Configuration du localhost ailleurs
#1
Bonjour,
Je souhaite avoir mon local host ailleurs que sur /srv/http.
En regardant le wiki voici les manip que j’ai effectue:
  • decommenter #Include conf/extra/httpd-userdir.conf dans /etc/httpd/conf/httpd.conf
  • chmod o+x ~
  • chmod o+x ~/Workspace
  • chmod -R o+r ~/Workspace
  • modifier le /etc/httpd/conf/extra/httpd-userdir.conf
# Settings for user home directories
# Required module: mod_authz_core, mod_authz_host, mod_userdir
# UserDir: The name of the directory that is appended onto a user's home
# directory if a ~user request is received.  Note that you must also set
# the default access control for these directories, as in the example below.
UserDir Workspace
# Control access to UserDir directories.  The following is an example
# for a site where these directories are restricted to read-only.
<Directory "/home/*/Workspace">
    AllowOverride FileInfo AuthConfig Limit Indexes
    Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
    Require method GET POST OPTIONS
</Directory>
et restart le service httpd.
cela ne fait rien du tout … J’ai rajoute des fichiers dans /Workspace et quand je vais dans le local host je les vois pas du tout.
Quelqu’un aurait une solution ?
Merci d’avance
