edu/pub/manjaro/
  0.584 United_States  : https://mnvoip.mm.fcix.net/manjaro/
  0.545 United_States  : https://forksystems.mm.fcix.net/manjaro/
  0.830 United_States  : https://codingflyboy.mm.fcix.net/manjaro/
  0.565 United_States  : https://coresite.mm.fcix.net/manjaro/
  0.798 United_States  : https://opencolo.mm.fcix.net/manjaro/
  0.633 United_States  : https://southfront.mm.fcix.net/manjaro/
  0.431 United_States  : https://volico.mm.fcix.net/manjaro/
  0.550 United_States  : https://ohioix.mm.fcix.net/manjaro/
  0.831 United_States  : https://mirrors.sonic.net/manjaro/
  0.507 United_States  : https://mirrors.gigenet.com/manjaro/
  0.658 United_States  : https://nocix.mm.fcix.net/manjaro/
  1.893 Uruguay        : https://manjaro.repo.cure.edu.uy/
  2.470 Uzbekistan     : https://mirror.dc.uz/manjaro/
  1.721 Vietnam        : https://mirror.meowsmp.net/manjaro/
::Germany         : https://manjaro.kurdy.org/stable
::Slovenia        : https://mirror.komelt.dev/manjaro/stable
::United_States   : https://volico.mm.fcix.net/manjaro/stable
::Global          : https://mirrors.cicku.me/manjaro/stable
::United_States   : https://mirrors.gigenet.com/manjaro/stable
::United_States   : https://forksystems.mm.fcix.net/manjaro/stable
::United_States   : https://ohioix.mm.fcix.net/manjaro/stable
::United_States   : https://coresite.mm.fcix.net/manjaro/stable
::United_States   : https://mnvoip.mm.fcix.net/manjaro/stable
::United_States   : https://cofractal-ewr.mm.fcix.net/manjaro/stable
::Global          : https://mirrors.manjaro.org/repo/stable
::Colombia        : https://edgeuno-bog2.mm.fcix.net/manjaro/stable
::United_States   : https://mirror.math.princeton.edu/pub/manjaro/stable
::United_States   : https://southfront.mm.fcix.net/manjaro/stable
::United_States   : https://repo.ialab.dsu.edu/manjaro/stable
::United_States   : https://nocix.mm.fcix.net/manjaro/stable
::Canada          : https://muug.ca/mirror/manjaro/stable
::Canada          : https://mirror.csclub.uwaterloo.ca/manjaro/stable
::United_States   : https://nnenix.mm.fcix.net/manjaro/stable
::Canada          : https://mirror.xenyth.net/manjaro/stable
::United_States   : https://irltoolkit.mm.fcix.net/manjaro/stable
::United_States   : https://mirrors.ocf.berkeley.edu/manjaro/stable
::Colombia        : https://mirrors.atlas.net.co/manjaro/stable
::United_States   : https://opencolo.mm.fcix.net/manjaro/stable
::United_States   : https://mirror.fcix.net/manjaro/stable
::United_States   : https://codingflyboy.mm.fcix.net/manjaro/stable
::United_States   : https://mirrors.sonic.net/manjaro/stable
::United_States   : https://ziply.mm.fcix.net/manjaro/stable
::Germany         : http://ftp.uni-kl.de/pub/linux/manjaro/stable
::United_Kingdom  : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable
::France          : https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable
::Netherlands     : https://mirror.koddos.net/manjaro/stable
::United_Kingdom  : https://mirror.vinehost.net/manjaro/stable
::France          : https://manjaro.syxpi.fr/manjaro/stable
::Switzerland     : https://mirror.init7.net/manjaro/stable
::Germany         : https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable
::Austria         : https://mirror.alwyzon.net/manjaro/stable
::United_Kingdom  : https://ask4.mm.fcix.net/manjaro/stable
::Spain           : https://mirror.raiolanetworks.com/manjaro/stable
::Germany         : https://ftp.halifax.rwth-aachen.de/manjaro/stable
::Switzerland     : https://ipng.mm.fcix.net/manjaro/stable
::Denmark         : https://mirrors.dotsrc.org/manjaro/stable
::Belgium         : https://mirror.futureweb.be/manjaro/stable
::Germany         : https://mirror.23m.com/manjaro/stable
::France          : https://mirror.ibakerserver.pt/manjaro/stable
::Netherlands     : https://manjaro.mirror.wearetriple.com/stable
::Czech_Republic  : https://mirror.it4i.cz/manjaro/stable
::France          : https://manjaro.ynh.ovh/stable
::Netherlands     : https://ftp.snt.utwente.nl/pub/linux/manjaro/stable
::Bulgaria        : https://mirror.telepoint.bg/manjaro/stable
::Austria         : https://mirror.easyname.at/manjaro/stable
::Belgium         : https://ftp.belnet.be/mirrors/manjaro/repos/stable
::Turkey          : https://ftp.linux.org.tr/manjaro/stable
::Serbia          : https://mirror1.sox.rs/manjaro/stable
::Brazil          : https://manjaro.c3sl.ufpr.br/stable
::Netherlands     : https://manjaro.mirrors.lavatech.top/stable
::Brazil          : https://linorg.usp.br/manjaro/stable
