Conky thread, show your work!
how-to
conky
#1
Carrying on from the old forum:
https://classicforum.manjaro.org/index.php?topic=2991.0
If you attach a screen shot, please include the Conky config file you used to create your masterpiece.
edit: fixed link
Conky config
The weather in conky
How do you personally make Manjaro your own?
Authoritative August (2017) Screenshots
Gentoo desktop on manjaro
Conky "circles" doesn't work, ethernet also
Tips, Tricks and General Info for Manjaro LXDE Community Edition
Visualize disk free space [solved]
Adding new widgets to Conky-Manager
Jeopardised June (2016) Screenshots
Juicy July (2016) Screenshots
Upload files to the forum
Nonsensical November (2017) Screenshots
Jacked June (2018) Screenshots
Conky color gradiation with temperatue
Bios on asrock x470
Help Hiding Text in Conky
#2
Font http://ufonts.com/fonts/dungeon.html
#3
I’d like to thank the multitude of conky users I’ve pinched the following mangled code from:
conky.conf:
conky.config = {
	alignment = 'top_right',
	background = true,
	border_width = 1,
	cpu_avg_samples =  2,
	default_color = '88BBFF',
	color0  ='0077FF',
	color1 = '888888',
	default_outline_color = '0077FF',
	default_shade_color = '0077FF',
	double_buffer = true,
	draw_borders = false,
	draw_graph_borders = true,
	draw_outline = false,
	draw_shades = false,
	gap_x = 15,
	gap_y = 65 ,
	maximum_width = 210,
    minimum_height = 690,
    maximum_width = 200,
	max_port_monitor_connections = 64,
	max_user_text = 16384,
	net_avg_samples = 2,
	no_buffers = true,
	out_to_console = false,
	wm_class_name = 'Conky',
	own_window_colour = 'black',
	own_window_hints = 'undecorated,below,sticky,skip_taskbar,skip_pager',
	own_window_transparent = true,
	own_window_type = 'normal',
	own_window = true,
	stippled_borders = 2,
	update_interval = 2,
	uppercase = false,
	use_spacer = 'left',
	use_xft = true,
	xftalpha = 0.8,
	--font  = 'Bitstream Vera Sans Mono:size=9',
	font  = 'Droid Sans Mono:size=9',
	--font  = 'monospace:size=8'
conky.text = [[
#${font URW Gothic Book:style=Bold:size=24}${color1}${alignc}${time %H:%M:%S}
${font League Gothic:size=36}${color1}${alignc}${time %H:%M}
${voffset -36}${font League Gothic:size=14}${alignc}${time  %a %d %B %Y}
${color0}${alignc}$sysname $kernel
${alignc}${machine} @ $freq(MHz)
${font}
${voffset -32}
${color0}All  :$color ${cpu cpu0}%$alignr${exec sensors | grep 'Core 0' | cut -c16-22 | sed '/^$/d'}
${color0}${cpugraph cpu0 18,200 0077FF 0077ff}
${color0}Core1:$color ${cpu cpu1}%$alignr${exec sensors | grep 'Core 1' | cut -c16-22 | sed '/^$/d'}
${color0}${cpugraph cpu1 18,200 0077FF 0077ff}
${color0}Core2:$color ${cpu cpu2}%$alignr${exec sensors | grep 'Core 2' | cut -c16-22 | sed '/^$/d'}
${color0}${cpugraph cpu2 18,200 0077FF 0077ff}
${color0}Core3:$color ${cpu cpu3}%$alignr${exec sensors | grep 'Core 3' | cut -c16-22 | sed '/^$/d'}
${color0}${cpugraph cpu3 18,200 0077FF 0077ff}
${color0}Core4:$color ${cpu cpu4}%$alignr${exec sensors | grep 'Core 4' | cut -c16-22 | sed '/^$/d'}
${color0}${cpugraph cpu4 18,200 0077FF 0077ff}
${color0}GPU${alignr}${execi 10 nvidia-smi -q -d TEMPERATURE | awk '/GPU Current Temp/ {print $5}'} °C
${voffset}
${color0}RAM: $color$memperc%$alignr$mem${color0}/${color}$memmax
${color0}$membar
${color0}Down: $color${downspeed enp4s0}$alignr${totaldown enp4s0}
${color0}${downspeedgraph enp4s0 18,200 0077ff 0077ff}
${color0}Up:   $color${upspeed enp4s0}$alignr${totalup enp4s0}
${color0}${upspeedgraph enp0s25 18,210 0077FF 0077ff}
${color0}/$alignr$color${fs_used /}${color0}/$color${fs_size /}
${color0}${fs_bar 5,200 /}
${color0}/home$alignr$color${fs_used /home}${color0}/$color${fs_size /home}
${color0}${fs_bar 5,200 /home}
${color0}/var$alignr$color${fs_used /var}${color0}/$color${fs_size /var}
${color0}${fs_bar 5,200 /var}
#|--SWAP
