The entire OS randomly crashes
Hey!
So only today I had an issue with the OS randomly crashing while in a Discord call.
rugp. 06 13:59:16 rPC NetworkManager[8493]: <info>  [1628258356.8702] device (lebridge0): state change: disconnected -> unmanaged (reason 'user-requested', sys-iface-state: 'managed')
rugp. 06 13:59:16 rPC NetworkManager[8493]: <info>  [1628258356.8710] device (wlp4s0.14): state change: deactivating -> disconnected (reason 'dependency-failed', sys-iface-state: 'managed')
rugp. 06 13:59:16 rPC gnome-shell[9777]: Removing a network device that was not added
rugp. 06 13:59:16 rPC NetworkManager[8493]: <info>  [1628258356.9038] device (wlp4s0.14): state change: disconnected -> unmanaged (reason 'user-requested', sys-iface-state: 'managed')
rugp. 06 13:59:24 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-70 noise=9999 txrate=39000
rugp. 06 13:59:26 rPC systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
rugp. 06 13:59:26 rPC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
rugp. 06 13:59:26 rPC kernel: audit: type=1131 audit(1628258366.791:3177): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
rugp. 06 13:59:27 rPC wpa_supplicant[9089]: wlp4s0: Reject scan trigger since one is already pending
rugp. 06 13:59:37 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 13:59:38 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 13:59:39 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 13:59:40 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: discord1, Impossible to lookup icon for 'discord1_14887-panel' in path /tmp/.org.chromium.Chromium.6pocin
rugp. 06 13:59:40 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: unable to update icon for discord1
rugp. 06 13:59:40 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 13:59:40 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: discord1, Impossible to lookup icon for 'discord1_14888-panel' in path /tmp/.org.chromium.Chromium.nFDFJb
rugp. 06 13:59:41 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 13:59:42 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 13:59:42 rPC gnome-shell[9777]: pushModal: invocation of begin_modal failed
rugp. 06 13:59:56 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 13:59:57 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:00:06 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: discord1, Impossible to lookup icon for 'discord1_14899-panel' in path /tmp/.org.chromium.Chromium.2AdpnG
rugp. 06 14:00:06 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: unable to update icon for discord1
rugp. 06 14:00:10 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:00:11 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:00:12 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:00:26 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:00:27 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:00:41 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:00:42 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:00:42 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: discord1, Impossible to lookup icon for 'discord1_14919-panel' in path /tmp/.org.chromium.Chromium.mjQ0mQ
rugp. 06 14:00:42 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: unable to update icon for discord1
rugp. 06 14:00:55 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:00:56 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:00:57 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:01:01 rPC CROND[93136]: (root) CMD (run-parts /etc/cron.hourly)
rugp. 06 14:01:01 rPC CROND[93135]: (root) CMDEND (run-parts /etc/cron.hourly)
rugp. 06 14:01:05 rPC wpa_supplicant[9089]: wlp4s0: WPA: Group rekeying completed with a4:91:b1:42:c1:47 [GTK=CCMP]
rugp. 06 14:01:11 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:01:12 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:01:22 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: discord1, Impossible to lookup icon for 'discord1_14941-panel' in path /tmp/.org.chromium.Chromium.SyrKu3
rugp. 06 14:01:22 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: unable to update icon for discord1
rugp. 06 14:01:26 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:01:27 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:01:31 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: discord1, Impossible to lookup icon for 'discord1_14951-panel' in path /tmp/.org.chromium.Chromium.csSMpb
rugp. 06 14:01:31 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: unable to update icon for discord1
rugp. 06 14:01:41 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:01:47 rPC gnome-shell[9777]: percentage lengths not currently supported
rugp. 06 14:01:48 rPC gnome-shell[9777]: percentage lengths not currently supported
rugp. 06 14:01:56 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:01:57 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:10 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:11 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:12 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:16 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: discord1, Impossible to lookup icon for 'discord1_14985-panel' in path /tmp/.org.chromium.Chromium.pCIgBl
rugp. 06 14:02:16 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: unable to update icon for discord1
rugp. 06 14:02:17 rPC gnome-shell[9777]: percentage lengths not currently supported
rugp. 06 14:02:18 rPC gnome-shell[9777]: percentage lengths not currently supported
rugp. 06 14:02:19 rPC gnome-shell[9777]: percentage lengths not currently supported
rugp. 06 14:02:25 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:26 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:27 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:29 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: discord1, Impossible to lookup icon for 'discord1_14997-panel' in path /tmp/.org.chromium.Chromium.4b3eRQ
rugp. 06 14:02:29 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: unable to update icon for discord1
rugp. 06 14:02:32 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: discord1, Impossible to lookup icon for 'discord1_14999-panel' in path /tmp/.org.chromium.Chromium.OllVCC
rugp. 06 14:02:32 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: unable to update icon for discord1
rugp. 06 14:02:41 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:42 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:55 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:56 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:02:57 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:03:08 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: discord1, Impossible to lookup icon for 'discord1_15025-panel' in path /tmp/.org.chromium.Chromium.4jx0JE
rugp. 06 14:03:08 rPC appindicatorsupport@rgcjonas.gmail.com[9777]: unable to update icon for discord1
rugp. 06 14:03:11 rPC discord.desktop[10663]: [2021-08-06 14:03:11.159] [10687] (audio_send_stream.cc:344): Failed to set up send codec state.
