Pamac icon no longer showing up in system tray
Ever since a few updates ago, the Pamac icon has permanently disappeared from my system tray and I can’t figure out why, everything else is there but it. The option “hide tray icon when no update” is disabled in Pamac settings… its icon doesn’t reappear even when I get a notification popup for new updates anyway, which itself still works as Pamac auto-checks for updates and provides a functional clickable message. It’s not disabled in the system tray’s entries tab either, the Pamac / Updates icon isn’t listed there at all! My mother’s computer also uses Manjaro / Plasma Wayland session, for her the icon is showing up accordingly… could it be some user related breakage?
Just realized: The same is true for the firewall icon! I used to have one very long ago, firewall is still enabled but no icon and no entry anywhere. What could cause those specific icons to disappear?
I do not know what firewall you’re talking about — there are many possible choices — but do you have pamac-tray-icon-plasma installed?
Did you check your “Status and Notifications” settings? I have ‘Properties’ when right-clicking my XFCE ‘Status Tray-Extension’ where I can hide icons on a second tab - e.g. I can hide the power management icon, although it’s still enabled in the power settings. This may be different for KDE, though.
D.
Yes, just checked and that package didn’t get uninstalled.
Hi, i had the same here and it returns to normal without any action…
Have you changed anything in System Settings → Notifications? If the Defaults button on that page is disabled you haven’t, otherwise try using it.
Jul 21 16:47:47 systemd[1222]: app-\x2fusr\x2fbin\x2fpamac\x2dtray\x2dplasma-5bb112ec5168477fbcebf91456c8123a.scope: Failed to add PIDs to scope's control group: No such process
Jul 21 16:47:47 systemd[1222]: app-\x2fusr\x2fbin\x2fpamac\x2dtray\x2dplasma-5bb112ec5168477fbcebf91456c8123a.scope: Failed with result 'resources'.
Jul 21 16:47:47 systemd[1222]: Failed to start /usr/bin/pamac-tray-plasma.
sometimes it loads it sometimes it doesn’t.
I have not yet found out the reason
I checked System Settings - Notifications as well, nothing out of place that I can see. It’s surely a bug related to what you mentioned: What’s the best command to print mine and double-check?
This what mine looks like;
And Application-specific settings;
Yes… double-checked and same for me, it’s not anything in there causing it.
Post output of journalctl -b | grep pamac.
That was surprisingly long… haven’t restarted in a few days so that’s why, hopefully means it includes as much info as possible.
Jul 20 18:06:26 linux-qz0r systemd[1468]: app-pamac\x2dtray@autostart.service: Skipped due to 'exec-condition'.
Jul 20 18:06:26 linux-qz0r systemd[1468]: app-pamac\x2dtray\x2dbudgie@autostart.service: Skipped due to 'exec-condition'.
Jul 20 18:06:26 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 20 18:06:27 linux-qz0r pamac-tray-plasma[2776]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 20 18:06:27 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 20 18:06:51 linux-qz0r pamac-tray-plasma[1838]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Jul 20 20:07:18 linux-qz0r plasmashell[1628]: QString::arg: 2 argument(s) missing in org.manjaro.pamac.manager
Jul 20 20:07:18 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.299' (uid=1000 pid=25575 comm="/usr/bin/pamac-manager")
Jul 20 20:07:18 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 20 20:07:20 linux-qz0r pamac-manager[25575]: _gtk_css_corner_value_get_x: assertion 'corner->class == &GTK_CSS_VALUE_CORNER' failed
Jul 20 20:07:20 linux-qz0r pamac-manager[25575]: _gtk_css_corner_value_get_y: assertion 'corner->class == &GTK_CSS_VALUE_CORNER' failed
Jul 20 20:07:21 linux-qz0r pamac-manager[25575]: _gtk_css_corner_value_get_x: assertion 'corner->class == &GTK_CSS_VALUE_CORNER' failed
Jul 20 20:07:21 linux-qz0r pamac-manager[25575]: _gtk_css_corner_value_get_y: assertion 'corner->class == &GTK_CSS_VALUE_CORNER' failed
Jul 20 20:07:25 linux-qz0r polkitd[998]: Operator of unix-session:2 successfully authenticated as unix-user:mircea to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.299 [/usr/bin/pamac-manager] (owned by unix-user:mircea)
Jul 20 20:07:57 linux-qz0r systemd[1]: Reloading requested from client PID 26079 (unit pamac-daemon.service)...
Jul 20 20:08:02 linux-qz0r plasmashell[1628]: kf.kio.core: Url QUrl("file:///usr/share/applications/org.manjaro.pamac.manager.desktop") already represents a local file, cancelling job.
Jul 20 20:08:19 linux-qz0r systemd[1468]: app-org.manjaro.pamac.manager-cc71abbaccb8411982def6f74f1f5a0a.scope: Consumed 3.175s CPU time.