${voffset 5}${font Droid Sans:style=Bold:size=8}SWP${font}${goto 40}Swap: ${font Droid Sans:style=Bold:size=8}${swapperc}%${font}
${voffset 4}${offset 1}${voffset -7}${swapbar 4,200}
${voffset 1}${goto 20}Free: ${font Droid Sans:style=Bold:size=8}$swapmax${font} ${goto 80}    Used: ${font Droid Sans:style=Bold:size=8}$swap${font}
${color0}Read: $color${diskio_read}$alignr${color0}Write: $color${diskio_write}
${color0}${diskiograph /dev/sda 18,200 0077FF 0077ff}
${color0}Top:${alignr}CPU%
$color${top name 1}$alignr${top cpu 1}
$color${top name 2}$alignr${top cpu 2}
$color${top name 3}$alignr${top cpu 3}
$color${top name 4}$alignr${top cpu 4}
$color${top name 5}$alignr${top cpu 5}
$color${top name 6}$alignr${top cpu 6}
$color${top name 6}$alignr${top cpu 7}
${color0}${alignr}MEM
$color${top_mem name 1}$alignr${top_mem mem_res 1}
$color${top_mem name 2}$alignr${top_mem mem_res 2}
$color${top_mem name 3}$alignr${top_mem mem_res 3}
$color${top_mem name 4}$alignr${top_mem mem_res 4}
$color${top_mem name 5}$alignr${top_mem mem_res 5}
$color${top_mem name 6}$alignr${top_mem mem_res 6}
$color${top_mem name 7}$alignr${top_mem mem_res 7}
Font is League Gothic https://www.theleagueofmoveabletype.com/
When Conky refreshes, it prints on top of itself
Need something like HWinfo for manjaro
#4
my goto :trident:
https://gist.github.com/0ptics/d6a896e2fb4240c866534cae7fd68e1c#file-optconk
#5
If I am in Manjaro XFCE, I just need to install conky and use your config? or do I need to make some change?
My resolution of monitor is 1920*1080 btw
#6
no changes needed, use it on xfce.
#7
thks, really beautiful conky
#8
After I install conky, it works, but when I reboot the system, my conky will show like this;
how can I fix it
#9
You have to make the following changes too. Common sense.
  1. install the ‘dungeon’ font i provided the link to.
  2. Change the hard drive section with your own mount points
    ${voffset 10}Root$alignr$color2${fs_used /}/${fs_size /}$color ${fs_bar 3,200 /} Home$alignr$color2${fs_used /home}/${fs_size /home}$color ${fs_bar 3,200 /home} myDisk1$alignr$color2${fs_used /mnt/myDisk1}/${fs_size /mnt/myDisk1}$color ${fs_bar 3,200 /mnt/myDisk1} myDisk2$alignr$color2${fs_used /mnt/myDisk2}/${fs_size /mnt/myDisk2}$color ${fs_bar 3,200 /mnt/myDisk2}
  3. Change the network section with your own network devices
    ${voffset 10}E: Down $color2${downspeedf enp7s0}KiB${alignr}${upspeedf enp7s0}KiB$color Up W: Down $color2${downspeedf wlp4s0}KiB${alignr}${upspeedf wlp4s0}KiB$color Up
  4. Finally, change your location code for weather info . Go to http://weather.noaa.gov/international.html
    ${voffset 10}Kolkata (IN)${alignr}${weather http://weather.noaa.gov/pub/data/observations/metar/stations/ VECC weather weather 60},${weather http://weather.noaa.gov/pub/data/observations/metar/stations/ VECC temperature temperature 60}°C
And most importantly, delay your conky by 10 seconds or so. It doesn’t play well with xfdesktop. Startup command is
sh -c "sleep 10s && conky -c $HOME/.conkyrc"
#10
Thks, but for the weather, the link you give to me I can not find any code in that site, my current location is Paris France
#11
#12
it works!!! love u!!!:heart_eyes:
#13
${voffset 10}Paris (FR)${alignr}${weather http://weather.noaa.gov/pub/data/observations/metar/stations/ LFPB weather weather 60},${weather http://weather.noaa.gov/pub/data/observations/metar/stations/ LFPB temperature temperature 60}°C
here in weather, it just shows the temperature, it doesn’t show the weather, is there some thing wrong here?
#14
rtfm
#15
I noticed here
                    weather -
                <p>Any relevant weather event (rain, snow,
                etc.). This is not used if you are querying the
                weather.com site since this data is aggregated
                into the cloud_cover one</p>
            </li>
It means I need to change the “weather” to “cloud_cover” right?
