Conflict between linux-meta and linux617
Hi, I’m coming back to my Manjaro workstation after a while away and I’m getting an error with my big catch-up update. I’ve read a number of update threads and I can’t see this issue mentioned anywhere, though I noticed that 6.17 is EOL and that some people are having kernel issues. I’m used to just removing conflicting packages, but given this is the kernel, I really don’t want to mess around with it.
Here is the output of pacman -Syu:
 core is up to date
 extra is up to date
 multilib is up to date
:: Replace linux617 with core/linux-meta? [Y/n]
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: linux-meta-6.18-1 and linux617-6.17.13-1 are in conflict
Would really appreciate any guidance anyone can offer!
What is the issue in just changing the kernel? Have you tried 6.12 or 6.18? Afterwards remove 6.17 and you should be fine with updating.
Hit Yes or Enter. Of course it has to be replaced or there will be no kernel at all.
I did hit enter - I tried both Y and n to confirm and got the same output each time.
As @Wollie suggested I am going to try to change kernels now.
Update: cannot install linux618 kernel without updating [long list of packages], which includes both linux617 and linux-meta.
Resorting the mirrors and syncing might help.
sudo pacman-mirrors -f
For the record: syncing a heavily out of date system is not exactly an “update” problem since it is by definition in an unsupported state. And if it is more than a couple of months it may be easier to reinstall.
Thanks for the help, everyone. I refreshed my mirrors, and then ran sudo pacman -Syu --ignore linux617, which gave me the option to safely remove the package during the full system update. I planned to switch kernels from the boot menu on reboot, but it just rebooted as normal and defaulted to 6.18. Hopefully I won’t have to go this long without an update again, but it’s good to know for the future!
