inxi -Gy1 ✔
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q]
driver: N/A
Device-2: AMD Cezanne
driver: amdgpu
v: kernel
Display: x11
server: X.Org
v: 21.1.3
with: Xwayland
v: 22.1.1
driver:
X:
loaded: amdgpu
unloaded: modesetting
gpu: amdgpu
resolution: 1920x1080~165Hz
OpenGL:
renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.41-1-MANJARO)
v: 4.6 Mesa 22.0.4
what’s the output of the echo $XDG command i posted previous and also the output of the 2 glxinfo commands ?
echo $XDG_SESSION_TYPE ✔
x11
~ glxinfo | grep server ✔
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
~ prime-run glxinfo | grep server ✔
if you check
nvidia-smi
is nvidia driver recognized ?
nvidia-smi ✔ 3s
Fri Jun 10 13:31:12 2022
| NVIDIA-SMI 510.73.05 Driver Version: 510.73.05 CUDA Version: 11.6 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| N/A 38C P0 28W / N/A | 0MiB / 8192MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
we’ll let’s give it a try also your system is suspicious indeed. please install optimus-manager.
after installing please post the output of
systemctl status optimus-manager
Sure. Any particular version:
pacman -Ss optimus 4 ✘
extra/linux414-bbswitch 0.8-256 (linux414-extramodules)
kernel module allowing to switch dedicated graphics card on Optimus laptops
extra/linux419-bbswitch 0.8-242 (linux419-extramodules)
extra/linux49-bbswitch 0.8-262 (linux49-extramodules)
extra/linux510-bbswitch 0.8-136 (linux510-extramodules)
extra/linux515-bbswitch 0.8-52 (linux515-extramodules)
extra/linux517-bbswitch 0.8-16 (linux517-extramodules)
extra/linux54-bbswitch 0.8-208 (linux54-extramodules)
community/bumblebee 3.2.1-22
NVIDIA Optimus support for Linux through Primus/VirtualGL
community/linux515-rt-bbswitch 0.8-26 (linux515-rt-extramodules)
community/linux517-rt-bbswitch 0.8-4 (linux517-rt-extramodules)
uname -a
shows up which kernel you’re using, but usually use the ordinary one that packet manager shows up
5.15.41-1-MANJARO #1 SMP PREEMPT Wed May 18 09:20:01 UTC 2022 x86_64 GNU/Linux
please use pamac and install optimus from there.
please reboot after all before ongoing.
pamac search optimus 1 ✘
prime-switcher 1.0.2-1 AUR
Tool (GUI + CLI) to select used GPU for Optimus Laptop
nvman 2.1.0-1 AUR
NVIDIA Manager for Optimus/Bumblebee
nvidia-prime-select-git 20191010.902aa9a-1 AUR
A collection of shell scripts that makes it possible to use the NVIDIA GPU on a Optimus Laptop,
similar to the feature provided by the nvidia-prime package in Ubuntu. Forked by wildtruc
nvidia-optictl 1.0-1 AUR
A set of simple scripts to control Nvidia Optimus
nvidia-exec 0.1.0-4 AUR
Run programs in nvidia optimus setups with power management for Xorg and Wayland without log out
libgdm-prime 42.0+r11+g4a52f026-1 AUR
Display manager and login screen - patched with Prime support for Optimus laptops - support
library
libgdm-plymouth-prime 40.0-1 AUR
GDM support library with plymouth and Prime support for Optimus laptops
lg-downloader-git 0.1+r13.78a81fc-2 AUR
Tool to flash LG devices like the LG Optimus black (P970) from their bootloader
Display manager and login screen with plymouth and Prime support for Optimus laptops
envycontrol 2.1.1-1 AUR
Easy GPU switching for Nvidia Optimus laptops under Linux
dl-switch 1-1 AUR
Easy way to switch between displaylink and optimus
bumblebee-picasso-git 3.2.1.r2.aaa1b42-1 AUR
NVIDIA Optimus support for Linux through VirtualGL or primus, igpu amd picasso
bumblebee-git 3.2.1.r57.61c6161-1 AUR
bumblebee-forceunload 3.2.1-20 AUR
NVIDIA Optimus support for Linux through VirtualGL (with kernel module unload patch)
bbswitch-pf 0.8-133 AUR
Kernel module allowing to switch dedicated graphics card on Optimus laptops
bbswitch-mainline 0.8-1 AUR
bbswitch-lts 0.8-45 AUR
bbswitch-git v0.8-3 AUR
kernel module allowing to switch dedicated graphics card on Optimus laptops (Git version)
bbswitch-dkms-git 0.8.r0.g0c38f97-4 AUR
kernel module allowing to switch dedicated graphics card on Optimus laptops, dkms version
bbswitch-ck 0.8-29 AUR
Kernel module allowing to switch dedicated graphics card on Optimus laptops for linux-ck
bbswitch-ati-git 0.8.5.gddbd243-1 AUR
kernel module allowing to switch also AMD integrated and Nvidia dedicated graphics card on
bbswitch-ati-dkms-git 0.8.5.gddbd243-1 AUR
ttf-optimusprinceps 1.0-2 AUR
Optimus Princeps font by Manfred Klein
plymouth-theme-optimus-git r28.32a0d92-1 AUR
The plymouth theme collection by adi1090x
optimus-manager-qt-kde 1.6.9-1 AUR
A Qt interface for Optimus Manager that allows to configure and switch GPUs on Optimus laptops
using the tray menu KDE
optimus-manager-qt-git 1.6.6.r0.g98d630c-1 AUR
using the tray menu
optimus-manager-qt 1.6.9-1 AUR
using the tray menu
optimus-manager-openrc-git 1.3.1.r64.g28bdc14-1 AUR
Management utility to handle GPU switching for Optimus laptops (Git version)
optimus-manager-git 1.4-2 AUR
optimus-manager 1.4-4 AUR
Sorry, but why through pamac (a reference will do).
