Hello
I just install nvidia driver (nvidia-470xx-utils) from Manjaro default appstore (pacman I think) but my computer won’t show anything on screen after the restart. It’s still functioning though.
Hello @Flygue
There is a bit more needed than just the utils… mhwd does the job for you:
sudo mhwd -i -f pci video-nvidia-470xx
systemctl reboot
thank you for this quick respond !
the thing is i can’t event see whats on my computer all that is display is the logo of the motherboard manufacturer
I guess i have to reinstall manjaro or is there an other way?
Easiest way would be:
- Boot a Manjaro Install Disk.
- Open a terminal.
- Run this to enter the chroot environment (no sudo/su required):
manjaro-chroot -a
- type 0, if it doesn’t work: type 1 if it asks, instead of 0. (old bug from an old ISO)
- Then you should be in chroot.
- Now install it:
- Exit chroot:
sync && exit
- Reboot the system:
systemctl reboot
i got an error:
Error: invalid use of option: -i/--install
nevermind i rerun the comand and it worked no idea why thought thank you for the help
