Can you show me what you typed in? You might have misspelled something.
Yes sure, there it is:
LC_ALL=C sudo pacman install base-devel git 1 ✘ 6s
[sudo] Mot de passe de frostbear :
erreur : aucune opération spécifiée (utiliser -h pour l’aide)
Okay I spelled “PACMAN” my bad, sorry.
I did it right, but now, I’ve got the same problem when I try to do this:
pacman -Syu vulkan-amdgpu-pro amd-vulkan-prefixes
Do this instead:
pamac build vulkan-amdgpu-pro amd-vulkan-prefixes
I installed the driver, now, can I start the game with multiple command? like PROTON_LOG=1 + vk_pro %command%
Yes, but without +
Your last solution works! thank you very much @albmar!
I hope this subject could help someone else in the future.
Today some mesa packages have been updated (changed version: 22.3.4-1 → 22.3.4-2). So I tested playing with the mesa driver again (without vk_pro) and it doesn’t crash anymore.
Thank you mate for your help, I am very thankful.
