No mount point is at /dev/nvme0n1p1
with FAT32 ?
Iām not sure quite what you mean?
corrupted Manjaro is installed on Btrfs partition 0n1p2 but I believe it is mounted from the FAT32 position or is that something to do with UFEI? @Zesko
I have a screenshot from a previous install saying I had used /boot/efi as a mount point. Does that mean I should use the same again? Not 100% certain what that means but I do know that I normally boot using efi @Zesko
Yes that should be FAT32 for EFI.
Yes, you can. I suspect it will automatically create 3 subvolumes @home
for home directory, @
for root directory and ⦠at this installation.
Iām not quite sure how to restore my backup from Timeshift? Do I need to tell it to put things into the subvolumes or will it restoring to / and /home sort into the new btrfs subvolumes correctly?
