What is the name of the default Manjaro KDE Plasma's clipboard manager?
I installed from the minimal Manjaro ISO, 'cause we’re all about reducing the bloat. However, I’m left without the clipboard manager in my system tray, and I miss it. Want to install it, but I don’t know which one it is. Did some research, but wasn’t able to find it. Arch Wiki says that KDE’s clipboard manager is Klipper, but I can’t find a clipboard manager package with that name in Pamac.
It doesn’t have to be the same manager I used before, as long as I can get that icon in the tray, configure it similarly etc.
Can’t you find it in the Settings of the tray icon widget?
//EDIT: also search “KDE enable clipboard” on google: https://www.addictivetips.com/ubuntu-linux-tips/use-the-kde-plasma-5-clipboard-manager/
I also installed the minimal ISO with Plasma. The clipboard manager is definitely included.