Jul 20 22:39:00 linux-qz0r plasmashell[1628]: QString::arg: 2 argument(s) missing in org.manjaro.pamac.manager
Jul 20 22:39:00 linux-qz0r dbus-daemon[1497]: [session uid=1000 pid=1497] Activating service name='org.manjaro.pamac.manager' requested by ':1.17' (uid=1000 pid=1628 comm="/usr/bin/plasmashell --no-respawn")
Jul 20 22:39:01 linux-qz0r dbus-daemon[1497]: [session uid=1000 pid=1497] Successfully activated service 'org.manjaro.pamac.manager'
Jul 20 22:48:22 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 20 22:48:24 linux-qz0r pamac-tray-plasma[47111]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 20 22:48:24 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 20 23:48:22 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 20 23:48:24 linux-qz0r pamac-tray-plasma[84264]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 20 23:48:24 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 00:00:12 linux-qz0r CROND[92386]: (mircea) CMDOUT (.config/pamac/)
Jul 21 00:00:12 linux-qz0r CROND[92386]: (mircea) CMDOUT (.config/pamac/config)
Jul 21 00:48:22 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 00:48:27 linux-qz0r pamac-tray-plasma[123024]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 00:48:27 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 01:48:22 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 01:48:24 linux-qz0r pamac-tray-plasma[161376]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 01:48:24 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 02:48:22 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 02:48:24 linux-qz0r pamac-tray-plasma[203322]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 02:48:24 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 03:48:22 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 03:48:34 linux-qz0r pamac-tray-plasma[239478]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 03:48:34 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 04:48:22 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 04:48:24 linux-qz0r pamac-tray-plasma[275774]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 04:48:24 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 14:57:25 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 14:57:26 linux-qz0r pamac-tray-plasma[314214]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 14:57:26 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 15:57:26 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 15:57:27 linux-qz0r pamac-tray-plasma[351448]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 15:57:27 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 17:59:43 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 17:59:45 linux-qz0r pamac-tray-plasma[393911]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 17:59:45 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 18:59:43 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 18:59:45 linux-qz0r pamac-tray-plasma[431600]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 18:59:45 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 22:25:43 linux-qz0r systemd[1]: pamac-mirrorlist.service: Deactivated successfully.
Jul 21 23:05:55 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 23:05:56 linux-qz0r pamac-tray-plasma[472451]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 23:06:14 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 21 23:06:14 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 21 23:06:14 linux-qz0r systemd[1]: pamac-daemon.service: Consumed 1.303s CPU time.
Jul 21 23:06:30 linux-qz0r plasmashell[1628]: QString::arg: 2 argument(s) missing in org.manjaro.pamac.manager
Jul 21 23:06:31 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.5085' (uid=1000 pid=472825 comm="/usr/bin/pamac-manager")
Jul 21 23:06:31 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 21 23:06:37 linux-qz0r plasmashell[472948]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 23:06:41 linux-qz0r polkitd[998]: Operator of unix-session:2 successfully authenticated as unix-user:mircea to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.5085 [/usr/bin/pamac-manager] (owned by unix-user:mircea)
Jul 21 23:06:46 linux-qz0r plasmashell[473131]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 23:06:47 linux-qz0r systemd[1468]: app-org.manjaro.pamac.manager-84327e34664f4dc28a7d4454e8cc664b.scope: Consumed 2.994s CPU time.
Jul 21 23:06:48 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 23:06:48 linux-qz0r pamac-tray-plasma[473150]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 23:06:49 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 21 23:06:50 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 21 23:06:50 linux-qz0r pamac-tray-plasma[473207]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 21 23:06:50 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 00:00:02 linux-qz0r CROND[504916]: (mircea) CMDOUT (.config/pamac/)
Jul 22 00:00:02 linux-qz0r CROND[504916]: (mircea) CMDOUT (.config/pamac/config)
Jul 22 00:05:55 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 00:05:56 linux-qz0r pamac-tray-plasma[508776]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 00:06:02 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 22 00:06:02 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 22 00:06:02 linux-qz0r systemd[1]: pamac-daemon.service: Consumed 2.323s CPU time.