#16
@Vamposine
Please “reply as linked topic” next time, this thread is only to scrot and gist your conkyrc ( @Orajnam add this line to your post#1 :slight_smile: ) .
If an op could please chop-off from post#5 Conky thread, show your work!
down to #15 and link it to new thread, that’ll be great. @eugen-b @jonathon gratitude in advance.
#17
Okay, I’ll be attention to it next time.
split this topic #18
12 posts were split to a new topic: Troubleshooting conky for JWM Edition
#30
Config:
http://pastebin.com/edS8Hze9
#31
Here is my assets for the conky, this is not my creation it is from here: https://github.com/oberon2007/conkies
Desktop screenshot here: Juicy July (2016) Screenshots
[quote]
conky.config = {
gap_x = 25,
gap_y = 15,
background = yes,
update_interval = 1.0,
override_utf8_locale = true,
no_buffers = true,
text_buffer_size = 2048,
temperature_unit = 'celsius',
own_window = true,
own_window_type = 'override',
own_window_class = 'Conky',
border_inner_margin = 0,
border_outer_margin = 0,
minimum_height = 200,
  minimum_width = 50,
draw_graph_borders = false,
use_xft = true,
font = 'Bitstream Vera Sans:size=8',
xftalpha = 0.5,
uppercase = false,
default_color = 'FFFFFF',
color2 = '2ECC71',
lua_load = '/usr/share/conky/clock_rings_green.lua',
lua_draw_hook_pre = 'clock_rings'
conky.text = [[
${voffset 8}$color2${font Bitstream Vera Sans:size=16}${time %A}$font
${voffset -8}$alignr$color${font Bitstream Vera Sans:size=38}${time %e}$font
$color${voffset -30}$color${font Bitstream Vera Sans:size=18}${time %b}$font
${voffset -3} $color${font Bitstream Vera Sans:size=20}${time %Y}$font$color2$hr
${voffset -17}${image /usr/share/icons/logo_green.png -p 69,116 -s 60x74}
Use the search function on http://weather.noaa.gov/ to find your desired four letter city codes and replace “LOWW” and “KDET” in the next lines:
${voffset 162}${font Bitstream Vera Sans:size=10}${alignr}Sydney
${font Bitstream Vera Sans:size=12}$color$alignr${weather http://weather.noaa.gov/pub/data/observations/metar/stations/ YSSY temperature temperature 15} °C
${goto 20}${voffset -50}$font${cpu cpu0}%
$color2${goto 20}CPU
$color${goto 45}${voffset 23}$mem
$color2${goto 45}RAM
uncomment and activate in /usr/share/conky/clock_rings_grey.lua to display swap usage:
${color}${goto 70}${voffset 23}${swapperc}%
${color2}${goto 70}Swap
$color${goto 70}${voffset 24}${fs_used_perc /}%
$color2${goto 70}Disk
$color${goto 95}${voffset 24}${downspeed enp3s0}
$color${goto 95}${upspeed enp3s0}
$color2${goto 95}Lan
$color${goto 120}${voffset 11}${downspeed wlp2s0}
$color${goto 120}${upspeed wlp2s0}
$color2${goto 120}Wlan
${voffset 10}${color2}uptime: $color$uptime_short
${voffset 15}${color2}processes${offset 6}$color $running_processes / $processes${goto 127}${color2}CPU${alignr 8}RAM
${voffset 7}${top name 1} ${goto 115}$color${top cpu 1}%
$color2${top name 2} ${goto 115}$color${top cpu 2}%
$color2${top name 3} ${goto 115}$color${top cpu 3}%
$color2${top name 4} ${goto 115}$color${top cpu 4}%
${voffset 7}$color2${top_mem name 1}$alignr$color${top_mem mem_res 1}
$color2${top_mem name 2}$alignr$color${top_mem mem_res 2}
$color2${top_mem name 3}$alignr$color${top_mem mem_res 3}
$color2${top_mem name 4}$alignr$color${top_mem mem_res 4}
${voffset 15}$color2$font$alignr${execi 5000 whoami}@$nodename
to display arch uncomment:
${color2}${font Bitstream Vera Sans:size=8}${alignr}kernel: $color${kernel} $machine
to display distribution-details uncomment:
$alignr$color${execi 5000 awk -F= ‘/TION/ {print $2}’ /etc/lsb-release |sed ‘s/"//g’} {execi 5000 awk -F= ‘/EASE=/ {printf $2" "} /NAME/ {print $2}’ /etc/lsb-release}[/quote][details=Summary]This text will be hidden[/details]
