I have tried to find information on the gui settings “check for updates” but everything I find is about cli.
aur and flatpack are enabled so I can install from them both.
I have the “check for updates” settings active on both aur and flatpac activated and disabled in the general settings tab.
The behavior I’m looking for is for manjaro to never check for updates automatically, I want to update the lists manually and then upgrade.
Are my settings correct? What does the setting do? Does it mean “update lists automatically” or does it mean, “check for updates when you are manually refreshing the lists”?
Edit. Ie, im interpreting the “check for updates” on the 3:rd party tab as running pamac checkupdates -a
when refreshing the lists.
Am I correct in this assumption?