Jul 22 00:06:05 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.5313' (uid=1000 pid=508850 comm="/usr/bin/pamac-manager --updates")
Jul 22 00:06:05 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 22 00:06:06 linux-qz0r pamac-tray-plasma[508927]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 00:06:06 linux-qz0r pamac-tray-plasma[508964]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 00:06:07 linux-qz0r pamac-tray-plasma[508965]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 00:06:13 linux-qz0r polkitd[998]: Operator of unix-session:2 successfully authenticated as unix-user:mircea to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.5313 [/usr/bin/pamac-manager --updates] (owned by unix-user:mircea)
Jul 22 00:06:17 linux-qz0r pamac-tray-plasma[509128]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 00:06:20 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 00:06:20 linux-qz0r pamac-tray-plasma[509158]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 00:06:20 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 00:06:21 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 00:06:21 linux-qz0r pamac-tray-plasma[509210]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 00:06:22 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 01:05:55 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 01:05:55 linux-qz0r pamac-tray-plasma[549321]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 01:05:55 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 02:05:55 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 02:05:56 linux-qz0r pamac-tray-plasma[586347]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 02:05:56 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 03:05:55 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 03:05:55 linux-qz0r pamac-tray-plasma[620750]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 03:05:55 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 04:05:55 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 04:05:55 linux-qz0r pamac-tray-plasma[656945]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 04:05:55 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 15:24:41 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 15:24:41 linux-qz0r pamac-tray-plasma[695806]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 15:24:41 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 16:24:41 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 16:24:42 linux-qz0r pamac-tray-plasma[734888]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 16:24:42 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 17:24:41 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 17:24:43 linux-qz0r pamac-tray-plasma[773791]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 17:24:43 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 18:24:41 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 18:24:43 linux-qz0r pamac-tray-plasma[812158]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 18:24:43 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 0 updates found
Jul 22 20:36:36 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 20:36:39 linux-qz0r pamac-tray-plasma[849743]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 20:36:44 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 22 20:36:44 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 22 20:36:44 linux-qz0r systemd[1]: pamac-daemon.service: Consumed 1.485s CPU time.
Jul 22 22:54:29 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 22:54:31 linux-qz0r pamac-tray-plasma[889696]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 22:54:39 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.8283' (uid=1000 pid=889640 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 22 22:54:39 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 22 22:54:41 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 22 22:54:41 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 22 23:54:29 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 22 23:54:30 linux-qz0r pamac-tray-plasma[925679]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 22 23:54:30 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.8624' (uid=1000 pid=925666 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 22 23:54:30 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 22 23:54:31 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 22 23:54:31 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 00:00:06 linux-qz0r CROND[929192]: (mircea) CMDOUT (.config/pamac/)
Jul 23 00:00:06 linux-qz0r CROND[929192]: (mircea) CMDOUT (.config/pamac/config)
Jul 23 00:54:29 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 00:54:30 linux-qz0r pamac-tray-plasma[962073]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 00:54:30 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.9054' (uid=1000 pid=962060 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 00:54:30 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 00:54:31 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 00:54:31 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 23 01:54:29 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 01:54:30 linux-qz0r pamac-tray-plasma[1000082]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 01:54:30 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.9565' (uid=1000 pid=1000071 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 01:54:30 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 01:54:31 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 23 01:54:31 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 02:54:29 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 02:54:30 linux-qz0r pamac-tray-plasma[1038103]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 02:54:30 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.10134' (uid=1000 pid=1038046 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 02:54:31 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 02:54:31 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 23 02:54:31 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 03:54:29 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 03:54:30 linux-qz0r pamac-tray-plasma[1072191]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 03:54:30 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.10322' (uid=1000 pid=1072180 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 03:54:30 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 03:54:31 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 23 03:54:31 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 04:54:29 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 04:54:30 linux-qz0r pamac-tray-plasma[1106642]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 04:54:30 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.10587' (uid=1000 pid=1106630 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 04:54:31 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 04:54:31 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 23 04:54:31 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 05:54:29 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 05:54:30 linux-qz0r pamac-tray-plasma[1145341]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 05:54:30 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.10774' (uid=1000 pid=1145330 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 05:54:30 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 05:54:31 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 23 05:54:31 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 16:31:51 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 16:31:51 linux-qz0r pamac-tray-plasma[1187682]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 16:31:52 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.11014' (uid=1000 pid=1187670 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 16:31:52 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 16:31:53 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 16:31:53 