::Germany         : https://ftp.gwdg.de/pub/linux/manjaro/stable
::Germany         : https://mirror.alpix.eu/manjaro/stable
::Poland          : https://ftp.psnc.pl/linux/manjaro/stable
::Ukraine         : https://distrohub.kyiv.ua/manjaro/stable
::Italy           : https://manjaro.mirror.garr.it/manjaro/stable
::Japan           : https://ftp.riken.jp/Linux/manjaro/stable
::Japan           : https://mirror.phoepsilonix.love/manjaro/stable
::Germany         : https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable
::France          : https://mirrors.eric.ovh/manjaro/stable
::Hungary         : https://quantum-mirror.hu/mirrors/pub/manjaro/stable
::Sweden          : https://ftp.lysator.liu.se/pub/manjaro/stable
::Sweden          : https://ftpmirror1.infania.net/mirror/manjaro/stable
::Netherlands     : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable
::Czech_Republic  : https://mirror.dkm.cz/manjaro/stable
::Iran            : https://mirror.mobinhost.com/manjaro/stable
::Belarus         : https://mirror.datacenter.by/pub/mirrors/manjaro/stable
::Greece          : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable
::Australia       : https://gsl-syd.mm.fcix.net/manjaro/stable
::Singapore       : http://ossmirror.mycloud.services/os/linux/manjaro/stable
::Bulgaria        : https://manjaro.ipacct.com/manjaro/stable
::Netherlands     : https://mirror.bouwhuis.network/manjaro/stable
::Greece          : https://fosszone.csd.auth.gr/manjaro/stable
::Japan           : https://mirrors.xtom.jp/manjaro/stable
::Vietnam         : https://mirror.meowsmp.net/manjaro/stable
::Singapore       : https://mirror.freedif.org/Manjaro/stable
::Russia          : https://mirror.truenetwork.ru/manjaro/stable
::Russia          : https://mirror.kamtv.ru/manjaro/stable
::Uruguay         : https://manjaro.repo.cure.edu.uy/stable
::Italy           : https://ct.mirror.garr.it/mirrors/manjaro/stable
::New_Zealand     : https://mirror.2degrees.nz/manjaro/stable
::South_Africa    : https://mirror.dimensiondata.com/mirrors/manjaro.org/stable
::Italy           : https://ba.mirror.garr.it/mirrors/manjaro/stable
::Georgia         : https://manjaro.grena.ge/stable
::Iran            : https://repo.iut.ac.ir/repo/manjaro/stable
::Mauritius       : https://manjarolinux-mirror.cloud.mu/stable
::Japan           : https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::China           : https://mirror.nju.edu.cn/manjaro/stable
::China           : https://mirrors.jlu.edu.cn/manjaro/stable
::Kenya           : https://manjaro.mirror.liquidtelecom.com/stable
::Uzbekistan      : https://mirror.dc.uz/manjaro/stable
::Australia       : https://mirror.aarnet.edu.au/pub/manjaro/stable
::Indonesia       : https://kartolo.sby.datautama.net.id/manjaro/stable
::Germany         : https://mirror.netcologne.de/manjaro/stable
::Bangladesh      : https://mirror.xeonbd.com/manjaro/stable
::Spain           : https://ftp.caliu.cat/pub/distribucions/manjaro/stable
::United_Kingdom  : https://manjaro.mirrors.uk2.net/stable
::China           : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
::Ukraine         : https://mirror.hostiko.network/manjaro/stable
I deleted the corrupted package but I get exactly the same output when I try to reinstall pipewire
Try installing uncorrupted version of package from one of Manjaro’s mirrors
sudo pacman -U https://mirror.alpix.eu/manjaro/stable/extra/x86_64/pipewire-1%3A1.4.8-2-x86_64.pkg.tar.zst
If that does not work, download the package and reinstall locally
I got the same output:
loading packages...
warning: pipewire-1:1.4.8-2 is up to date -- reinstalling
resolving dependencies...
warning: could not fully load metadata for package pipewire-1:1.4.8-2
error: failed to prepare transaction (invalid or corrupted package)
sudo rm -r /var/lib/pacman/local/pipewire-1:1.4.8-2/
PipeWire 1.4.9 was released 2025-10-09 so a package update will probably resolve issue with corrupted package soon
After doing that I could succesfully install the pipewire package again. Thanks!
If PipeWire has been reinstalled correctly, install pamac-gtk3 and wireplumber to replace pamac-gtk and pipewire-media-session
Out of curiosity, does specifying the mirror’s address bypass pacman preferring its cache, or what is happening here? I was half expecting pacman trying to be lazy and just go for the corrupted package in the cache.
Yes, it bypass the cache. With -U it uses the specified url or file path. Useful for emergencies.
