Has worked for years, but after updating to the 5.10 kernel this morning it works no more, it is just blank.
Is there some replacement for it?
NB Booted an older kernel and it works again, but not with 5.10, so it certainly looks kernel related.
Two answers below both correct but moson’s idea about using names instead of numbers should render any further tweaks unnecessary.
Occasionally, the monitor listings at /sys/class/hwmon/* will change (just like /dev/sda will automagically be re-assigned to /dev/sdb.
You’ll have to look at /sys/class/hwmon/* and determine what was changed, and make your changes in your conf file accordingly.
Most likely, after a few boots, it will settle down and the listing will become stable. I haven’t had to make any hwmon changes for almost a year, now.
