Update Tuxedo packages for latest hardware (Aura 15 Gen1)
Hi,
Hope this is the right place to post this… Aura is not listed as an official Manjaro Hardware.
I just got a new Tuxedo Aura 15 Gen1. It’s an Ryzen 4700U with Vega graphics. I tried the following packages:
  • tuxedo-cc-wmi
  • tuxedo-control-center
  • tuxedo-keyboard-dkms
The keyboard (packager: @oberon) package is working fine, I’m able to use the keys to change backlight and all Fn keys work as expected (though I had to modify the config manually to persist the settings after reboot). However Tuxedo Control Center (packager: @nightmare-2021 ) and related cc-wmi) say that the hardware is not supported.
I then tried to build the packages directly from Tuxedo’s GitHub repos and then Control Center works - I can see the CPU temp and also set the processor speed.
I wonder if the owners of the packages could rebuild the above mentioned packages, so that I would not have to compile the packages myself.
Also if you can explain how you build the Tuxedo Manjaro packages… in the official repository I can’t find build scripts/instructions to build pacman packages.
Thank you for the heads up. I will look into updating those packages.
We are currently in progress to update those packages. There were some updates and some packages got dropped. Since we have direct contact with Tuxedo, a soluton will be available shortly.
Thank you both. I’ll keep an eye for new packages.
tuxedo-control-center 1.0.8-1.1 (unstable) should solve your problem :wink:
I’ll give it a try, thanks.
… or maybe it’s best to wait for the stable package… I saw that in order to use unstable it’s best to upgrade the whole system… I already have working packages built manually, don’t want to change the whole system for just a few packages :slight_smile:
Regarding tuxedo-keyboard-dkms… I stand corrected - if I use the AUR package the system fails to boot to graphics mode… I just get a black screen, can enter the console and uninstall, though.
It seems that I installed tuxedo-keyboard from source.
@samo_dadela
can you please explain it better? we should install the package by source or not? and which one exactly?
@Terence64w It seems that the latest update brings rebuilt packages… I did not try them yet though.
Problem is that the latest update removed the 5.7 kernel - and 5.10 is buggy as hell on Aura 15 (resume does not work, graphics locks up, backlight)…
I installed the new tuxedo-keyboard and tuxedo-control-center. Everything works as expected. Thanks guys!
I also did some testing compiling a project in Java:
  • tuxedo cc profile balanced: 1:15 (fans spin like when not using cc, though speed changes seem more jerky)
  • tuxedo cc profile cool and breezy: 2:09 (can’t hear fans at all)
  • tuxedo cc profile powersave extreme: 2:27 (totally silent)
  • no tuxedo cc: 1:15
Update: After some more testing I decide to disable tuxedo-control-center (systemctl disable tccd). You need to shutdown and restart or the cpu speeds will be kept. Control center version: 1.0.8-1.1. System: Tuxedo Aura 15 Gen1
Why: I noticed that the fan control was turning on-off and changing it’s speed too often - which was resulting in clicks coming from the fan. In one case it also did a not inspiring grinding sound. I reckon that changing the fan speed too often will wear the fan too soon.
Too describe it in more detail:
  • with mode Balanced and computer idle: at start the fan is at 0%… after some light load cpu temp goes up and fan starts at 15% which results in a click… after 5 seconds or so cpu is cool again and fan stops… 10 seconds later it again starts click…
  • with mode Freezy: fan start at around 10-15% (this mode I suspect want to keep the cpu temperature freezy)… after 1-2 seconds it increases the speed slightly which results in a click (because fan accelerates)… after 1-2 second it changes speed again.
There is no way I found to set some kind of hystersis without coding… I’ll report the same issue upstream.
The good guys at Tuxedo are working on a feature that will allow using TC only to control CPU speed (i.e. it will leave fan control to the BIOS):
Clicking on the fan shouldn’t happen otherwise didn’t respect PWM-specifications.
PWM specification say: Starting at (about) 30% and hold continuous voltage on the fan increasing by arise of temp/voltage proportionally (or through a self defined curve in the BIOS/UEFI) but still continuous.
The “clicking” is given by rectangular voltage (on, off, on, off, etc.), that’s out of specs (See PWM-specs 1.4).
Maybe this indication can help to resolve the problem.
Anyway, it make sense and is useful to can adjust the CPU-behavior/speed through Tuxedo manager let me say “online” e.g. if you want start gaming or video-edit, but make less sense to “manipulate” PWM twice in BIOS/UEFI and through additional mechanism.