rugp. 06 14:03:11 rPC discord.desktop[10663]: rtc_log_set_paused: false
rugp. 06 14:03:11 rPC discord.desktop[10663]: rtc_log_set_paused error: monitor_option.is_none()
rugp. 06 14:03:11 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:03:11 rPC discord.desktop[10663]: [2021-08-06 14:03:11.211] [10687] (audio_send_stream.cc:344): Failed to set up send codec state.
rugp. 06 14:03:11 rPC discord.desktop[10663]: [2021-08-06 14:03:11.211] [10687] (audio_device_generic.cc:32): BuiltInAECIsAvailable: Not supported on this platform
rugp. 06 14:03:11 rPC discord.desktop[10663]: [OpenH264] this = 0x0x23c966b5a0, Warning:ParamValidationExt(), eSpsPpsIdStrategy setting (2) with iUsageType (1) not supported! eSpsPpsIdStrategy adjusted to CONSTANT_ID
rugp. 06 14:03:11 rPC discord.desktop[10663]: [OpenH264] this = 0x0x23c966b5a0, Warning:ParamValidation(), AdaptiveQuant(1) is not supported yet for screen content, auto turned off
rugp. 06 14:03:11 rPC discord.desktop[10663]: [OpenH264] this = 0x0x23cce6e810, Warning:ParamValidationExt(), eSpsPpsIdStrategy setting (2) with iUsageType (1) not supported! eSpsPpsIdStrategy adjusted to CONSTANT_ID
rugp. 06 14:03:11 rPC discord.desktop[10663]: [OpenH264] this = 0x0x23cce6e810, Warning:ParamValidation(), AdaptiveQuant(1) is not supported yet for screen content, auto turned off
rugp. 06 14:03:11 rPC discord.desktop[10663]: [OpenH264] this = 0x0x23cce6e810, Warning:Actual input framerate fAverageFrameRate = 0.000000 is quite different from framerate in setting 60.000000, please check setting or timestamp unit (ms), start_Ts = 3837247391589
rugp. 06 14:03:11 rPC discord.desktop[10663]: [OpenH264] this = 0x0x23cce6e810, Warning:[Rc] iDid = 0,iContinualSkipFrames(3) is large
rugp. 06 14:03:11 rPC discord.desktop[10663]: [OpenH264] this = 0x0x23cce6e810, Warning:[Rc] iDid = 0,iContinualSkipFrames(6) is large
rugp. 06 14:03:11 rPC discord.desktop[10663]: [OpenH264] this = 0x0x23cce6e810, Warning:[Rc] iDid = 0,iContinualSkipFrames(9) is large
rugp. 06 14:03:12 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:03:13 rPC discord.desktop[10663]: [OpenH264] this = 0x0x23cce6e810, Warning:Actual input fLatestFrameRate = 0.000000 is quite different from framerate in setting 36.000000, please check setting or timestamp unit (ms), cur_Ts = 3837247393625 start_Ts = 0
rugp. 06 14:03:17 rPC /usr/lib/gdm-x-session[9592]: (II) event7  - USB Gaming Mouse: SYN_DROPPED event - some input events have been lost.
rugp. 06 14:03:19 rPC /usr/lib/gdm-x-session[9592]: (II) event7  - USB Gaming Mouse: SYN_DROPPED event - some input events have been lost.
rugp. 06 14:03:22 rPC /usr/lib/gdm-x-session[9592]: (II) event7  - USB Gaming Mouse: SYN_DROPPED event - some input events have been lost.
rugp. 06 14:03:24 rPC /usr/lib/gdm-x-session[9592]: (II) event7  - USB Gaming Mouse: SYN_DROPPED event - some input events have been lost.
rugp. 06 14:03:26 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:03:37 rPC /usr/lib/gdm-x-session[9592]: (II) event7  - USB Gaming Mouse: SYN_DROPPED event - some input events have been lost.
rugp. 06 14:03:37 rPC /usr/lib/gdm-x-session[9592]: (II) event7  - USB Gaming Mouse: WARNING: log rate limit exceeded (5 msgs per 30s). Discarding future messages.
rugp. 06 14:03:27 rPC wpa_supplicant[9089]: wlp4s0: CTRL-EVENT-BEACON-LOSS
rugp. 06 14:03:29 rPC pulseaudio[9779]: q overrun, queuing locally
rugp. 06 14:04:07 rPC discord.desktop[10663]: [OpenH264] this = 0x0x23cce6e810, Warning:Actual input framerate fAverageFrameRate = 5.561230 is quite different from framerate in setting 60.000000, please check setting or timestamp unit (ms), start_Ts = 3837247391589
No real idea what happened, anyone here able to explain it?
The apps that I had open were:
Discord, Firefox browser, Minecraft, gedit, vscode, terminal, I think thats about all.
Also, I recently had around a 1GB operation to install with the add/remove software app so i think that was an update. Before this has never happened.
Gotta mention, I also started screensharing and right after, it crashed.
Hi there, welcome to the forum!
I’m afraid the information you have provided won’t help us help you very much.
Since you’re new to this forum, I’d recommend you take a look at the link below:
That way other users might be able to help out. :slightly_smiling_face:
I also recommend you check out the forum rules (If you haven’t done that yet):
https://wiki.manjaro.org/index.php?title=Forum_Rules
Thank you!
