Hi I’m a new user to Manjaro (used Mint and Ubuntu before) having a KDE Plasma DE.
I was trying to do some customization and every time I tried to install anything from the system manager I get different kinds of network errors, the most common being “Network Error 2: Connection Closed”. I went back to Mint and Windows and the network’s fine there… speed is good enough too (speed almost the same in Manjaro as well). May I know what the problem is and how to fix it?
Here is my inxi -Fxxz report:
System: Host: nik-manjaro Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.21.5 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: HP product: HP Laptop 15-da2xxx v: Type1ProductConfigId serial: <superuser required>
Mobo: HP model: 86B4 v: 88.27 serial: <superuser required> UEFI: Insyde v: F.33 date: 07/31/2020
Battery: ID-1: BAT1 charge: 31.4 Wh (80.3%) condition: 39.1/40.9 Wh (95.7%) volts: 12.1 min: 11.3
model: Hewlett-Packard PABAS0241231 status: Discharging
CPU: Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP arch: Kaby Lake note: check rev: C
cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36812
Speed: 700 MHz min/max: 400/1800 MHz Core speeds (MHz): 1: 700 2: 700 3: 700 4: 700 5: 700 6: 700 7: 700
8: 700
Graphics: Device-1: Intel UHD Graphics vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Hewlett-Packard driver: nvidia v: 465.31 bus-ID: 01:00.0
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 1-5:4
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nvidia resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169
v: kernel port: 4000 bus-ID: 02:00.0
IF: eno1 state: down mac: b0:5c:da:4a:22:82
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtl8821ce v: N/A port: 3000 bus-ID: 03:00.0
IF: wlo1 state: up mac: 70:66:55:a8:5d:13
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 bus-ID: 00:17.0
Drives: Local Storage: total: 1.42 TiB used: 11.43 GiB (0.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G2B0C-00PXH0 size: 465.76 GiB temp: 33.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-60Z10T0 size: 931.51 GiB
ID-3: /dev/sdb type: USB vendor: SanDisk model: Cruzer Blade size: 57.33 GiB
Partition: ID-1: / size: 19.52 GiB used: 9.45 GiB (48.4%) fs: ext4 dev: /dev/sdb3
ID-2: /boot/efi size: 511 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1
ID-3: /home size: 33.98 GiB used: 1.98 GiB (5.8%) fs: ext4 dev: /dev/sdb4
Swap: ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) dev: /dev/sdb2
Sensors: System Temperatures: cpu: 43.0 C mobo: 29.8 C
Info: Processes: 238 Uptime: 58m Memory: 23.3 GiB used: 2.69 GiB (11.5%) Init: systemd Compilers: gcc: 11.1.0
Packages: 1218 Shell: Bash v: 5.1.8 inxi: 3.3.04
Thanks in advance,
Polar.