optimus-manager
just to get an overview, please post the actual
and
inxi --admin --verbosity=7 --filter --no-host --width 0|1 ✘ 3s
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=b0c1b620-4a51-4d52-983b-e9774711e237 rw acpi_backlight=vendor
quiet apparmor=1 security=apparmor udev.log_priority=3 amdgpu.backlight=0
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82JU v: Legion 5 15ACH6H
serial: <superuser required> Chassis: type: 10 v: Legion 5 15ACH6H
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: GKCN46WW date: 10/01/2021
ID-1: BAT0 charge: 61.4 Wh (100.0%) condition: 61.4/60.0 Wh (102.3%)
volts: 17.5 min: 15.4 model: Celxpert L20C4PC0 type: Li-poly
serial: <filter> status: full cycles: 9
Device-1: hid-dc:2c:26:f5:60:7e-battery model: Keychron K3 serial: N/A
charge: N/A status: discharging
RAM: total: 13.57 GiB used: 2.38 GiB (17.5%)
RAM Report:
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1608 high: 3289 min/max: 1200/3300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1520 4: 1197 5: 2395 6: 1397 7: 1922 8: 1197 9: 1198 10: 1197 11: 1198
12: 3289 bogomips: 79085
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Ampere pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:24dd class-ID: 0300
Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: none bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: modesetting gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0a1c built: 2021 res: 1920x1080
hz: 165 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.41-1-MANJARO)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: br-dcd89bf8ef45 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth097f0a7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: veth55baf24 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: vethd25e5fb state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:2
Local Storage: total: 476.94 GiB used: 34.54 GiB (7.2%)
model: PC SN530 SDBPMPZ-512G-1101 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21160001 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 34.54 GiB (7.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: b0c1b620-4a51-4d52-983b-e9774711e237
label: NO_LABEL uuid: DEED-D205
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 3 rev: 2.1 speed: 480 Mb/s
Device-1: 1-2.3:4 info: SteelSeries ApS Rival Gaming Mouse
type: HID,Mouse,Keyboard driver: hid-generic,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 200mA chip-ID: 1038:1384 class-ID: 0300
Device-2: 1-4:3 info: Integrated Express ITE Device(8910) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c101 class-ID: 0301
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:2 info: Genesys Logic GL3523 Hub ports: 3 rev: 3.2
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 349 Uptime: 4m wakeups: 3 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1350 lib: 342
flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.16
Optimus status:
systemctl status optimus-manager ✔
● optimus-manager.service - Optimus Manager Commands Daemon
Loaded: loaded (/usr/lib/systemd/system/optimus-manager.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2022-06-10 13:42:06 CEST; 4min 43s ago
Process: 521 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_daemon_start (code=exited, status=0/>
Process: 621 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_xorg_start (code=exited, status=0/SU>
Main PID: 698 (python3)
Tasks: 1 (limit: 16584)
Memory: 54.0M
CPU: 1.527s
CGroup: /system.slice/optimus-manager.service
└─ 698 /usr/bin/python3 -u -m optimus_manager.daemon
Jun 10 13:42:05 luke-user python3[621]: [1344] INFO: Unloading modules ['nvidia_drm', 'nvidia_modeset>
Jun 10 13:42:06 luke-user python3[621]: [1347] INFO: switching=none, nothing to do
Jun 10 13:42:06 luke-user python3[621]: [1375] INFO: Found MHWD-generated Xorg config file at /etc/X1>
Jun 10 13:42:06 luke-user python3[621]: [1375] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manag>
Jun 10 13:42:06 luke-user python3[621]: [1376] INFO: Writing state {'type': 'pending_post_xorg_start'>
Jun 10 13:42:06 luke-user python3[621]: [1376] INFO: Xorg pre-start hook completed successfully.
Jun 10 13:42:06 luke-user systemd[1]: Started Optimus Manager Commands Daemon.
Jun 10 13:42:06 luke-user python3[698]: [1] INFO: # Commands daemon
Jun 10 13:42:06 luke-user python3[698]: [1] INFO: Opening UNIX socket
Jun 10 13:42:06 luke-user python3[698]: [1] INFO: Awaiting commands
great step 1 seems to be succesful. please post the output of the 2 prime-run commands again to see the output. after this we’ll edit the grub to add nvidia as kernel-parameter.
echo $XDG_SESSION_TYPE INT ✘ 6m 12s
x11
edit /etc/default/grub (you must edit with sudo rights) and add the following to GRUB_CMDLINE_LINUX_DEFAULT line "optimus-manager.startup=nvidia ". be aware you have to add this parameter to the already existing ones.
after editing do an
sudo update-grub
sudo mkinitcpio -P
reboot
you can enable the compositor back
Thank you @Olli !
Let us hope it will be useful for someone else as well in the future. I also have another minor issue getting brightness to be adjustable (Can't control Lenovo laptop screen brightness) – although that just became less important now that I can use external displays… Thank you again, and to @brahma as well.
