Hi. I have troubles installing a module called “neoAPI” for python: ERROR: neoapi-1.3.0-cp310-cp310-linux_x86_64.whl is not a supported wheel on this platform.
The supplier of the software “neoAPI” writes in his documentation:
run python3 -m pip install neoapi_<neoapi-version>-cp<python-version>-cp<python-version>m-<platform>.whl to install the neoAPI
Here is the most relevant system information: (baumer_test) [dejhost@lenovoB50 wheel]$ python3 --version Python 3.11.3
You could use pyenv to install a local version of 3.10, or ask the developer to build the wheels for 3.11, (maybe build it yourself?). But seeing that the last commit was in 2015, I guess you should migrate to another package.
So far, so good. in what way would the initial command change? I still get
python3 -m pip install neoapi-1.3.0-cp310-cp310-linux_x86_64.whl