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 23 17:31:51 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 17:31:51 linux-qz0r pamac-tray-plasma[1225925]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 17:31:52 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.11164' (uid=1000 pid=1225914 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 17:31:52 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 17:31:52 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 23 17:31:52 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 18:31:51 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 18:31:51 linux-qz0r pamac-tray-plasma[1265744]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 18:31:52 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.12278' (uid=1000 pid=1265729 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 18:31:52 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 18:31:52 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 23 18:31:52 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 19:31:51 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 19:31:51 linux-qz0r pamac-tray-plasma[1303075]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 19:31:52 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.12974' (uid=1000 pid=1303064 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 19:31:52 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 19:31:52 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 23 19:31:52 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 1 updates found
Jul 23 23:25:19 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 23 23:25:20 linux-qz0r pamac-tray-plasma[1348782]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 23 23:25:27 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.13378' (uid=1000 pid=1348770 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 23 23:25:27 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 23 23:25:28 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 2 updates found
Jul 23 23:25:28 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 24 00:25:19 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 24 00:25:20 linux-qz0r pamac-tray-plasma[1387130]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 24 00:25:21 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.13719' (uid=1000 pid=1387118 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 24 00:25:21 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 24 00:25:22 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 24 00:25:22 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 2 updates found
Jul 24 01:25:19 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 24 01:25:20 linux-qz0r pamac-tray-plasma[1423076]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 24 01:25:20 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.13879' (uid=1000 pid=1423062 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 24 01:25:20 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 24 01:25:21 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 24 01:25:21 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 2 updates found
Jul 24 02:25:19 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 24 02:25:19 linux-qz0r pamac-tray-plasma[1455981]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 24 02:25:20 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.14116' (uid=1000 pid=1455970 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 24 02:25:20 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 24 02:25:21 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 2 updates found
Jul 24 02:25:21 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 24 03:25:19 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 24 03:25:20 linux-qz0r pamac-tray-plasma[1490960]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 24 03:25:20 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.14245' (uid=1000 pid=1490948 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 24 03:25:20 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 24 03:25:21 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 24 03:25:21 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 2 updates found
Jul 24 04:25:19 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 24 04:25:19 linux-qz0r pamac-tray-plasma[1529669]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 24 04:25:20 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.14776' (uid=1000 pid=1529658 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 24 04:25:20 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 24 04:25:21 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 24 04:25:21 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 2 updates found
Jul 24 16:28:53 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:71: check updates
Jul 24 16:28:54 linux-qz0r pamac-tray-plasma[1572546]: touch: cannot touch '/var/tmp/pamac/dbs/sync/refresh_timestamp': Permission denied
Jul 24 16:28:54 linux-qz0r dbus-daemon[996]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.15017' (uid=1000 pid=1572535 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Jul 24 16:28:54 linux-qz0r dbus-daemon[996]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Jul 24 16:28:55 linux-qz0r systemd[1]: pamac-daemon.service: Deactivated successfully.
Jul 24 16:28:55 linux-qz0r pamac-tray-plas[1838]: updates_checker.vala:101: 2 updates found
Entries like these make it seem like its (another) case of permissions being wrong for pamac directories.
(possibly from using sudo pamac ... … though theres at least one thread out there contending its an internal bug of pamac)
There are a number of errors there.
I think that means XDG is borked. On KDE you should have xdg-desktop-portal and xdg-desktop-portal-kde installed. Check that they are and if not install them.
$ pacman -Qs xdg-desktop
local/xdg-desktop-portal 1.16.0-3
    Desktop integration portals for sandboxed apps
local/xdg-desktop-portal-kde 5.27.6-1 (plasma)
    A backend implementation for xdg-desktop-portal using Qt/KF5
This one;
usually means you’ve run sudo pamac at some point. To fix that try this;
And if you have others - you should likely uninstall them.
Though … xdg is a lot more than just the portals. xdg-utils and xdg-user-dirs being some of the packages.
These variables should be set by the DE …
https://wiki.archlinux.org/title/Xdg-utils
Yeah, if you search the interwebs for that error there are a number of results that just lead down blind alleys… the "app-pamac\x2dtray\x2dplasma@autostart.service" is failing because of ExecCondition=/usr/lib/systemd/systemd-xdg-autostart-condition "KDE" "" so I assume that error is connected too.
Both xdg-desktop-portal and xdg-desktop-portal-kde are installed, no other xdg-desktop-portal-* are installed just those two. KDE_FULL_SESSION is true whereas XDG_CURRENT_DESKTOP is KDE. Indeed I use sudo pacman -Syu at times when I find it easier, never knew it can cause any issues… I will attempt the solution you mentioned and see was that solves.
It cannot.
sudo pamac [...]
can.
pacman != pamac
Oh, wait: I never used sudo pamac only sudo pacman. Pamac is a GUI and I only open it from the menu as user, I should have never ran it as root. I recreated /var/tmp/pamac/dbs/sync as user followed by sudo pacman -Syy; pamac update and will see if that fixes it after a restart.
Something I noticed that my be relevant, though I think the missing icon issue was happening even before: Pamac seems to use a different GTK theme after the latest update. Like I have Breeze GTK set which is correctly used by Firefox and Thunderbird and such, but Pamac refuses to use the same theme and gives me a gray scheme with some circular buttons instead. Could it mean it’s now running as root internally for some unknown reason?
pamac is now gtk4 (and libadwaita).
The previous version is still in the repos as pamac-gtk3.
pamac is both a cli and gui tool.
I suppose only you really know if and how you have used it.
No. We really meant something like sudo pamac update. (and of course see previous comment)
