hanari
June 12, 2022, 4:10am
#1
hallo. this is my first post, apologies in advance for any errors made. i am not good with computer
i have an old laptop that i wish to use as an external monitor for my main laptop through a VGA connection. for this i have read that xrandr is an appropriate command
both my laptops are running manjaro i3 community edition
i have read the xrand man but i do not believe i’ve understood it correctly. from what i have read, this would be the appropriate command for my situation:
xrand --output LVDS-1 --auto --primary --output VGA-1
however no effect seems to take place. i have tried many different combinations with the same result(no apparent effect and no errors). i believe this to be a simple problem of me misinterpreting an argument, so i ask for help. thanks you
Hello @hanari and welcome
The command is not xrand
, but xrandr
If it is no hybrid gpu with nvidia, then this command should work:
xrandr --output LVDS-1 --auto --primary --output VGA-1 --auto --right-of LVDS-1
However… it would be better if you could share some more information:
inxi -Fazy
hanari
June 12, 2022, 7:10am
#3
thank you for the welcome @megavolt
woops! i made a mistake when typing the command in the post. apologies.
sadly the command you provided gave me the same result as before(no apparent effect nor error)
i realize also that i did not account for the third argument in my original command. silly me. nonetheless the problem persists
i can gladly provide the System information from both machines, but first i am worried. is there any precarious information in the output which i should censor before publishing to the internet? thanks
No, serial numbers, mac adresses etc. will be filtered. inxi -Fazy
is shortcut for:
inxi --full --admin --filter --width 80
or only gpu section: inxi -Gazy
I don’t think you can - VGA pots on a laptop is outgoing and what you are looking for is incoming.
There is another option though
hanari
June 12, 2022, 5:18pm
#6
thanks for reassurance. i have pasted the -Fazy output for both machines below.
machine 1(one i want to use as master):
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=e6e414ee-c0f5-4391-adb4-cc3b21b7aee0 rw quiet apparmor=1
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.30.0
Type: Laptop System: Hewlett-Packard product: HP Pavilion dv2600 v: F.2E
Mobo: Wistron model: 30CD v: 80.52 serial: <superuser required>
BIOS: Phoenix v: F.2E date: 12/01/2008
ID-1: BAT0 charge: N/A condition: N/A volts: N/A
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: N/A
Info: model: Intel Core2 Duo T5250 bits: 64 type: MCP arch: Core2 Merom
built: 2006-09 process: Intel 65nm family: 6 model-id: 0xF (15)
stepping: 0xD (13) microcode: 0xA4
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 1026 high: 1053 min/max: 1000/1500 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1053 2: 1000
bogomips: 5986
Flags: ht lm nx pae sse sse2 sse3 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: Intel Mobile GM965/GL960 Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen4 process: Intel 65n
built: 2006-07 ports: active: LVDS-1 off: VGA-1 empty: SVIDEO-1
bus-ID: 00:02.0 chip-ID: 8086:2a02 class-ID: 0300
Device-2: Chicony VGA 30fps UVC Webcam type: USB driver: uvcvideo
bus-ID: 2-5:2 chip-ID: 04f2:b016 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
s-diag: 398mm (15.69")
Monitor-1: LVDS-1 pos: primary model: Seiko Epson 0x4642 built: 2006
res: 1280x800 hz: 60 dpi: 107 gamma: 1.2 size: 303x190mm (11.93x7.48")
diag: 358mm (14.1") ratio: 16:10 modes: 1280x800
Monitor-2: VGA-1 note: disabled size-res: N/A modes: max: 1024x768
min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 82801H HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:284b
class-ID: 0403
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Device-1: Marvell 88E8039 PCI-E Fast Ethernet vendor: Hewlett-Packard
driver: sky2 v: 1.30 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 05:00.0 chip-ID: 11ab:4353 class-ID: 0200
IF: ens3 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel PRO/Wireless 4965 AG or AGN [Kedron] Network
driver: iwl4965 v: in-tree:d pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 8086:4229 class-ID: 0280
IF: wls5 state: down mac: <filter>
Local Storage: total: 240.39 GiB used: 9.41 GiB (3.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD2500BEVS-26VAT0 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 1.5 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A11 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: USB Flash
size: 7.5 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0.00 scheme: MBR
ID-1: / raw-size: 232.88 GiB size: 228.17 GiB (97.98%) used: 8.95 GiB (3.9%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 42.0 C mobo: 42.0 C
Processes: 148 Uptime: 1h 24m wakeups: 1 Memory: 2.9 GiB
used: 587.9 MiB (19.8%) Init: systemd v: 250 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1071
lib: 306 Shell: Bash v: 5.1.16 running-in: urxvtd inxi: 3.3.17
machine 2(one that i want to use as monitor):
bogomips: 5986
Type: mds
min: 640x480
class-ID: 0403
hanari
June 12, 2022, 5:35pm
#7
is there a way for me to know if the vga is only outgoing? i have seen a lecturer using the projector feature on a windows 10 laptop to use it as a secondary screen before. though i did not pay attention if he had two separate vga ports in his machine
But this not a VGA connection, but rather a Network Connection. At the end of the day, Windows uses here Miracast through Wifi-DIrect (P2P).
Sorry I misread your post. Of course it is NOT possible to connect 2 Laptops via VGA, because both are outgoing connections, always.
Hi. I also think that direct connection isn’t possible, but you can try to connect laptops by network. It is not an easy task, but you can read the link to Archwiki in this post:
hanari
June 12, 2022, 8:36pm
#10
oh, i did not think of looking up the word ‘display’ when i was looking for people with the same question as mine. sorry about the duplicate post.
i am currently learning computer networks at the moment so i think i’ll give it a go when i am more comfortable configuring servers in my machines. thanks for the potential solution!
Monitor signals originating from a computer is usually only outgoing - if you think of it - it makes sense - there is no devices which sends display into a laptop to project on the laptops internal display.
No matter how hard you try - it won’t work if there is no input port available.
Such function is outgoing - as the projector functions as the screen for the laptop usually mirrored so you can focus on the audience and your laptop before you - not the screen behind you.
Your only option is to use the network either controlling the laptop with your keyboard and mouse or by using the laptop’s xserver as client to your main computer.
system
closed
June 15, 2022, 6:50pm
#12
