I can connect to one Bluetooth without issues using Bluedevil. When I try to connect a second device, Bluedevil keeps connecting and then fails (the first device keeps connected). If I use Windows, I am able to connect two devices simultaneously, so the Bluetooth adapter has that feature.
KDE Plasma: 5.19.5
KDE Frameworks: 5.73.0
Kernel: 5.8.6
Bluetooth adapter: Realtek RTL8822BE
Fabby
September 15, 2020, 12:28pm
#2
Welcome to Manjaro!
Please read this:
When asking questions in the forum, it would be most helpful to all members if you provide some basic information. When you provide info from the terminal, usually from your logs, you have to format it so the content is easy to read. First copy and...
Reading time: 6 mins đź•‘
Likes: 133 ❤
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Hello
I have the same issue with my bluetooth. My log of inxi --admin --verbosity=7 --filter --no-host
Kernel: 5.10.19-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.2.1
root=UUID=49e7ac6d-322f-4620-9de0-5a48d7689fce rw quiet
Desktop: i3 4.19.1 info: polybar dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81N8
v: Lenovo IdeaPad S340-15IWL serial: <filter> Chassis:
type: 10 v: Lenovo IdeaPad S340-15IWL serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter>
UEFI: LENOVO v: ALCN26WW(V2.03) date: 06/05/2019
ID-1: BAT1 charge: 46.1 Wh condition: 46.3/52.5 Wh (88%)
volts: 12.7/11.2 model: Celxpert L18C3PF7 type: Li-ion
serial: <filter> status: Unknown cycles: 235
Device-1: hidpp_battery_0
model: Logitech G305 Lightspeed Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored)
rechargeable: yes status: Discharging
RAM: total: 11.43 GiB used: 4.31 GiB (37.7%)
RAM Report: permissions: Unable to run dmidecode. Root
privileges required.
Info: Quad Core model: Intel Core i5-8265U bits: 64
type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: C (12) microcode: DE
L2 cache: 6 MiB bogomips: 28808
Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz):
1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts
clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced
ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Vulnerabilities: Type: itlb_multihit
status: KVM: VMX disabled
Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
Type: spectre_v2
mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0 class ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1d13
class ID: 0302
Device-3: Syntek Integrated Camera type: USB
driver: uvcvideo bus ID: 1-6:3 chip ID: 174f:2426
class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver:
loaded: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:9dc8 class ID: 0403
Sound Server: ALSA v: k5.10.19-1-MANJARO
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Lenovo ThinkPad E595 driver: rtw_8822be v: N/A
modules: rtw88_8822be port: 3000 bus ID: 03:00.0
chip ID: 10ec:b822 class ID: 0280
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full
mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB
driver: btusb v: 0.8 bus ID: 1-10:4 chip ID: 0bda:b023
class ID: e001 serial: <filter>
Message: Required tool hciconfig not installed. Check
--recommends
Local Storage: total: 704.24 GiB used: 39.5 GiB (5.6%)
SMART Message: Required tool smartctl not installed. Check
--recommends
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo O.E.M.
model: RPFTJ256PDD2MWX size: 238.47 GiB block size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
rotation: SSD serial: <filter> rev: 11.9 temp: 34.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial
model: CT500MX500SSD1 size: 465.76 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 033 scheme: GPT
ID-1: / raw size: 128 GiB size: 124.99 GiB (97.65%)
used: 37.44 GiB (30.0%) fs: ext4 dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A
uuid: 49e7ac6d-322f-4620-9de0-5a48d7689fce
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%)
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 309E-B702
ID-3: /media/CrucialSSD raw size: 465.76 GiB
size: 465.76 GiB (100.00%) used: 2.04 GiB (0.4%) fs: ntfs
dev: /dev/sda1 maj-min: 8:1 label: CrucialSSD
uuid: 9C820C3B820C1D00
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB
fs: <superuser required> label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 109.86 GiB
fs: ntfs label: N/A uuid: A86AA3EE6AA3B788
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 513 MiB fs: ntfs
label: N/A uuid: 4C1E58781E585D50
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12
rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-2:5 info: Logitech USB Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c53f
class ID: 0300
Device-2: 1-6:3 info: Syntek Integrated Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 174f:2426 class ID: 0e02 serial: <filter>
Device-3: 1-10:4
info: Realtek RTL8822BE Bluetooth 4.2 Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1
speed: 12 Mb/s chip ID: 0bda:b023 class ID: e001
serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6
rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nouveau
temp: 38.0 C
Processes: 260 Uptime: 3h 43m wakeups: 7 Init: systemd
v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1344
lib: 394 flatpak: 0 Shell: Zsh v: 5.8 running in: kitty
inxi: 3.3.01
